Extended and modified Atom (was "Faulty Atom")
Post by DutchAcorn » Sun Sep 08, 2019 4:19 pm
I have been working on the Atom that I got yesterday (viewtopic.php?f=41&t=5594&start=5370#p247342).
Regrettably it does not work yet. I have replaced the socket for IC31 and also replaced the IC for a known good one but the symptoms have not changed. I also replaced C4 and I’m using a known good PSU. See here for what I get:
https://youtu.be/QWLWe_g-dXk
If I touch the top part of IC31 with my finger the video behaves erratically (as shown in the youtube video).
I checked the clock signal, which is fine.
It seems something is floating. Any ideas on what to try / check?
Re: Faulty Atom
Post by 1024MAK » Sun Sep 08, 2019 6:05 pm
So if the displayed screen data is staying the same (in between the erratic behaviour when you touch IC31), then the 6847 is able to read the same data from the video RAM. That does not mean that the CPU is doing anything, or doing anything useful. It also could be that the CPU can’t access the video RAM.
Do you have a logic probe, logic analyser or oscilloscope? It may be worthwhile testing the various control signals on the CPU to see what, if anything, it is doing.
The erratic behaviour when you touch IC31, looks like either a dry solder joint, or a bad socket contact, or possibly a cracked PCB track. Does it only occur when you press this chip, or does it occur if you press other areas of the board, or flex or tap other areas of the board?
The other possibility is that the circuit is picking up induced mains voltage from you when you touch IC31 via inputs that are floating (and which should be driven) due to an open circuit fault somewhere else on the board.
oss003
Re: Faulty Atom
Post by oss003 » Sun Sep 08, 2019 7:04 pm
There are no 2114's in IC42/43 and you need that at #8000, the text screen.
Greetings
Kees
Re: Faulty Atom
Post by roland » Sun Sep 08, 2019 7:18 pm
If you need some extra 2114's just give me a sign
Or even better: install Hoglet's noise killer board.
For now you can borrow some 2114's from the program space, just not IC51/52 (IIRC) because those are the zero page.
Does it beep when you press CTRL+G ?
Re: Faulty Atom
Post by DutchAcorn » Sun Sep 08, 2019 8:49 pm
Thanks for the offer, Roland! Actually it came with a fully loaded video memory, I just removed some when I took the picture. It behaves the same with memory installed in IC42 and 43.
Thanks for leading me onto the CPU, Mark! Using another Atom I found that I can replicate the symptoms by removing the CPU.
The CPU does not seem to be very active. The reset on pin 40 goes low when I press break and stays high. But so do all the data and address lines. Clock signals are ok.
Re: Faulty Atom
Post by hoglet » Sun Sep 08, 2019 8:51 pm
Paul,
Can you post a decent resolution photo of the current configuration you are testing.
oss003
Re: Faulty Atom
Post by oss003 » Sun Sep 08, 2019 8:53 pm
Re: Faulty Atom
Post by DutchAcorn » Sun Sep 08, 2019 8:58 pm
Paul,
Re: Faulty Atom
Post by DutchAcorn » Sun Sep 08, 2019 9:00 pm
Maybe this helps: viewtopic.php?f=44&t=6318&p=60505&hilit ... ion#p60505
Greetings
Kees
Thanks Kees, I'll try those.
Re: Faulty Atom
Post by hoglet » Sun Sep 08, 2019 9:06 pm
IC23, which does the ROM select decoding, looks like it's been modified significantly.
I'd try to understand what's that's trying to achieve.
Any chance of a close up photo of that area?
Re: Faulty Atom
Post by DutchAcorn » Sun Sep 08, 2019 9:19 pm
oss003
Re: Faulty Atom
Post by oss003 » Sun Sep 08, 2019 9:21 pm
Maybe it's better to swap IC23 with a standard LS138 for testing.
Greetings
Kees
Re: Faulty Atom
Post by hoglet » Sun Sep 08, 2019 9:31 pm
I think at the very least you should try to trace/document the obvious modifications to the address decoding around !C23.
It's not a modificiation I've ever seen before.
Re: Faulty Atom
Post by DutchAcorn » Mon Sep 09, 2019 5:14 am
Tonight I’ve been connecting some dots. Rom selection logic + CPU not processing = wrong OS selected?
So I thought it might be a variation of the bootstrap logic that I have encountered earlier:
viewtopic.php?f=3&t=10789&p=133077#p132767
Trying shift-break gets me this:
ACORN ATOM is in lower case but I’m not complaining :D
Re: Faulty Atom
Post by roland » Mon Sep 09, 2019 10:23 am
Some people did this just for fun. There are also Atoms that only display the word ATOM (inverted) because that freed up some bytes in the reset routine. Also the memory check for RAM at #2900 was often removed (together with the characters "ACORN " - note the space) to make some room for some additional stuff in the reset routine like automatically enable the DOSrom and enable some bank switching software.
However, this is a remarkable situation because you have an original ROM so that is not modified. My best guess is that the extras on the 74LS138 disable that ROM and enable an eprom on one of the memory boards.
Re: Faulty Atom
Post by hoglet » Mon Sep 09, 2019 10:43 am
If you look carefully at IC24 you'll see it has a "F" on it, which is a bug clue.
It also looks like it's chip select pin is benr out, and has been wired to pin 7 of IC23, which is the 74LS138 address decoder output for #Fxxx
So I think the #Fxxx region of the original ROM is disabled, and is overlaid with by IC23.
I would be very interesting to somehow get a dump of the #F000-#FFFF. Or even just #FF00-#FFFF.
Re: Faulty Atom
Post by hoglet » Mon Sep 09, 2019 10:49 am
Could you run the following program, and take a clear photo?
