I'm in the same boat - I have Dave's adapter board but, having ordered an EEPIZZA, it never arrived. (At least I got a refund.)JannievanZyl wrote: ↑Sat May 16, 2020 10:58 amMY timing in getting an epizza board was pretty bad. Had hoglet's ICE boards made and the epizza and programmer ordered. Just for the vendor to (likely understandably) disappear.
ICE T65/Z80/6809
Re: ICE T65/Z80/6809
This might be an alternative though its lacking the serial (FTD) interface.
https://www.ebay.com/itm/DC5V-XILINX-Sp ... 2912966752
Same for this :
https://www.ebay.com/itm/Xilinx-Spartan ... 4652356207
Or this one :
https://www.ebay.com/itm/Mojo-V3-FPGA-D ... 2969705764
Same for this :
Or this one :
- Contact:
That last one should be usable, it has USB. Perhaps redefine the pin mappings...
BTW: what is the issue with the EEPROM? I found it (M25P80-VMW6) on ebay: 10 for 7 euros.
https://www.ebay.com/itm/10pcs-ST-M25P8 ... 2535498277
This also seems to have been discontinued by the original manufacturer.obiwanjacobi wrote: ↑Sun May 17, 2020 7:02 amThat last one should be usable, it has USB. Perhaps redefine the pin mappings...
The Eagle schematics and board design are here:
https://alchitry.com/products/mojo-v3
I see a few problems:
- The connectors use different pins for power, so it's more than just changing the .ucf file.
- The connector spacing is 2.1 inches, on the EEPIZZA board it's 1.7 inches.
- The EEPROM is a SST25VF040B which is 4Mbit, so only has space for one design (i.e. not multi-boot).
- It doesn't have the additional 6x2 connector
The only FPGA board I'm aware of with a similar main connecror footprint and power supply connections is the DE0-NANO.
Unfortunately, this costs ~£85 in the UK.
- Contact:
Hmm, I guess you always run the risk of ebay/ali products not being available at any time.
If you want to provide consistency you have to make one yourself (can be a copied design) with still available parts for a reasonable price. Bonus is that you can integrate level shifting and make the EEPROM big enough to hold all the code you need.
@Dave: can you explain what the problem is with switching the brand of FPGA? Are you using IP that is bound to Xilinx tooling?
Edit: I see Farnell still carries the XC6SLX9TGQ144 for around 17 euros (without VAT)...
There's no real technical issue here, it's just rather mundane to do this for about 20 different projects. It's much more than just recompiling, because Altera DCMs are different, and the dual port RAMs are less flexible. I'd just rather spend my time on other things.obiwanjacobi wrote: ↑Sun May 17, 2020 8:33 am@Dave: can you explain what the problem is with switching the brand of FPGA? Are you using IP that is bound to Xilinx tooling?
I'm still hoping that at some point eepizza will open his ebay shop again as China starts to recover. If this doesn't happen in the next few months, then I think cloning the existing board is the best way to go. Roland's had good experiences using PCBWAY for Atom2K18, and they do double-sided assembly and part sourcing.
In any event, all the projects are open source, so anyone is free to fork them and add support for different boards/FPGA. If you feel motivated to design a new all-in-one board, then you have my blessing.
I made some HiRes pictures.
2 Questions I have :
@Dave do you have an idea (or educated guess) how many layers the EEPizza board has ?
My guess is at least 4,with (maybe?) a power and ground plane.
Looking at my board pictures it looks that the voltage regulators are already larger than SOT-223
I think it's 4-layers.
Here's the datasheet for the AMS1117:
http://www.advanced-monolithic.com/pdf/ds1117.pdf
The SOT-223 package is 6.3mm x 3.3mm.
Looking at your pixtures, that seems to match what you have.
Do you have any calipers? You could try to measure them.
I think I've found a bug in the 6809 core on the Godil.
If you set a write to memory watch, it always lists the written data as $FF
With the following watches set :
I get the follwowing results :
The first write to $FF90 was $80 from the A register
The second write to $FF90 was $C0 from the A register
The writes to $FF92 and $FF93 where $00 (both clr instructions).
