Extract files from Atom TAP files.
Post by Prime » Mon May 30, 2011 8:33 pm
Hi all
Does any one know of a utility to extract individual files from an atom .TAP file as used by the Dos Atom emulator ?
Re: Extract files from Atom TAP files.
Post by oss003 » Mon May 30, 2011 8:46 pm
Phill,
if you use the Atom emulator from Wouter Ras, you can save files from a .TAP file to an .ATM file.
Just press F9 to select a .TAP file,
The press Right and select a file,
Press E to export the file to an .ATM file.
Post by danielj » Mon May 30, 2011 9:24 pm
Phill, I've got a little one I've written in java, attached...
java -jar tapsplit.jar filename.tap
It'll barf out all the atm files with 8 character names, spaces removed (not to say there won't be some dots here and there...).
tapsplit.zip
(9.31 KiB) Downloaded 80 times
Post by Prime » Tue May 31, 2011 10:17 pm
OOPS
Didn't notice there where replies.....
Anyway thanks guys, much apreciated.
Having not noticed that people had actually replied to this, I went away and wrote some code to do it....
Attached is Tap2ATM, which will split out the individual files, and optionally truncate them to 8 characters, and optionally send them to a specified directory.
Included is the Lazarus (FreePascal) project and source, this should compile on anything that FreePascal supports.
Tap2ATM.zip
Tap2ATM executable and source.
(481.81 KiB) Downloaded 85 times
