Phill's 32K RAM ROM Board:
-10x 1st Generation board (no noise killer)
-20x 2nd Generation board (with noise killer)
(info was from Phill)
Charlie's AtomMMC 2.0
~20x AtomMMC boards in Mar 2010 (green boards with wire modification)
~20x AtomMMC boards in Dec 2012 (black boards)
(Info was from reading this thread and guessing)
http://www.stardot.org.uk/forums/viewto ... 888#p23727
This is slightly more than I was expecting, and is making me think we should do as much as possible in software to be as compatible as possible.
At some point next week I'll try to do some testing on my real Atom with the version of AtomMMC that it shipped with, and produce a list of the afflicted titles. I got this in Jan 2013. Were there many changes made between the original build in 2010 and this second build?oss003 wrote:The (2) issue only occurs with *filename and *RUN filename commands. Is it possible to only use *LOAD filename and RUN?
Note, this is not an issue with the menu system (I use the double 0D fix), but with titles that span multiple files, and where the first file launches the second. At a guess this would be just:
- Bug Byte Chess
- Program Power Chess
- Akorny Atomia
- All of the Retro Software Titles