10 PRINT $12
20 FOR X=#FF10 TO #FFFF
30 A=?X
40 LINK #F802
50 NEXT
60 END
We can then see whether there are other OS ROM modifications.
Multiwizard
Re: Faulty Atom
Post by Multiwizard » Mon Sep 09, 2019 12:38 pm
these modifications looks almost exactly the same as my modified CP/M IC23... :shock:
Greetings, Wim... :-)
Re: Faulty Atom
Post by DutchAcorn » Mon Sep 09, 2019 6:38 pm
10 PRINT $12
30 A=?X
40 LINK #F802
50 NEXT
60 END
This is the result:
Re: Faulty Atom
Post by DutchAcorn » Mon Sep 09, 2019 7:58 pm
Do you know what the modification in your computer is for?
Multiwizard
Re: Faulty Atom
Post by Multiwizard » Mon Sep 09, 2019 8:16 pm
This modification had something to do with the switch board...
And if the switchboard is working it needs a different FP rom too,,, FP 1000 or something.
Edit, I found a pic (from 2016) too:
Re: Faulty Atom
Post by hoglet » Mon Sep 09, 2019 8:17 pm
Hi Paul,
Thanks for posting that screen shot.
Here's a quick disassembly of the updated reset code, which is quite interesting (and a clever optimization).
FF3F   AD FF 9F   LDA $9FFF
FF42   29 4F      AND #$4F
FF44   8D FF 9F   STA $9FFF
FF47   8D FF BF   STA $BFFF
FF4A   AD 01 B0   LDA $B001
FF4D   10 03      BPL $FF52
FF4F   6C FC 1F   JMP ($1FFC)
FF52   A2 33      LDX #$33
FF54   A9 FF      LDA #$FF
FF56   9D EB 02   STA $02EB,X
FF59   BD 98 FF   LDA $FF98,X
FF5C   9D 02 B0   STA $B002,X
FF5F   BD 9A FF   LDA $FF9A,X
FF62   9D 04 02   STA $0204,X
FF65   CA         DEX
FF66   10 EC      BPL $FF54
FF68   9A         TXS
FF69   E8         INX
FF6A   86 EA      STX $EA
FF6C   86 E1      STX $E1
FF6E   86 E7      STX $E7
FF70   A9 0A      LDA #$0A
FF72   85 FE      STA $FE
FF74   20 D1 F7   JSR $F7D1
FF77              EQUB $06,$0C,$0F
FF7A              EQUS "acorn atom"
FF84              EQUB $0A,$0A.$0D
FF87   A9 82      LDA #$82
FF89   58         CLI
FF8A   8D 01 29   STA $2901
FF8D   CD 01 29   CMP $2901
FF90   D0 03      BNE $FF95
FF92   4C B2 C2   JMP $C2B2
FF95   4C B4 C2   JMP $C2B4
FF98   07         EQUB $07,$8A
The original reset code can be seen here:
http://www.acornatom.nl/atom_handleidin ... m/f000.txt
The extra code that has been squeezed in is:
FF42   29 4F      AND #$4F
It basically hands control over to a ROM at #1xxx unless the shift key is pressed.
This is consistent, I think, with what you have observed.
Re: Faulty Atom
Post by hoglet » Mon Sep 09, 2019 10:15 pm
Multiwizard
Re: Faulty Atom
Post by Multiwizard » Tue Sep 10, 2019 7:21 am
Thanks Dave =D> ,
I was already looking for these pages (again) but couldn't find them... :(
Re: Faulty Atom
Post by DutchAcorn » Tue Sep 10, 2019 9:17 am
Thanks Dave! Good to know that it behaves as intended.
Re: Faulty Atom
Post by DutchAcorn » Fri Sep 13, 2019 10:06 pm
I had some time to look into stuff. Thanks to the documentation Multiwizard pointed to I found out how to get the RAM/ROM board to work.
Also found a disc (attached) with alternate OS images. Loading one of them (SOSHS3) at #1000 and pressing break (without shift) gets me this:
So that works as Dave explained from the disassembly.
Disc 9.zip
(42.78 KiB) Downloaded 9 times
Re: Extended and modified Atom (was "Faulty Atom")
Post by DutchAcorn » Sun Sep 15, 2019 10:58 am
The modifications and software are described in this article in Acorn Nieuws (in Dutch). SOS stands for Switch board Operating System and was designed to be able to access all the commands in the support roms that are on the ram/rom board without manually having to select the specific rom (something that the BBC does as standard).
The extra 9 pin socket turns out to be a joystick interface.
Still to find out: the Big Benny RTC; I have not managed to get a time out of that yet...
Post by CMcDougall » Sun Sep 15, 2019 12:10 pm
/\ benny needs 2x1.5v AA batts to keep time, but think you will be using its port for a AtoMMC !
Post by DutchAcorn » Sun Sep 15, 2019 9:17 pm
Check, got the batteries installed. But I only read the first page of the article describing the RTC board so I did not have the actual code to set the clock :oops:
After typing in the code on the second page I found the RTC works perfectly and keeps time. :D
Post by roland » Sun Sep 15, 2019 10:19 pm
=D>
Big Benny is a nice extension for the Atom and it works quite well. I even added a PL8 compatible connector on my Atom2k15/2k18 extension boards for Big Benny and I got it running on those models as well. It's a bit complicated to read and write the clock IC but with the software in Atom Nieuws you can get it working.
There is also a program that makes it work with interrupts so the time is always on screen. I wrote that a long long time ago....
If there are other people that want a Big Benny ... I might have a few ones left. Just drop me a PM when interested.
