Atom Virgin - gets one !!!
Re: Atom Virgin - gets one !!!
Post by hoglet »
DaveLecky wrote:
Tue Nov 03, 2020 8:12 pm
I’ve just built hoglets Atom to HDMI board....and it works too....
=D>
What do you do if there are lower case letters in a program and you can’t input them.....am I missing something obvious.
Just use the shift key (e.g. Shift-A), it will be displayed in inverse video, but that's expected.
The 6847 Charater ROM doesn't contain lower case.
DaveLecky
Post by DaveLecky »
Thanks Dave
I have also built your noise killer but can’t tell if it’s running or not, I can’t see any difference in the screen display, it’s good without it and with it......does it need to be activated or does it just sit there and do it’s thing....
Electron Plus 1 Pres AP3/4
StrongA RPC, A3020
Atom
Post by hoglet »
DaveLecky wrote:
Tue Nov 03, 2020 8:31 pm
There is a test program on the Wiki:
https://github.com/hoglet67/AtomRamAndN ... mbly-Notes
If you remove LK3 (LKEN) then you should see lots of screen noise (which will be really obvious with that test program)
Some before/after photos here:
viewtopic.php?p=238127#p238127
DaveLecky
Post by DaveLecky »
Hi Dave,
I tried the test program yesterday when I finished assembling the noise killer.
The screen wasn’t scrambled like the before photo you pointed me too, and when I ran it, it did everything you described would happen, but no real difference to the output....as it was good anyway.
I’ll try it with the HDMI board tomorrow.
StrongA RPC, A3020
Atom
Post by roland »
The Atom manual (Atomic Theory and Practise) is on its way to you so you can read and learn how the Atom behaves.
If you can't see any noise on the screen then remove the noise killer board, reinstall the right most 2114's back in the video memory and run the test program. However, if you can't see any noise with the board installed then you shouldn't bother. Believe me, the noise is only irritating and you're better off without it :lol:
DaveLecky
Post by DaveLecky »
Hi folks,
I ran the test as instructed, everything looks fine, fuzzy then clear....great stuff.
I was worried I hadn’t assembled it properly......another success....my soldering is improving.
Just waiting on my YARRB2 and AtoMMC to arrive with a copy of Atomic Theory and Practise to keep me right.
StrongA RPC, A3020
Atom
DaveLecky
Post by DaveLecky »
Hi Folks,
I’ve now completed upgrading my Atom........for now......with,
A YARRB2 and AtoMMC from Roland......great devices.....thanks Roland.
A VIDEO to HDMI adapter and a NOISE KILLER from Hoglet, more great devices....thanks Hoglet (Dave).
All now up and running nicely.
And now for some play time.
StrongA RPC, A3020
Atom
Post by roland »
Very cool. Can you also post a picture of the video adapter box? I want to include it on my (new) website :)
Post by chrisn »
DaveLecky wrote:
Fri Nov 20, 2020 9:34 am
So glad to hear you've got it all working! =D> I have a similar setup with RGB to HDMI, noise killer, Yarrb2, AtomMMC. It's a great combination. Enjoy!
DaveLecky
Post by DaveLecky »
roland wrote:
Fri Nov 20, 2020 11:14 am
Done....see above.
StrongA RPC, A3020
Atom
oss003
Post by oss003 »
Nice setup Dave .... let the fun begin ....
Greetings
Kees
