NTSC Colour board. :)
waltermixxx
Post by waltermixxx » Fri Dec 01, 2017 4:56 pm
Hi there,
If I understand correctly, the colour board for the Acorn Atom provides 2 functions:
Changes the frequency of the video out for 50Hz operation (from 60, as the 6847 in an ntsc chip), and combines the various other outputs of the MC6847 to produce a colour signal namely (I think):
CLK
0B
0A
HS
CB
Y
FS
INV
because I am in North America, and don't need to change the 60Hz portion, would a colour board be much simpler? Could I instead use something like this instead with little to no modification, (just a connector to PL4 and a couple of flying leads for the Y (composite video) signal? would I also need to change the 3.58 mhz crystal to a proper ntsc colour burst 3.579 crystal...? :)
this is the MC1372 used in the coco 2. :)
Re: NTSC Colour board. :)
Post by hoglet » Fri Dec 01, 2017 5:03 pm
Yes, much simpler colour boards are possible.
This is the simplest I could come up with, if you have a TV/Monitor with component-video inputs:
viewtopic.php?p=59728#p59728
And the MC1372 has been used on the Atom before:
viewtopic.php?p=142454#p142454
waltermixxx
Post by waltermixxx » Fri Dec 01, 2017 5:38 pm
thank you, I will look into those. :)
Cheers. :)
waltermixxx
Post by waltermixxx » Tue Dec 05, 2017 6:45 pm
Zippster, a guy in the U.S. builds lots of very cool projects for the Tandy Colour Computer.
I'm looking to purchase one of these from him, it's designed for the CoCo 2.
I just have to double check with him if the 1372 is included. :)
Post by hoglet » Tue Dec 05, 2017 6:54 pm
Is it this one?
https://sites.google.com/site/thezippst ... -the-coco2
I'll be interested to hear how well it works.
waltermixxx
Post by waltermixxx » Tue Dec 05, 2017 8:41 pm
its a newer version of it. it looks like...
:) I will let folks know how it works out.
I sent a note to Ed, (Zippster) and he confirmed the board does come with the MC6847 and MC1372.
I purchased the board and will update the thread and post pictures of the Atom when it arrives, with the colourboard and AtoMMC installed.
I will just have to reroute the ribbon cable from the video ram board to the Atom.
waltermixxx
Post by waltermixxx » Fri Dec 08, 2017 8:54 pm
A question about "snow or noise on the screen" when playing games, on a real Acorn Atom, with 6k of Video ram: will this happen in black and white as well as colour games? If I understand correctly the snow is from a timing issue caused when the cpu and the MC6847 are accessing video ram at the same time? The Acorn Atom i will be receiving has a single 6264 8k Ram chip for video ram, as shown above, will this configuration also produce noise on the graphics screens on the ATOM?
Post by hoglet » Fri Dec 08, 2017 8:58 pm
waltermixxx wrote: The Acorn Atom i will be receiving has a single 6264 8k Ram chip for video ram, as shown above, will this configuration also produce noise on the graphics screens on the ATOM?
In a word, yes. There are a couple of ways to avoid screen noise:
- run the CPU off the VDC clock (1.79MHz)
- add a noise killer / screen noise eliminator, see here
waltermixxx
Post by waltermixxx » Fri Dec 08, 2017 11:58 pm
thank you... :)
lots of good info in that document. :)
Cheers. :) the 74LS573 looks like a nice fit, along with the 74LS123. :)
i have lots of stuff to do to my atom:
32k RAM upgrade (deadbug on my 6502) 0000-7FFF and remove existing ram chips
(unless I get lucky enough to get on the list of folks who will receive a RAM/ROM board. :)
Install the ATOMMC and the eprom in #A000
Zippster Colour composite output (designed for COCO2)
Noise eliminator.
it's going to be a very good winter... :)
thanks everyone for your help thus far.
waltermixxx
Post by waltermixxx » Tue Dec 12, 2017 3:17 pm
Me again :)
I have a question, as you can see above, (scroll up a few posts to the picture of my Acorn Atom Motherboard.) i have 8k of ram connected in the "video ram" section of the Atom board. :)
I know that normally the MC6847 can use up to 6K of ram #8000-97FF. because there is 8k i suspect it goes from
#8000-9FFF. I suspect the ram from 9800 to 9FFF can be used for other things? Are there any programs that take advantage of the ram here? :)
just wondering really :)
Post by oss003 » Sun Feb 04, 2018 7:59 pm
waltermixxx wrote:Me again :)
No commercial programs are using this area but you can use it for your own programs.
The only problem is that screen noise will be generated is this area is accessed.
