Interfacing an Atom to a Raspberry Pi Pico
Prime
Re: Interfacing an Atom to a Raspberry Pi Pico
Post by Prime »
Am I correct in assuming that Lower case on the Atom should replace the black text on green characters with the lower case green text on black?
Might need to do some twiddling as the Dragon would want to replace the green on black with the lower case black on green.....
Basically what the two machines considder "inverse" is inverted :)
Phill.
cjm
Post by cjm »
Prime wrote:
Fri Jun 04, 2021 4:44 pm
As far as I know the Atom never had lower case. But lower case green text on black was a deliberate choice - maybe the GODIL version does something different?
Basically what the two machines consider "inverse" is inverted :)
So normal on a dragon is black text on green?! :shock:
Chris
Atom + YARRB + Noise Killer + HDMI adapter + Homebrew RPi-MMC AtoMMC V4
Post by roland »
Upper case on the Atom is green (or white, depending on your monitor) on a black background. Lower case is black on a green (white) background.
The Godil can use different character sets, some of them have real lower case characters.
