Atom Video to HDMI Adapter
Re: Atom Video to HDMI Adapter
Post by hoglet » Fri Jun 19, 2020 7:15 pm
thecellartroll wrote:
Fri Jun 19, 2020 6:49 pm
I would very much like a pair of these. Can the surface mount be achieved with a big standard Maplin solder station? I'm generally pretty crap at soldering...
Can you post a photo of the soldering iron tip?
I do most of my surface mount work with a 2mm bevel tip:
https://www.hakko.co.uk/t18-c2-bevel-ti ... -t-2c.html
This works great for drag soldering the CPLDs.
thecellartroll
Post by thecellartroll » Sat Jun 20, 2020 12:16 pm
These are the tips I have to choose from.
Post by hoglet » Sat Jun 20, 2020 12:22 pm
It's a little hard to tell from the photo, but they both look like a rounded cone shape.
I think you will struggle to drag solder with those.
You really need a bit with some flat surface:
thecellartroll
Post by thecellartroll » Sun Jun 21, 2020 2:06 pm
You are correct. Both tips are rounded at the end and the same all the way round :(
John Ferguson
Assembly details
Post by John Ferguson » Mon Jul 06, 2020 8:19 pm
Some information about the assembly from Dave
How to know which way round the cable to PL4 should be fitted.
If I get it wrong I take it the interface is a right off.
Yes, you don't want to get that wrong.
The cable needs to be such that Pin 1 of J11 connects to Pin 1 of PL4 on the Atom:
- Pin 1 of J11 is the square pad.
- Pin 1 of PL4 on the Atom is identified by a dot on the silk screen, as the end closer to the regulators.
Once connected, but before applying power, use a multi meter on the low resistance range to verify that 0V on the Atom PCB is directly connected to GND on the HDMI convertor. The are a couple of pads labelled GND that you can use for this purpose. The resistance should read <3 ohms. If it doesn't, then something is wrong and you SHOULD NOT APPLY POWER.
There are also the switches and pots. Do I need to touch them?
You will need to adjust RV1 to get a picture. At one extreme, everything will be black, At the other, everything will be green. Somewhere in the middle will be a point where you see the ACORN ATOM prompt.
RV2 is not critical.
The three push button switches operate a menu system. You'll need to use this at some point to optimise the settings for your monitor and your Atom.
There are instructions here:
https://github.com/hoglet67/RGBtoHDMI/w ... tart-Guide
But you should get a picture without needed to use the Menu.
What's the make/model of your monitor?
Which switch is the reset one?
SW4, the right-angle one.
John Ferguson
Post by John Ferguson » Mon Jul 06, 2020 8:25 pm
When I click on the link for the instructions I get error 404.
John
Post by oss003 » Mon Jul 06, 2020 8:27 pm
Post by BigEd » Mon Jul 06, 2020 8:39 pm
Probably this particular page: Quick Start Guide
John Ferguson
Post by John Ferguson » Tue Jul 07, 2020 7:17 am
I have to confess that I went crashing ahead and installed the HDMI interface and got the connection to PL4 the wrong way round. So I have to accept that it’s a right off.
I cant bring myself to make another one so the board will remain in my abandoned hardware box.
They say you learn by your mistakes and that’s why I reluctantly have to fade out from this project.
If someone has a working one that wants to sell it I would be interested. Some hope.
John
Post by hoglet » Tue Jul 07, 2020 7:27 am
I've just checked the schematic, and it you might be lucky. A reversal of PL4 would connect +5V to pin 9 (it was pin 2). This pin is connected to a DC blocking capacitor (C1) so not a lot of current will flow.
So it may actually be OK.
How long was it power on for?
Have you actually tried it the right way around?
John Ferguson
Post by John Ferguson » Tue Jul 07, 2020 7:58 am
Sounds as though I might be lucky. It was installed wrongly for only a short time. On seeing no signal I tried it the other way to no effect. I take it the leds should light up if you get it right.
There was damage to the Atom which needed the 8255 and the 6847 chips being replaced.
I will follow your advice later as I have removed the cable.
Thanks. John
John Ferguson
Post by John Ferguson » Tue Jul 07, 2020 5:12 pm
Thanks. John
Having made sure the ground connection to the Atom was correct as you advised I connected the interface again to the Atom but no HDMI signal was the result.
I have come to the conclusion that the board is damaged so it has to be abandoned.
John
Post by hoglet » Tue Jul 07, 2020 5:54 pm
I'm sorry this hasn't been a positive experience for you John.
I would be happy to take a look at the board for you, if you would like to post me the HDMI PCB, the Pi Zero and the SD Card.
Nothing is beyond repair in the Atom world!
John Ferguson
Post by John Ferguson » Tue Jul 07, 2020 7:07 pm
I love your optimism. I am happy to take up your kind offer. I am not aware of an SD card.
Please can you let me have your address?
John
Post by hoglet » Tue Jul 07, 2020 7:20 pm
OK, but before that....
John, I really don't understand this comment.
Most of the work in RGBtoHDMI is done with Rasberry Pi Zero running our custom software. You need to install that software, by unzipping it onto a Micro SD card, and putting that in the Pi Zero. That's what the Quick Start Guide covers.
Have you actually done this step, and put the SD Card into the slot in the Pi Zero?
Without a SD Card, the Pi will not boot, and you'll not get any HDMI output.
John Ferguson
Post by John Ferguson » Tue Jul 07, 2020 7:35 pm
I have found the SD card in my box of components I ordered at the start and failed to fit it or install any software.
Shall I go ahead with this or ship the whole thing to you?
John
Post by hoglet » Tue Jul 07, 2020 7:44 pm
Please do give it a try.
Here's a direct link to the ZIP file:
https://github.com/hoglet67/RGBtoHDMI/r ... 19df1c.zip
You need to unzip this onto the SD Card.
Let's see if that gets you any further.
John Ferguson
Post by John Ferguson » Tue Jul 07, 2020 7:48 pm
I will give it a try.
John
John Ferguson
Post by John Ferguson » Wed Jul 08, 2020 9:34 am
John
I extracted the files to the SD card but I see there are some folders. Is this okay?
John
Post by hoglet » Wed Jul 08, 2020 10:22 am
Yes, it's expected. In the root of your SD card you should end up three folders (Profiles, Resolutions and cpld_firmware), plus about 15-20 other files.
Don't move or rename any of the files!
John Ferguson
Post by John Ferguson » Wed Jul 08, 2020 11:27 am
Yes it is as you say.
John
John Ferguson
Post by John Ferguson » Wed Jul 08, 2020 12:13 pm
John
The good news is that the interface is working normally after the auto configuration.
What a fantastic quality display you have achieved.
I could not be more happy now I have your noise killer board and Roland's Yarrb. The Atom is reinvented.
These are wonderful achivements.
Regards
John
John Ferguson
Post by John Ferguson » Wed Jul 08, 2020 2:36 pm
John
Regards
John
Some photos of the display.
John
Post by hoglet » Wed Jul 08, 2020 3:54 pm
=D> =D> =D> =D> =D> =D> =D>
Well done John for persevering!
Post by roland » Wed Jul 08, 2020 8:40 pm
John and Dave, well done!
I guess that John now almost knows every in and out of the Atom :lol:
thecellartroll
Post by thecellartroll » Mon Aug 10, 2020 2:43 pm
Now I have a new soldering iron, a hot air blowing doobery and a bucket of solder paste, could I please order a pair of boards if any are left? :D
Post by hoglet » Mon Aug 10, 2020 2:53 pm
PM sent....
