ICE T65/Z80/6809
Re: ICE T65/Z80/6809
Post by hoglet »
cyberbarter wrote:
Sun Sep 26, 2021 2:05 am
Do you take donations. I very much would like to reward you for your efforts.
I've sent you a PM.
I hope you manage to get your 6502 ICE working.
What host machine will you be using it with?
Please continue to ask questions in this thread if you need help.
cyberbarter
Post by cyberbarter »
Hi ICE friends.
I am having issues with a Pi4B. I have a Pi1B working fine so this is not a high priority for me. It is all about the journey.
OpenOCD Failures programming EEPIZZA FPGA on Pi4B
Note:I have no problems running any of the below on a Pi1B using either the frame_buffer.bit .bin files or the iceT6502.bit .bin files
Pi4B Info:
(I'm using 2020-02-13-raspbian-buster-full.img) on a Pi4B
I downloaded the 32bit Oi OS version from: https://downloads.raspberrypi.org/raspb ... 020-02-14/
I am running OpenOCD 0.10.0-5
sudo apt-get update
sudo apt-get install openocd=0.10.0-5
My local.cfg file contains:
interface bcm2835gpio
bcm2835gpio_trst_num 7
adapter_khz 200
I made changes to /usr/share/openocd/scripts/interface/raspberrypi-native.cfg
bcm2835gpio_peripheral_base 0xFE000000
bcm2835gpio_speed_coeffs 236181 60
My Bscan file is from:
wget https://github.com/quartiq/bscan_spi_bi ... c6slx9.bit
Pi1B .bit file Success example:
When I program the .bit file into the FPGA “ram” using the Pi1B, the EEPIZZA reboots and only the yellow LD10 DONE and blue LD9 PWR LEDs are lit. Everything looks fine.
Here is the output for the Pi1B
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
BCM2835 GPIO config: trst = 7
adapter speed: 250 kHz
Warn : Interface already configured, ignoring
BCM2835 GPIO config: tck = 11, tms = 25, tdi = 10, tdo = 9
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
xc6s_print_dna
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : JTAG only mode enabled (specify swclk and swdio gpio to add SWD mode)
Info : clock speed 250 kHz
Info : JTAG tap: xc6s.tap tap/device found: 0x24001093 (mfg: 0x049 (Xilinx), part: 0x4001, ver: 0x2)
Warn : gdb services need one or more targets defined
loaded file frame_buffer.bit to pld device 0 in 11s 536903us
Pi4B .bit file failure example:
When I program the .bit file into the FPGA “ram” using the Pi4B, the EEPIZZA does not seem to reboot and only the blue LD9 PWR and blue LD1-LD8 LEDs are lit. No yellow LD10 DONE LED is lit.
Here is the output for the RP4B
NOTE: There is a considerable time difference loading the .bit file to the pld device between the Pi1B and the Pi4B and this could be indicative of some timing issue.
pi@raspberrypi4B:~ $ sudo openocd -f local.cfg -f /usr/share/openocd/scripts/interface/raspberrypi-native.cfg -f /usr/share/openocd/scripts/cpld/xilinx-xc6s.cfg -c "init; xc6s_program xc6s.tap; pld load 0 frame_buffer.bit; exit"
adapter speed: 200 kHz
xc6s_print_dna
Info : clock speed 200 kHz
loaded file frame_buffer.bit to pld device 0 in 4s 947634us
Pi4B .bin file failure example 1: Error: Unknown flash device (ID 0x00000000)
Most of the time when I attempt to program the .bin file into the FPGA “FLASH” using the Pi4B, the EEPIZZA I get the Error: Unknown flash device (ID 0x00000000)
Here is the output for the Pi4B
pi@raspberrypi4B:~ $ sudo openocd -f local.cfg -f /usr/share/openocd/scripts/interface/raspberrypi-native.cfg -f /usr/share/openocd/scripts/cpld/xilinx-xc6s.cfg -f /usr/share/openocd/scripts/cpld/jtagspi.cfg -c "init; jtagspi_init 0 bscan_spi_xc6slx9.bit; jtagspi_program frame_buffer.bin 0; xc6s_program xc6s.tap; shutdown"
xc6s_print_dna
jtagspi_program
loaded file bscan_spi_xc6slx9.bit to pld device 0 in 2s 440935us
Pi4B .bin file failure example 2: contents differ diff 0 address 0x00000100. Was 0xff instead of 0x00
Occasionally/intermittently when I attempt to program the .bin file into the FPGA “FLASH” using the Pi4B, I get the contents differ diff 0 address 0x00000100. Was 0xff instead of 0x00
Note: below diff errors 1-126 removed for clarity
xc6s_print_dna
jtagspi_program
loaded file bscan_spi_xc6slx9.bit to pld device 0 in 3s 2009us
Info : Found flash device 'win w25q32fv' (ID 0x001640ef)
flash 'jtagspi' found at 0x00000000
auto erase enabled
Info : sector 0 took 862 ms
Info : sector 1 took 108 ms
Info : sector 2 took 108 ms
Info : sector 3 took 128 ms
Info : sector 4 took 120 ms
Info : sector 5 took 106 ms
wrote 393216 bytes from file frame_buffer.bin in 117.956841s (3.255 KiB/s)
read 340604 bytes from file frame_buffer.bin and flash bank 0 at offset 0x00000000 in 8.422829s (39.490 KiB/s)
contents differ
diff 127 address 0x0000017f. Was 0xff instead of 0x00
I saw a thread somewhere that the new Pi4B GPIO lines have configurable Pull Ups. I need to research this and determine if this might be causing SPI transfer issues. I think this boils down to something being different on the Pi4B BCM2711 architecture and the Pi1B.
