Econet Card on Ebay
John Ferguson
Econet Card on Ebay
Post by John Ferguson » Wed Jul 25, 2018 6:52 am
Just to let members know that an issue 1 Econet card has gone on sale on Ebay.
The sale is nothing to do with me.
I thought members of this forum would be interested. I hope I have not broken the rules.
John
Last edited by John Ferguson on Wed Jul 25, 2018 12:49 pm, edited 1 time in total.
Kazzie
Re: Econet Card on Ebay
Post by Kazzie » Wed Jul 25, 2018 8:30 am
As a lay member, the post may have been better suited to the "Worth Taking a Look At" thread in the buying/selling section, but those who only frequent this atom/system corner may not look there regularly.
One thing is certain though: There have been two bids within half an hour of you posting, so it seems to have worked!
Post by roland » Wed Jul 25, 2018 9:19 am
I thought, give it a try :mrgreen:
256K + 6502 Inside
marcusjambler
Post by marcusjambler » Sun Jul 29, 2018 2:31 pm
I'm currently the winning bidder on this card
markjw
Post by markjw » Mon Jul 30, 2018 10:02 am
spotted that last night whilst having trawl though eBay - I've never seen one before and was interested in how it works.
marcusjambler - best of luck with your bid - I'll not bid against you on it. If you win let us know if you get it working.
marcusjambler
Post by marcusjambler » Mon Jul 30, 2018 10:16 am
Hi Mark
If I win I'm planning on sharing :D
Post by hoglet » Mon Jul 30, 2018 10:34 am
For anyone considering buying this to reverse engineer, the schematic is already available:
https://www.4corn.co.uk/archive/diagram ... %20PCB.jpg
And the technical manual is here:
http://www.bighole.nl/pub/mirror/homepa ... boards.htm
I would say this is of limited use, because PL8 cannot easily be shared, and many Atoms now have AtomMMC connected to PL8.
marcusjambler
Post by marcusjambler » Mon Jul 30, 2018 10:49 am
thanks Dave good to know
markjw
Post by markjw » Mon Jul 30, 2018 8:59 pm
might be possible to make it switchable - there appears to be an enable out on PL8 pin 4 fed from IC49 described in the Atom technical manual which could be intercepted - however I can't locate IC49 on the schematic I have to see what it actually is connected to.
Post by IanS » Mon Jul 30, 2018 9:04 pm
IC49
Post by Prime » Tue Jul 31, 2018 6:24 am
It should be able to be shared, both the current version of AtoMMC and the Econet card only use 3 or 4 IO addresses.
It's easier to move AtoMMC as we have the source code :)
I did make a board that was a clone of the AtoMMC (I had Charlie's permission!) and a socket for a Master Econet module, worked reasonably well except of course you can only have one $A000 rom active at once, so it's either Econet or MMC. Having said that I believe that it's possible to use AtomDOS & Econet, so maybe SDDOS would also work.
Post by roland » Tue Jul 31, 2018 6:58 am
In an unexpanded Atom you can also use an eprom (2532) at #Exxx by piggy packing it on another rom and connect the cs pin to ic23 pin 9. Remove ic4 to avoid conflicts on the data bus as #Exxx is meant to be outside the Atom. That way you can have both the MMC rom and the Econet rom.
Or contact me for a free (almost: just p&p), simple expansion board at #Axxx ;)
256K + 6502 Inside
marcusjambler
Post by marcusjambler » Tue Jul 31, 2018 9:30 pm
I decided not to pursue it :D
myelin
Post by myelin » Tue Jul 31, 2018 10:20 pm
Looks like it sold for £51! Way above what I was hoping for :)
