Kamikazi
Telemedic
Kamikazi
Post by Telemedic » Sun Feb 11, 2018 7:02 pm
Well guys, I have ordered a new op amp, and am awaiting delivery. As soon as I can load the file, I will upload it, along wit pics. :)
Re: Kamikazi
Post by oss003 » Mon Feb 12, 2018 7:57 am
Maybe it's better to make a WAV file, like hoglet suggested, before you start.
It's an old tape and when something happens, you can always create a new tape from the WAV file.
Re: Kamikazi
Post by CMcDougall » Mon Feb 12, 2018 6:25 pm
oss003 wrote:it's better to make a WAV file
yes exactly, as I said on BoringBook first! 8)
Does anything else load into your Atom Tony? as the tape might have been recorded over with Madonna :x
Telemedic
Kamikaze!
Post by Telemedic » Tue Feb 13, 2018 12:52 am
Finally it loads!!! And it’s a good game! Very difficult space invaders/Galaxians style game :)
Multiwizard
Re: Kamikaze!
Post by Multiwizard » Tue Feb 13, 2018 7:03 am
Telemedic wrote:Finally it loads!!! And it’s a good game! Very difficult space invaders/Galaxians style game :)
Nice =D> , now,,, WAV file please... :mrgreen:
Greetings, Wim... :-)
Re: Kamikazi
Post by oss003 » Tue Feb 13, 2018 7:04 am
Ok Tony, nice job ..... =D>
Re: Kamikazi
Post by oss003 » Tue Feb 13, 2018 9:51 pm
Ok guys, Tony uploaded the Kamikaze WAV file and here is the ATM file.
Enjoy playing thanks to Tony..... =D>
KAMIKAZ.zip
(2.97 KiB) Downloaded 15 times
Re: Kamikazi
Post by hoglet » Tue Feb 13, 2018 9:53 pm
Nice game, thanks Telemedic/Tony for saving this!
Multiwizard
Re: Kamikazi
Post by Multiwizard » Tue Feb 13, 2018 10:21 pm
Awesome... :P
Many thanks you all... =D>
Re: Kamikazi
Post by CMcDougall » Tue Feb 13, 2018 11:15 pm
seems Dave has won the high score challenge already :shock:
did the .WAV get uploaded anywhere :? ,
& was it any good for a .UEF convert
can't believe how similar it is to the Electron version 8)
Telemedic
Re: Kamikazi
Post by Telemedic » Tue Feb 13, 2018 11:55 pm
Hi guys, I’d just like to thank everyone for their patience, also Kees and hoglet for
The conversion to .atm. I am thrilled that my atom purchase has been not only a great experience for me, but a gain for the achive too! This has made my day, and in a way has justified the £200 for the machine! Hope you all enjoy :D
Re: Kamikazi
Post by oss003 » Wed Feb 14, 2018 7:08 am
CMcDougall wrote:did the .WAV get uploaded anywhere :? ,
The CSW file has errors but the UEF file works fine. I'll upload them this evening.
Here's the link to the WAV file: https://drive.google.com/open?id=1FU4ol ... RgKwauAgG-
Re: Kamikazi
Post by CMcDougall » Wed Feb 14, 2018 12:20 pm
^cheers Kees, some weird .WAV that, says non standard :x
below is CSW (no work on Atomulator127) & working UEFhq 8)
kamikazeUEFhq CSW.zip
CSW UEFhq
(125.76 KiB) Downloaded 11 times
Re: Kamikazi
Post by hoglet » Wed Feb 14, 2018 12:51 pm
Colin,
CMcDougall wrote:^cheers Kees, some weird .WAV that, says non standard :x
Do you want to try this WAV file, see if it's any better for conversion to CSV?
KAMIKAZE.zip
(127.94 KiB) Downloaded 14 times
(it's computer generated directly from the ATM file)
Telemedic
Re: Kamikazi
Post by Telemedic » Wed Feb 14, 2018 1:21 pm
The wav file I sent was recorded from tape to goldwave, that’s when I realised it was 16 bit. So I resaved it as 8bit. So weather the conversion is a bit “how ya doin’” I don’t know. But at least it’s out there :)
Re: Kamikazi
Post by CMcDougall » Wed Feb 14, 2018 9:07 pm
Telemedic wrote: But at least it’s out there
yes sure is Tony, nice1! 8)
hoglet wrote:Do you want to try this WAV file, see if it's any better for conversion to CSV?
Evening Dave,
this 'ATM' file did work on Atomulator127, but shows nothing in the "Show tape cat" :? (even with "Rewind tape" first)
BUT does not make anything for a UEFhq file :x
also noticed no peaks or troughs at all, and no two seconds between blocks, hence why original 4min29sec / atm 3min39sec
original WAV 4:29
ATM gen WAV 3:39
I've not tried to load the ATM into my Atom, but doubt will work, but will confirm tomorrow >1pm
When using my UEFhq, and the FreeUEF prog to .WAV, it does not sound right at all, so won't load into real Atom.
I can confirm my CSW does with BackToLife prog to .WAV, load into real Atom.
Cheers again, Col.
KAMIKAZEfromATM worksAtomulator127 not makeuef.zip
CSW for Atomulator ONLY
(9.38 KiB) Downloaded 9 times
Re: Kamikazi
Post by oss003 » Wed Feb 14, 2018 9:33 pm
Hi Colin,
I managed to get a working CSW and UEF file ....
I used Charlie's ATM2WAV program to create a new WAV from the KAMIKAZ.ATM file.
Then, after converting the WAV to 8 bit mono 44kHz, I could create a working CSW file.
kamikaz.zip
(13.23 KiB) Downloaded 11 times
Re: Kamikazi
Post by CMcDougall » Thu Feb 15, 2018 2:41 pm
Afternoon folks,
my humble spare room setup:
room
with playing the various .WAVs from original (Tony), my CSW, Dave's ATM>WAV, Kees ATM>CSW>WAV
I get the following with playing out laptop at Vol 23% :
original .WAV said SUM ERROR 6 at block 0 & 9 ((so does not load) even with Vol33%)
the rest all worked, apart as said previously UEFhq>WAV from MakeUef prog a no go.
now, why does it do extra numbers after each block? ie block0000 FF then 0544 0D00 ??
this happens only with DaveATM & KeesCSW, does not do it with myCSW (still has the two secs between blocks),
the Original or Saveout from Atom....
Cheers, Col.
Re: Kamikazi
Post by oss003 » Thu Feb 15, 2018 3:02 pm
CMcDougall wrote:now, why does it do extra numbers after each block? ie block0000 FF then 0544 0D00 ??
Yes, I also noticed this but it's working ......
I'm using CSW Viewer release 38 and MakeUEF v2.3
Re: Kamikazi
Post by oss003 » Thu Feb 15, 2018 3:04 pm
Did you also try Charlie's ATM2WAV program?
Re: Kamikazi