Any help would be most appreciated.
cyberbarter
Post by hoglet »
cyberbarter wrote:
Mon Sep 27, 2021 6:18 pm
I made a couple of comments in this section about the Pi4:
https://github.com/hoglet67/Beeb1MHzBus ... -pi-models
Did you modify these lines in raspberrypi-native.cfg?
I haven't tried using a Pi4 myself.
cyberbarter
hoglet wrote:
Mon Sep 27, 2021 6:45 pm
I did make those changes and I updated my post to include that bit of missing information. Thanks for the catch. Would it be helpful if I ran this issue by the OpenOCD forums?
Post by hoglet »
cyberbarter wrote:
Mon Sep 27, 2021 6:57 pm
Yes, I expect they would be better qualified over there to advise you.
I'm very much a novice user of OpenOCD!
cyberbarter
hoglet wrote:
Mon Sep 27, 2021 7:00 pm
Hi Dave. I am in the same boat. This is my first exposer to OpenOCD. I will post an update if and when the OpenOCD forums help with a fix. As always, thanks for your assistance.
cyberbarter
cyberbarter wrote:
Mon Sep 27, 2021 7:17 pm
Hi Dave. I am in the same boat. This is my first exposer to OpenOCD. I will post a update if and when the OpenOCD forums help with a fix. As always, thanks for your assistance.
I did get a Pi1B AND Pi4B to program the EEPIZZA using OoenOCD with the ice6502.bin and ice6502.bit files.
Both of the Pi1B and Pi4B are running the same OS and OpenOCD.
OpenOCD = 0.10.0-5
PiOS = 32bit version 2020-02-13-raspibian-buster-full
The OpenOCD forums and Google searches turned up nothing.
I decided to scope the JTAG pins. I found that the Pi1B TCK was running at ~250 Khz as configured in local.cfg
adapter driver bcm2835gpio
adapter speed 250
The Pi4B TCK was running at ~416 Khz with the adapter speed set to 200 in the local.cfg
I changed the local.cfg adapter speed = 100 on the Pi4B and the EEPIZZA could be flashed consistently without errors although is was slow.
adapter speed 100
I am going to research the /usr/share/openocd/scripts/interface/raspberrypi-native.cfg
file for the Pi4B specifics.
I am going to see if I can find some detail on the speed coeffs definitions as I have a gut feeling that maybe this might be part of the problem.
Also attached is a word doc with some additional information. Please share if you would like.
Thanks for everyone's help on this issue.
Cyberbarter
Programming ice6502 on the EEPIZZA FPGA Board using OpenOCD 0.10.0-5 using a Pi4B 32bit OS.docx
(24.89 KiB) Downloaded 3 times
Post by hoglet »
Thanks for the update Cyberbarter.
It does look like bcm2835gpio_speed_coeffs values depend on the ARM clock:
# Transition delay calculation: SPEED_COEFF/khz - SPEED_OFFSET
# These depend on system clock, calibrated for stock 700MHz
# bcm2835gpio_speed SPEED_COEFF SPEED_OFFSET
bcm2835gpio_speed_coeffs 146203 36
There are some more examples here, some determined experimentally:
https://github.com/bunnie/netv2mvp-scri ... de.cfg#L23
bluearcus
Re: ICE T65/Z80/6809 -
Post by bluearcus »
I'm trying to make up an eepizza 6809 level shifter board... but notice that the single line tri-state level shifters in the BOM are OOS everywhere in the UK and have very long lead times...
Can anyone suggest some alternative part options that have stock?
Kind regards,
Mike
Post by hoglet »
bluearcus wrote:
Sun Oct 24, 2021 1:40 pm
Do you mean the SN74LV1T125DBVR parts?
These are actually not critical and can be omitted.
The Wiki says this:
If you struggle to solder fine-pitch parts, the three 74LVT125 devices (U7-9) can be omitted. You will loose two features:
- the external trigger capability (which allows a breakpoint to be qualified by a function of two external signals)
- the TSC capability (a RnW cannot now be tristated).
If you really need those features NOW you could risk ebay; there are some showing there (in China).
I'm not aware of any alternatives with the same pinout and voltage thresholds.
