Atom Virgin - gets one !!!
DaveLecky
Post by DaveLecky » Thu Oct 15, 2020 1:16 pm
Well I got one, but what have I bought...looks well upgraded and not the basic one.
No power supply unfortunately. :(
Could someone give me a breakdown on what is onboard.......here are some photos.
Electron Plus 3 and plus 1, AP6 and Home made MMFS PP SD interface
Electron Plus 1 Pres AP3/4
Beeb issue 7 with IFEL 16 socket Rom/Ram board
Master 128, BooBip multi OS,IFEL SD card
StrongA RPC, A3020
Atom
Re: Atom Virgin - gets one !!!
Post by oss003 » Thu Oct 15, 2020 2:00 pm
Nice catch ..... you have this:
- Motherboard Issue4
- Acorn Colourboard
- 6KB video RAM
- 6KB user RAM
- Floating point (IC21)
- Utility ROM (IC24)
- VIA (IC1)
Missing:
- Printerbuffer (IC50)
- Bus buffers (IC2/3/4)
- Bus buffer control (IC5)
In fact if you don't print and don't want to use any expansion boards on PL6/7 then you don't need the missing IC's.
Looks like LK6 and LK7 are not in so you need +8V-2A as power supply.
Does it start?
DaveLecky
Post by DaveLecky » Thu Oct 15, 2020 3:48 pm
Hi oss003,
Thanks for the summary, I don’t have a power supply yet, I need to sort out that next.
Would it be best to desolder the power components and link 6 and 7 and use a 5volt one.?
It looks good and does not smell, I wish I could say the same for myself.....
StrongA RPC, A3020
Atom
Post by oss003 » Thu Oct 15, 2020 3:51 pm
If you install LK6 and LK7 then you can use a standard USB +5V power supply or another +5V power supply. You can desolder the regulators but that's not necessary.
Just be carefull to use the right polarity ,...
DaveLecky
Post by DaveLecky » Fri Oct 16, 2020 10:53 am
Hi Folks,
Can anyone explain what the two connections are for here..is there an instruction manual for the colour card anywhere ?
And this large capacitor isn’t on any other pics I’ve seen
StrongA RPC, A3020
Atom
Multiwizard
Post by Multiwizard » Fri Oct 16, 2020 12:10 pm
Hi Folks,
the left one is used for the power supply,
the right one is used for the video output of the Colour board & the blue wire something else.
The Manual for the Colour board:
http://www.acornatom.nl/doc/vdu-col-40.doc
Greetings, Wim... :-)
DaveLecky
Post by DaveLecky » Fri Oct 16, 2020 12:27 pm
Thanks for the info,
I’ve just found a suitable power supply so hopefully flash it up soon to see if it actually works.
StrongA RPC, A3020
Atom
Post by oss003 » Fri Oct 16, 2020 12:37 pm
The big capacitor on the keyboard side is not original and is added to stabilize a bad power supply I think.
If you have a decent stable power supply, you don't need that capacitor.
I find it dangerous to have the same connectors for power and video .......
Also C2 is out and the blue wire is connected to the +-side of C2 which means that the video out of the colourboard is the infeed for the modulator.
DaveLecky
Post by DaveLecky » Fri Oct 16, 2020 12:49 pm
Thanks oss003,
I agree, it’s a waiting timebomb, I’ll regig everything once I confirm it’s working.
StrongA RPC, A3020
Atom
DaveLecky
Post by DaveLecky » Fri Oct 16, 2020 12:56 pm
Hi oss003,
Quote,”Also C2 is out and the blue wire is connected to the +-side of C2 which means that the video out of the colourboard is the infeed for the modulator.”
Does this mean I connect the tv to the modulator...or the other socket next to the additional dodgy power socket.? Or both.
StrongA RPC, A3020
Atom
Post by oss003 » Fri Oct 16, 2020 2:54 pm
According to the manual, use the RF modulator.
DaveLecky
Post by DaveLecky » Fri Oct 16, 2020 8:49 pm
YIPEEEEEE........It works.....I tried to type in the colour card test program...but it had typos and I ran out of time to fix.
StrongA RPC, A3020
Atom
Post by oss003 » Fri Oct 16, 2020 8:58 pm
Great news ....... =D>
Post by oss003 » Fri Oct 16, 2020 9:04 pm
Some test programs:
FOR A=0 TO 255;A?#8000=A;NEXT
?#B002=8
CLEAR4;MOVE 0,0;DO CO.A.R.%4;DRAW(A.R.%256),(A.R.%192);U.0
DaveLecky
Post by DaveLecky » Fri Oct 16, 2020 9:07 pm
Great, I’ll try them tomorrow
StrongA RPC, A3020
Atom
Bobbi
Post by Bobbi » Fri Oct 16, 2020 9:10 pm
Your Atom has a different 0 (number zero) key to most of them. Fascinating!!
