YARRB [SOLD OUT]
Re: YARRB [SOLD OUT]
Post by roland » Thu Jun 13, 2019 9:47 pm
OK, that is settled then :D
256K + 6502 Inside
etaoin
Re: YARRB
Post by etaoin » Tue Jul 02, 2019 6:39 pm
Ok, almost working...
It is randomly switching graphic modes if I leave it alone. I'm sure I've seen that mentioned somewhere but can't find it right now. Something for tomorrow.
anightin
Post by anightin » Tue Jul 02, 2019 6:44 pm
Here are my settings:
JP3 on 1-2
JP4 on 1-2 (pin 1 is at the CPLD side).
JP5 and P5 closed
P4 and P6 open
I notice you have JP5 open?
Best
Andy
etaoin
Post by etaoin » Tue Jul 02, 2019 6:51 pm
No, JP5 is jumpered. P5 is open but that has been pulled up as suggested by Roland in his mods list.
anightin
Post by anightin » Tue Jul 02, 2019 6:53 pm
Apologies, meant type P5 :oops:
To prevent writing to the EEPROM you can remove P5. But then you have to add a 4k7 resistor between the pins 31 and 32 of the EEPROM socket otherwise the EEPROM might not be readable (this is a design flaw in the board, this resistor should have been there).
Got it.
Re: YARRB
Post by roland » Tue Jul 02, 2019 11:29 pm
On the previous page, Sirmorris had solved this issue by replacing the 8255 and the chips in the clock circuit. If you have spares, this is worth a try. If you need a 8255 to test, just let me know.
256K + 6502 Inside
etaoin
Post by etaoin » Wed Jul 03, 2019 11:54 am
Yes, what he observed seems very similar. I'll first replace the sockets around the clock, as they're crap anyway. The 8255 already has a new socket and I think isn't the original 8255 anyway (it's a NEC chip). I've used lots of 8255's for DIY stuff ages ago so I probably pulled the original at some point and replaced it later. I probably have one or two (used) spares.
etaoin
Post by etaoin » Thu Jul 04, 2019 7:15 am
Quick question: is the duty cycle of the 4 MHz clock expected to be way off 50%? Does the CPLD care anyway?
etaoin
Post by etaoin » Thu Jul 04, 2019 7:21 am
Sorry, I'm being stupid. My 12 MHz sample rate will skew the duty cycle.
