What is a good PSU for a 5V modded Atom?
Post by tricky » Tue Jun 12, 2018 9:19 pm
I'm planning on removing and keeping the extra RAM and ROM and replacing them with a modern board, so I think 1.2A will be enough.
A tour of ebay suggests:
£9 GENUINE ORIGINAL MW MD050S120 IC REGULATOR POWER SUPPLY ADAPTER 5V 1200mA
seems to have screws! UK buy it now
£10 UK 5V 5.0V 2A 2.0A Mains AC-DC Switching Adaptor Regulated Power Supply 5.5mm
UK buy it now
£13.50 4A/4000MA 5V 20W AC/DC MAINS REGULATED POWER ADAPTOR/SUPPLY/CHARGER/PSU
UK buy it now
There are also many LED PSUs (most don't mention being regulated).
Re: What is a good PSU for a 5V modded Atom?
Post by 1024MAK » Tue Jun 12, 2018 9:46 pm
If you have Maplin store near you that is still open, they may still have some that are suitable, and which by now will be discounted.
I'll go though your links later.
The basic problem is that it is not possible to know the quality of power supplies bought via eBay or similar outlets.
In terms of quality, I'm talking about both how good the regulation of the output voltage is, and the quality of the design and workmanship, that is, is it safe with regards to the separation of the mains voltage from the low voltage output circuitry.
Hence, the normal recommendation is to buy from a U.K. store that you trust.
Post by CMcDougall » Tue Jun 12, 2018 9:52 pm
go into your old mobile / tablet 5v Adaptor drawer, pick out something 1AMP for a non modded Atom.
if new mods, or old ram mod boards, use >1AMP
I use these, easy as pie 8)
USB 5v
Post by roland » Tue Jun 12, 2018 10:00 pm
I also use (and advice) a 5V 2A usb adapter, bought in a local store.
256K + 6502 Inside
Post by 1024MAK » Tue Jun 12, 2018 10:12 pm
UK buy it now
Power Adaptors UK also have a web site: http://www.poweradaptorsuk.co.uk//aboutus.asp
If you mean LED driver power supplies, well, basically LEDs need their current regulating (limiting), not the voltage. But some PSU sold for use with LEDs are in fact ordinary PSU's...
markjw
Post by markjw » Sun Sep 23, 2018 7:13 pm
thanks for the recommendations - I'll take a look
Post by tricky » Mon Oct 22, 2018 10:51 am
With a 5V modded ATOM, should/can the LM340Ts be removed?
Post by oss003 » Mon Oct 22, 2018 11:19 am
Hi Tricky,
with LK6 and LK7 in, the LM340Ts can be removed.
Post by tricky » Mon Oct 22, 2018 11:34 am
Thanks Kees, I had cunningly I thought mounted my power connector at the end of the parallel connector, but I was just fitting my RAMROM board and noticed that it had plans for that little gap, so now I need to move things around a bit and the extra 1/4" will be useful.
