Hi All,
This is probably a question mostly for hoglet.....
Does the ICE-T 6809 target sdupport both the 6809 and 6809E......the board I may want to use it in has the former.
ICET-6809
Re: ICET-6809
Hi Phill,
It you look on the Wiki there is a "E Mode" jumper to select between the two modes:
https://github.com/hoglet67/AtomBusMon/wiki/ICE-6809
Yes indeed it does.
Re: ICET-6809
Cheers Dave,hoglet wrote: ↑Tue Oct 09, 2018 11:26 amYes indeed it does.
Though I think I worked out why my System clone 6809 board is not working.....helps to have the code in the right section of ROM so the CPU can read it rather than just getting FF
