Connecting a printer to the Atom
John Ferguson
Post by John Ferguson » Sun Apr 15, 2018 4:02 pm
Is there a solution to connecting a modern printer to the Atom?
Has anyone solved this problem.
I would be interested to hear.
John
lcww1
Re: Connecting a printer to the Atom
Post by lcww1 » Sun Apr 15, 2018 4:28 pm
A similar question relating to the Beeb was recently asked here - viewtopic.php?f=3&t=14876 - and this older thread is also relevant viewtopic.php?f=3&t=4344 - of the options discussed in these threads, perhaps best bet would be find an older HP laser with a parallel port. Otherwise, printing to an Econet print server may be an option, though requiring a reasonable amount of additional equipment. Alternatively, wait for the RetroPrinter to become available, which ought to make this sort of thing much easier....
Post by oss003 » Sun Apr 15, 2018 5:19 pm
If the printer has a centronics connector, it shouldn't be a problem.
You do need IC's 1 and 50 to print.
ASCII won't be a problem but graphics can be because bit 7 is not connected to the printer dataoutput.
John Ferguson
Post by John Ferguson » Sun Apr 15, 2018 6:32 pm
Thank you about installing ic1 and 50.
I have these on order.
Then I see from the technical manual I need a 26 way pcb connector but I can’t find any printer cables as they all require 36 ways. The manual talks about a ribbon cable connector but does not explain how this would work with a printer.
Has anybody solved this problem?
John
Post by oss003 » Sun Apr 15, 2018 6:50 pm
Hi John,
I don't think that there are standard Atom printer cables, you have to make it yourself ...... ;)
- a 26-pin flatcable connector
- a 26 wire flatcable
- a centronics connector
Centronics pinout: http://pinouts.ru/ParallelPorts/Centronics_pinout.shtml
Atom pinout:
John Ferguson
Post by John Ferguson » Sun Apr 15, 2018 9:12 pm
Hi Kees
Looking at your diagram of the connections I see that 26 way connectors are required.
I have done some research and found for sale a bbc micro parallel printer cable 26 way idc to centronics 36 way printer cable.
This should fit a right angle 26 way idc pcb connector for the Atom as recommended in the technical manual.
Next to find a printer.
John
Post by Prime » Mon Apr 16, 2018 12:23 am
I really must dust down the design I had for paralell printer output to serial. Basically just an AVR reading an input port on strobe and outputting on serial. Should actually be easy to do as an arduino shield.....let me think on that.
herklots
Post by herklots » Wed Apr 18, 2018 1:32 am
Why not add the extra inverter for the Centronics bit 7? The connector has the pins...
Post by Prime » Wed Apr 18, 2018 7:00 pm
herklots wrote:Why not add the extra inverter for the Centronics bit 7? The connector has the pins...
And it would be super easy to piggy back another LS244 on the one already there and use that.
Post by jgharston » Wed Apr 18, 2018 7:13 pm
oss003 wrote:I don't think that there are standard Atom printer cables, you have to make it yourself ...... ;)
A standard Atom printer cable is a standard BBC printer cable.
John Ferguson
Post by John Ferguson » Thu Apr 19, 2018 6:53 am
Hi Phill
How would you provide the connections to get bit 7 by piggybacking the ic50?
It sound a very interesting idea.
John
Post by oss003 » Thu Apr 19, 2018 8:53 am
Post by Prime » Thu Apr 19, 2018 8:55 am
John Ferguson wrote:Hi Phill
Piggy back it on the current chip with only power, ground and enables connected to the bottom chip (so pins 1,10,19 and 20). Bend all other pins on the upper chip so they make no connection with the lower.
Then pick one of the other buffer inputs, and connect to D7 on the 6522 output port. Connect the buffer's output to d7 on the printer port.
Note I've not actually tried this but see no reason why it would not work.
Post by oss003 » Thu Apr 19, 2018 9:20 am
It the databit latched?
John Ferguson
Post by John Ferguson » Thu Apr 19, 2018 4:48 pm
Hi Phill
I understand about piggy backing the ic50 but not the connections you describe to follow.
I need pin connections then to follow. Buffer inputs and outputs mean little to me.
Thanks for your help.
John
John Ferguson
Post by John Ferguson » Fri Apr 20, 2018 3:27 pm
Hi Phill
Looking at the data sheet for the ls244 buffer chip to be piggy backed on the ic50 I will connect pin 9 of the 6522 via chip to pin 17 of the buffer with pin 3 of the buffer connected to the printer connector where bit 7 should have been.
I hope this is okay.
John
