System Clone design files....
Prime
Post by Prime » Tue Jan 22, 2019 8:51 pm
Hi all since I have been asked about these :
Here's the Eagle design files for the following :
6502 clone board,
Video board combination of the 40 and 80 column boards, switchable between the two.
Backplane board.
Floppy / Econet board, 8271 based, Econet is implemented by a Master / Arch Econet module.
Gotek clone.
6809 clone board.
SystemCloneSchematics.zip
System clone schematics.
(1014.17 KiB) Downloaded 51 times
These should be able to be opened in any version of Eagle after 6, you should also be able to produce gerbers from them even using the free version, however you will need either the hobby or professional versions to modify them.
I'll update this post later with the design files for the CPLDs on the boards, and the AVR code for the Keyboard interface on the CPU board.
Right here's the Webpack projects for the 6502 & 6809 CPUs, the Video and Floppy boards. You'll need Xilinx webpack (14.7, which is the latest version) to compile these, sorry Webpack is a big download :(
SystemCloneXilinxFiles.zip
System clone Xilinx files.
(85.81 KiB) Downloaded 27 times
And here's the AVR source for the PS/2 -> System keyboard interface, which is on the CPU boards.
SystemCloneKeyboard.zip
System clone keyboard AVR source.
(26.31 KiB) Downloaded 32 times
If you have any questions about any of the above feel free to ask.....
Phill.
bprosman
Re: System Clone design files....
Post by bprosman » Wed Jan 23, 2019 2:26 am
Thanks Phill for publishing these !
Kind regards, Bram
ask_nz
Post by ask_nz » Sat Feb 09, 2019 7:36 pm
Wow - thanks Phil, that’s great :D
Ade
ask_nz
Post by ask_nz » Sun Mar 03, 2019 6:49 pm
Hi Phil,
What do you use to program your CPLDs?
Ade
Ade
Prime
Post by Prime » Sun Mar 03, 2019 11:56 pm
Hi Phil,
*COUGH* Phill *COUGH*
Xilinx webpack and one of the clone Xilinx usb programmers like the one shown on hoglet's wiki page here : https://github.com/hoglet67/AtomBusMon/ ... requisites
Phill.
ask_nz
Post by ask_nz » Mon Mar 04, 2019 5:09 am
Sorry Phill (I'm not very observant most of the time).
...and thanks for the link - I'll check it out.
and again - many thanks for all your hard work :)
A.
Ade
bprosman
Post by bprosman » Tue Mar 05, 2019 10:26 am
Hi Phill,
What toolchain do you use to compile the Keyboard (AVR) files ?
Atmel Studio ? Or "native" AVRgcc ?
Kind regards, Bram
sirmorris
Post by sirmorris » Tue Mar 05, 2019 11:58 am
Beautiful work as always, Phill!
Prime
Post by Prime » Tue Mar 05, 2019 2:40 pm
Hi Phill,
Usually the AVRgcc toolchain, I'm on windows so I (historically) installed WinAVR, and then updated it with the more recent Atmel command line package.
Phill.
