Saving Programmes on ATOM - current thinking - AtoMMC?
ghostrider
Post by ghostrider » Sun Dec 03, 2017 11:39 am
Hi All
Having successfully got my Atom rebooted after ~32 years in the box I've started to dabble with some programming.
In the old days I remember lots of messing around with cassette recorders, DIN plugs and volume levels - I am assuming that things have progressed since the mid-80s!
So can the guru's recommend what I should do to enable me to write than save/load programmes in a reliable and effective way? I've seen several references to AtoMMC board by sirmorris - is this what I need?
My soldering skills are somewhat limited so it has to be simple to fit.
Sorry if this is an idiot question but I've not been near the Atom for over 30 years.......Any advice gratefully received!
Gary
Re: Saving Programmes on ATOM - current thinking - AtoMMC?
Post by roland » Sun Dec 03, 2017 12:05 pm
Hi Gary,
Yes, the AtoMMC is what you need. sirMorris sells these as complete kit so no soldering is required. You need a ROM at #Axxx or #Exxx. If you want to enjoy your Atom to the max I also advise a good ramrom board.
Greetings, Roland
256K + 6502 Inside
Post by CMcDougall » Sun Dec 03, 2017 1:18 pm
Can just use a laptop to record to .WAV file, try a little prog first, then load it back in, if all is well, can type in big progs!
The problem BITD ~1981, people used rubbish blank tapes /mono players, so very unreliable due to price, but in the long run Only use TDK D tapes, as all my stuff still loads perfectly 8)
Post by IanS » Sun Dec 03, 2017 2:01 pm
roland wrote:Yes, the AtoMMC is what you need. sirMorris sells these as complete kit so no soldering is required.
You may need to solder in a header for PL8 (where the AtoMMC connects to the Atom PCB).
Post by roland » Sun Dec 03, 2017 2:38 pm
Technically speaking you are right but I have never seen an Atom without this connector. But yes, the connector can be lacking or even worse, mounted at the component side of the board.
256K + 6502 Inside
Post by hoglet » Sun Dec 03, 2017 2:50 pm
PL8 is fitted in the right place:
http://www.stardot.org.uk/forums/viewto ... 93#p187293
Post by roland » Sun Dec 03, 2017 3:54 pm
I knew it :lol:
256K + 6502 Inside
ghostrider
Post by ghostrider » Sun Dec 03, 2017 8:33 pm
Thanks All
So sounds like I need to wait for sirmorris to pitch up and offer me his wares........
Roland - what do you mean by "you need a ROM at #Axxx or #Exxx"? I only have the original ROM fitted (no FP or other aftermarket ROMs), do I need to buy something else and if so any suggestions as to where to get it from?
Thanks again
Gary
Post by roland » Sun Dec 03, 2017 10:15 pm
The AtoMMC is just the hardware to read and write the memory card. You also need a rom that has the software to communicate with the controller on the AtoMMC board. You can compare it with the DOS rom.
It is not that hard to get your Atom equipped. You just need a 2532 eprom with the AtoMMC rom in it. You can fit that in socket 24. You might solder a small link to have the rom automatically enabled afterva reset. And if you're getting that eprom, get two of them and install also the fp rom for socket 21.
I might be able to help you to get programmed eproms if you need some help.
There is a bit related reading at viewtopic.php?f=44&t=14098#p187478
256K + 6502 Inside
ghostrider
Post by ghostrider » Mon Dec 04, 2017 4:59 pm
Hi Roland
Thanks for all the info
I can confirm PL8 is there and ICs 21 and 24 are empty
Any help you can give sourcing the necessary programmed eproms would be much appreciated?
Thanks again
Gary
PS I'm based in London
Post by danielj » Mon Dec 04, 2017 5:01 pm
roland wrote:Technically speaking you are right but I have never seen an Atom without this connector. But yes, the connector can be lacking or even worse, mounted at the component side of the board.
Mine needed PL8 fitting! :)
Gary, when you order an AtomMMC from Charlie, he'll also send you an eprom with it :)
martinw
Post by martinw » Tue Dec 05, 2017 2:02 pm
A couple of the best things I've seen on my Atom :)
Courtesy of AtoMMC
Martin