Post by oss003 » Sat Oct 17, 2020 10:42 am
Good observing .... haven't seen one before ...
DaveLecky
Post by DaveLecky » Sat Oct 17, 2020 12:49 pm
Hi folks,
I input a colour check prog, but the results were cr!p.
I don’t know if it is the old acorn card or the tv not accepting the signal, I had to get a scart cable for my other beebs.
Failing that I’ve seen an analog to hdmi adapter on the forum, may try that.
Not very good.
StrongA RPC, A3020
Atom
Post by oss003 » Sat Oct 17, 2020 12:54 pm
There are some pot meters on the colourboard ... you can read in the manual what they do .... VC1 is for the colour.
There is also a possibility to output RGB .....
http://www.stairwaytohell.com/temporary ... rboard.gif
Post by oss003 » Sat Oct 17, 2020 2:04 pm
RGB should give a much better picture quality.
Multiwizard
Post by Multiwizard » Sat Oct 17, 2020 2:59 pm
yes Kees indeed it is, apart of the 50/60 Hz white band... :(
DaveLecky
Post by DaveLecky » Sat Oct 17, 2020 4:37 pm
Hi folks,
I couldn’t get any better a picture by adjusting the pots.
Sometimes when I adjusted way off a picture I got very vivid colours...just not in the correct place.
I just checked my temporary power supply, it’s 5.42v when unplugged, but only 4.82v when plugged in and Atom switched on.
I’ll have to wait until my new one arrives to test further.
Meanwhile I’ll have to find the parts for RGB, plugs/sockets etc.....or get an analogue to hdmi converter from the forum.
StrongA RPC, A3020
Atom
Post by roland » Sat Oct 17, 2020 4:57 pm
This is quite a low voltage but still in the specified (TTL) range of 4.75 - 5.25V
DaveLecky
Post by DaveLecky » Sun Oct 18, 2020 11:29 am
Do you always get the white band on the RGB signals from this board, does it remain when running games for instance ?
StrongA RPC, A3020
Atom
Post by oss003 » Sun Oct 18, 2020 11:57 am
Yes, the white band is caused by the 60 to 50 hz converter. The screen refresh rate is normally 60 hz but the colourboard is 50 hz and freezes the screen to be shown at 50 hz causing the white band.
DaveLecky
Post by DaveLecky » Sun Oct 18, 2020 3:07 pm
Hi Folks,
I don’t think I’ll be happy with the 50/60Hz white banding, so I’ve been looking into modern equivalents.
1) Hoglets - Atom video to HDMI adapter, which looks great......but..... it’s self build, and has some SMD components which will be well beyond my skills and shakey hand...... viewtopic.php?f=44&t=16907
2) IanB - RGB to HDMI boards, which also looks great and has an add-on board for the Atom, unfortunately he has sold out of the main boards but still has the analog boards...... viewtopic.php?f=8&t=20404&p=286709&hilit=HDMI#p286709
Can anyone suggest where I go to now.....apart from a SMD soldering course... :wink:
I may try the Wanted section for Atom upgrades surplus to requirements.....
I have also ordered a AtoMMC from Roland, I asked him about his RAM/ROM upgrade, YARRB2, for the Atom, again these are out of stock, but he is collecting names to order another batch of boards, so if you would like one too, then register your interest on the For Sale section of the forum....and I’ll get one too....
I’ll have to keep my eyes open for the new upgrades as they appear to get them.....
StrongA RPC, A3020
Atom
DaveLecky
Post by DaveLecky » Mon Oct 19, 2020 8:31 am
YIPEEEE.....I think I’m all sorted now.
Dave(Hoglet) has agreed to solder on the SMD parts and programme the chip..... thanks Dave.
Roland has gone ahead to order a few more Ram/Rom boards, YARRB2, and is supplying a AtoMMC .....thanks Roland.
Thanks to all in the forum developing these new hardware solutions, you are true magicians.... =D>
Stay Safe
StrongA RPC, A3020
Atom
Post by oss003 » Mon Oct 19, 2020 9:28 am
Nice ..... this way you are getting a great Atom with lot of possibilities ........ =D>
DaveLecky
Post by DaveLecky » Tue Nov 03, 2020 8:12 pm
Hi Folks,
I’ve just built hoglets Atom to HDMI board....and it works too....
But when I was attempting to input hoglets test program in the instructions I found out something else about the Atom, it doesn’t do lower case letters, I’ve looked on this forum to find a solution to no avail.
What do you do if there are lower case letters in a program and you can’t input them.....am I missing something obvious.
10 GOSUB a
20 FOR A=#8000 TO #81FF
30 ?A=A
40 NEXT
50 LINK LL0
60aP=#2800
70 DIM LL10
etc etc etc
StrongA RPC, A3020
Atom
