Decent 5v PSU recommendation for Atom
markjw
Post by markjw » Sun Sep 23, 2018 5:19 pm
Looking to convert my Acorn Atom to 5 volts and thus will need a new PSU, however given the number of crappy cheap power supplies out there I would like anyone's recommendation on a decent unit at a reasonable price that will not go bang in a month's time.
Would prefer one with the correct sized connector so I don't have to modify it or the Atom.
Re: Decent 5v PSU recommendation for Atom
Post by Prime » Sun Sep 23, 2018 6:17 pm
And I have used these :
https://www.rapidonline.com/powerpax-uk ... 5a-85-2940
For powering Atoms and other stuff that needs a +5V PSU....even powered a beeb board off them with no problems**.
**The beeb board does need -5V for the sound circuit, but there are chips that will act as an 'inverter' with a couple of discretes to generate the -5V. If you don't need sound it runs fine off just +5V.
Post by CMcDougall » Sun Sep 23, 2018 6:55 pm
viewtopic.php?f=44&t=15236
already answered a few threads down!
markjw
Post by markjw » Sun Sep 23, 2018 7:55 pm
thanks for the suggestions - eyesight must be going, missed the other thread (and also manged to reply to it instead of this one)
Interesting suggestion on the USB adapter - I've got a charger from an old iPad which I think is 2 amps - get myself a cable for it and problem sorted
Post by tricky » Mon Sep 24, 2018 7:22 am
For regularly keeping up with threads, I use the Active Threads Topics link from the three bar menu in the top left of the page.
