New Atom owner (soon)
myelin
Post by myelin » Thu Jul 05, 2018 9:32 pm
After staring at it on eBay for a couple of weeks, I finally cracked and bought the 200 euro Atom from backtoyourpast (pricey, but out of the Atoms I've seen whose owners will ship to the USA, it seemed bearable). So... I expect to be an Atom owner once it arrives in San Francisco :)
Re: New Atom owner (soon)
Post by Elminster » Thu Jul 05, 2018 10:31 pm
I am waiting for Roland to reinvent his Atom design. 200 euros seems a bit steep.
Failing that I hope to magically acquire one.
waltermixxx
Post by waltermixxx » Thu Jul 05, 2018 11:49 pm
200 euro's for an Atom is not bad,
I've seen it as high as $800.00 or so for an Atom.
or no Atom's at all. Good for you for getting one.
I finally got one for myself as well. And I love it.
Upgraded it to 32k, and added a coco 2 composite video board to it,
as a colour board.
Please make sure you get one of those MMC interfaces for it as well,
very reasonably priced and totally necessary for reliving some of those
gaming memories. :)
Congrats on your purchase, Bottom line, Congrats... :)
Cheers. :)
Post by hoglet » Fri Jul 06, 2018 5:45 am
This is actually a very good price for decent Atom, and the Issue 5 atom is definitely the one to have.
What's you plan in terms of extensions?
AtoMMC2 and some kind of RAM/ROM board are the two "must-have" Atom extensions.
For a nice, clean video output from the 6847 I use a custom scan convertor which works very well, and doesn't require any mods to the Atom:
https://github.com/hoglet67/AtomVGAWing
viewtopic.php?p=58741#p58741
myelin
Post by myelin » Sun Jul 08, 2018 2:41 am
Not sure yet! AtoMMC2 seems like an excellent start.
I like the look of your scan converter. Also, do you think your RGBtoHDMI hardware could be adapted to work here? I guess you would need comparators on the inputs...? I'm still figuring out how the whole Y/PA/PB video thing works.
8bitkick
Post by 8bitkick » Sun Jul 08, 2018 4:34 am
Hey congratulations I've just been getting my Atom running too. I imagine there aren't many in California!?
Until you get your MMC this might be useful. I just saw your post which prompted me to get in online...
myelin
Post by myelin » Sun Jul 08, 2018 6:55 am
Thank you! Yes, that'll be super useful! Are you bringing your Atom to VCF? There's a slight chance that mine might arrive in time...
Post by hoglet » Sun Jul 08, 2018 7:58 am
From a timing point of view I'm sure it could be made to work.
The only problem is the Y/PA/PB signals are relatively low voltage swing and tri-level (with some redundancy).
Figure 10 in the 6847 data sheet best explains this.
In the FPGA I use the differential LVDS I/O cells rather than external comparators. Each of PA and PB uses a pair of LDVS I/O cells, which allows comparison against two different thresholds. This gives you the tri-level sensing. The Y signals is clamped with a proper back-porch clamp circuit to restore the black level.
I'll check the DipTrace schematic and PCB design into github this morning.
8bitkick
Post by 8bitkick » Sun Jul 08, 2018 3:36 pm
I was planning to bring my Atom. I can start another thread as we need to sort out logistics for the day...
myelin
Post by myelin » Tue Jul 10, 2018 9:24 pm
Oh, I see now -- you're using the differential inputs to compare against voltage references, which explains the AH/AL signal names :) So you need quite a few more inputs into the system than when just reading an RGB signal.
