Ramtop wrote: ↑Fri Nov 08, 2019 10:48 am
The technique demonstrated in that video is a very poor way of soldering surface mount ICs. Putting solder on the pads causes them to be lumpy, making it more difficult to align the chip. Its pins will tend to slide into the gaps between the pads. And using a hot air gun is slow and subjects the chip to unnecessary thermal stress.
Seconded!
I really should try to find a suitable camera to video my way of soldering QFP chips, just to show how quick and simple it can be. People tend to drastically over-think SMD soldering.
That would be really great.
I'm still pretty new to surface mount assembly, and I'm still pretty amazed at the results you can get with drag soldering and lots of flux.
The most challening thing I've done to date is to replace a faulty 0.5mm pitch FPGA on one of Revaldhino's GOPs. These are nice little DIP compatible FPGA models, that are sadly now discontinued. The FPGA blew because the switching regulator blew (or may have always been faulty). So it was running the core of 3.3V rather than 1.8V.
The hardest part was desoldering the old part (using hot air) without dislodging any of the surrounding 0603 components. Masking everything possible in Kapton tape did the trick though:
After carefully cleaning all the pads with solder braid, it almost looked like new!
Soldering the replacement part litereally only took a few minutes. Accurate alignment is the key. I tend to use a couple of blobs of blu tack, then tack down a couple of opposite corner pins. The blu tack stops the part moving sligtly when tacking down, leaving both hands free to solder.
And the final result, after cleaning the board with IPA.
The riskiest part of the procedure was buying the replacement part from China. It only cost ~£7 though, and is now working perfectly.
