Compiling Atomulator on windows....
Post by Prime » Thu May 31, 2012 9:37 am
What do I need to be able to build Atomulator on windows ?
I'm guessing MinGW and Allegro, but what specific versions ? and do I need anything else ?
SarahWalker
Re: Compiling Atomulator on windows....
Post by SarahWalker » Thu May 31, 2012 11:28 am
You need MingW, Allegro 4.x, Zlib, OpenAL and ALut.
Post by Prime » Thu May 31, 2012 1:57 pm
It also specifically seems to need version 1.2.5 of zlib, apparently some of the zlib interfaces changed after that which has broken compatibility with Atomulator (and prolly b-em too), uef.c seems to be the file affected.
Having installed everything I can get all the c files to compile, but it fails on linking :-
$ make
gcc.exe 6502.o 6522via.o 8255.o 8271.o atom.o config.o csw.o ddnoise.o debugger.
o disc.o fdi.o fdi2raw.o soundopenal.o ssd.o uef.o video.o win.o win-keydefine.o
 atom.res -o "Atomulator.exe" -mwindows -lalleg -lz -lalut -lopenal32 -lwinmm
c:/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot fin
d -lalleg
collect2: ld returned 1 exit status
make: *** [Atomulator.exe] Error 1
I used a pre-compiled version of allegro from here :
http://www.allegro.cc/files/?v=4.4
specifically : http://static.allegro.cc/file/library/a ... -4.5.2.zip
SarahWalker
Post by SarahWalker » Thu May 31, 2012 2:30 pm
Rename the liballegro-*.a file of your choice to liballeg.a.
Post by Prime » Thu May 31, 2012 2:38 pm
TomWalker wrote:Rename the liballegro-*.a file of your choice to liballeg.a.
Bingo that did it. thanks for the speedy responses Tom.
do you have any problem with me hacking support for my rombox (and Charlie's MMC) into Atomulator ?
SarahWalker
Post by SarahWalker » Thu May 31, 2012 5:34 pm
No problem, it's not an emulator I'm interested in anymore.