This is on a CoCo 3, but I've used it on there before without problems. I can be certain about what
is being written as this is my code I am debugging
So there seems to be either a small bug or I'm doing something wrong (which is entirely possible!).
>> blist
0: FF90 mask FFFF: Mem Wr Watch (trigger: Always)
1: FF92 mask FFFF: Mem Wr Watch (trigger: Always)
2: FF93 mask FFFF: Mem Wr Watch (trigger: Always)
CPU free running...
00.306531 : Mem Wr Watch hit at CE61 writing FF90:FF .
00.306803 : Mem Wr Watch hit at CE75 writing FF90:FF .
00.307152 : Mem Wr Watch hit at CE7B writing FF92:FF .
00.307157 : Mem Wr Watch hit at CE7E writing FF93:FF .
There is indeed a bug, which only affects the GODIL, which is why I've not noticed it before.
I've committed what I think is a fix to the dev branch:
https://github.com/hoglet67/AtomBusMon/commits/dev
I've also pushed a change that adds an optional address to the next command.
Give this a try and see if it helps; hopefully I haven't introduced any new bugs!
Great work going on here, I have old systems vectrex spectrum etc. Was looking for a fluke 6809 pod but this setup would be ideal for fault finding.
Hi, folks. So when I had originally stumbled on this project, I was having problems with a machine that had a 6809. Fortunately, I figured out what the issue was without the need of the ICE. Now I have a new issue with a Z80 board and would like to use the ICE to troubleshoot it.
I bought 4 of those GODIL50_XC3S500E DIL FPGA modules and those sweet adapters bprosman made and am now reading on the hoglet67 wiki page that they're obsolete?! I'd love to put these together. It's an incredible tool. Can I no longer use them?
Thanks,
Tom
Thanks,
Tom
The GODIL boards are obsolete only in the sense that they are not being made any more - they are still a supported build for the ICE.
Oh, jeez... I just bought 2 off of their website. I contacted them a day or so ago and said their website wasn't working. I guess someone got the message because I could purchase those GODILs now.
https://shop.trenz-electronic.de/de/TE0 ... 50-pin-IDC
That's great to hear. I read up on the eePizza boards and it sounds great.
I'm writing instructions on how to program the GODIL. Here's what I got...
Pending...
Pending...
(Actually, I say not being made - it might be that the GODIL 50 still is, and as you note there is now an adapter story for that model. But the original GODIL 40 seems now not to be a current product. Unfortunately, at present the eepizza board isn't available either.)
Hmm, I wonder if Dave or anyone could cook up a recipe like the one here
https://github.com/hoglet67/Beeb1MHzBus ... CD-on-a-Pi
which allows a Raspberry Pi to load a *.bit file into an FPGA, but with mcs files? This way, no need for giant Xilinx tool download, or for any licensing or signing up.
Have you read this page on the Wiki?Tom swift wrote: ↑Sat Jul 18, 2020 8:48 pm
- Need to register and download Xilinx ISE WebPack version 14.7 ~15GB here: https://www.xilinx.com/member/forms/dow ... 0213_1.zip
- Download relevant .mcs files here: https://github.com/hoglet67/AtomBusMon/ ... r/releases
- Simple terminal emulator needed connected to the serial port at 57600 baud.
- Enjoy.
https://github.com/hoglet67/AtomBusMon/ ... -in-iMPACT
It covers both the GODIL and the EEPIZZA boards, including where to download the latest release from.
LOL! OMG. I clicked on that link on another page of yours and it went to something else. Thanks!hoglet wrote: ↑Sat Jul 18, 2020 8:57 pmHave you read this page on the Wiki?Tom swift wrote: ↑Sat Jul 18, 2020 8:48 pm
- Enjoy.
I can have a look at this over the next day or two.BigEd wrote: ↑Sat Jul 18, 2020 8:57 pmHmm, I wonder if Dave or anyone could cook up a recipe like the one here
OpenOCD includes support for Spartan-6, via this config file:
https://github.com/arduino/OpenOCD/blob ... x-xc6s.cfg
(For programming into FLASH I think both .bin and .mcs file formats should work)
For the GODIL, something like this needs to be created that works with Spartan 3E.
This may actually be quite hard, as it's not included already in OpenOCD.
Here it is: https://github.com/hoglet67/AtomBusMon/ ... e-emulator
It says 'Programming the GODIL' and goes here: https://github.com/hoglet67/AtomBusMon/wiki
Dave, thank you so much for getting back. I'm reading over the programming steps and a bit confused over these steps for the GODIL.
Sorry, I'm just trying not to let the magic smoke out of these GODILs.
Thanks a ton.
- Configure the GODIL jumpers appropriately to power the design that's currently programmed
- Apply power to via these pins
Thanks a ton.
The GODIL needs to be "jumpered" so that it is powered by the pins used by the original CPU.Tom swift wrote: ↑Sat Jul 18, 2020 9:36 pmI understand that the pins need to be reset but I'm wondering which pins need to be powered / grounded for each device. Is it the one's listed at the GODIL Hardware (now obsolete) ICE-T65, ICE-T80 & ICE-6809 pages? They also show serial pins (and trigger?). When are those used? When programming or under test?
So for the 6809 (40 pin DIP), pin 1 is GND and pin 7 is VCC.
This Wiki page shows you which jumpers you need on the GODIL to do this:
https://github.com/hoglet67/AtomBusMon/wiki/ICE-6809
Your setup is a bit more complicated, because your GODIL has 2x 50-pin femake IDC headers in place of the blocks of jumpers. The blocks of jumpers do exist stll though, on Bram's adapter board, and should be in the same relative positions. But do confirm this for yourself with a multimeter (I don't have one of Bram's adapter board myseld).
(All GODILs use the same PCB, it's just different connectors are fitted).
The serial pins are how you interact with the ICE.
The trigger pins can be ignored for now.
Make sure you have looked at the GODIL manual:
http://www.trenz-electronic.de/fileadmi ... L-v090.pdf
This explains far better than I can about powering the GODIL.
This is how I jumpered them for a 6502, Red = Vcc, Black = Gnd and the serial connection, as Dave says, you take the pins that originally also are powered at the original CPU.
Thanks for speaking up. I was gonna give it external supply. The instructions say, 'Apply power to via these pins'. Jumpering makes sense looking at the GODIL schematics now.
I don't get why it needs to be on a bread board. Doesn't the programmer supply voltage to the GODIL? Perhaps I got spoiled working with Arduinos.
So just jumper those pins when you are programming the FPGA. Correct?
I'm sorry. I would PM you but I'm too much of a n00b on this forum.
Hi , no the programmer won’t power the Godil, actually the programmer checks the voltage otherwise it will throw an error message.
Not only jumper them when programming and supplying power but leave them when you put the ICE in the target machine otherwise it wont be powered either.
And to repeat , just for safety
mine was jumpered for a 6502 but once you get the logic you will see.
OK. I just had an epiphany. When I finally get this thing programmed, the board under test will be supplying the power to the GODIL. Correct? That's why you need the jumpers... ahhh, genius. It's all adding up.bprosman wrote: ↑Sun Jul 19, 2020 6:48 amHi , no the programmer won’t power the Godil, actually the programmer checks the voltage otherwise it will throw an error message.
And to repeat , just for safetymine was jumpered for a 6502 but once you get the logic you will see.
Communication through serial to the terminal is handled at A1, C1, A2.
When I program it, I'm supplying voltage at C2 and ground at A1 but also have the jumpers connected.
Great. The pieces are slowing moving into place. If only I can get this damn Xilinx software to install.
What OS are you using ?, as on Windows 10 its pretty straight forward.If only I can get this damn Xilinx software to install.
Great. Tell me what you're doing.pretty straight forward
I'm using WIndows 10. I try installing it and it keep coming up with error messages.
I downloaded Xilinx_ISE_14.7_Win10_14.7_VM_0213_1.zip and also VirtualBox-6.1.12-139181-Win.exe
vboxmanage error pops up when I don't install VirtualBox.
Untested and Appliance Import errors pop up when I do install VirtualBox.
Oh, the appliance import error might be because I didn't allocate enough hard drive space.
