Crystal replacement
sirmorris
Crystal replacement
Post by sirmorris » Sat May 23, 2020 11:18 am
Hi all,
A crystal on my issue 3 is huge. ENORMOUS. I'd like to replace it with something a little more discreet. Well both actually. In case I come to fit a RAMROM.
From my readings there are parallel and series cut crystals. They have different use cases. Referencing the Atom schematic it looks as if I should probably select a series cut. I tried a parts bin 4mhz low profile crystal when I was starting my resurrection I couldn't get the clock to start until I strapped a couple of 12pf caps from ground to the crystal's pins. Even then it was intermittent. Is there a difference between the big-can crystals and their low profile equivalents? Do they, for example, have the caps already integrated? Does anyone have any advice for swapping out the crystals for modern equivalents?
C
Prime
Re: Crystal replacement
Post by Prime » Sat May 23, 2020 11:31 am
I've used low profile ones for both the 4MHz and the 3.57MHz ones on a couple of my Atoms, I pretty much supply a low profile 4MHz with a RAMROM these days as even the reasonable sized normal crystal will foul with it.
Phill.
oss003
Post by oss003 » Sat May 23, 2020 11:45 am
Or locate the crystal on the other side of the mainboard ... if it fits there.
Greetings
Kees
Post by 1024MAK » Sat May 23, 2020 12:30 pm
Different crystals may need different loading capacitors.
Try with a new crystal from a mainstream supplier (so you can look up the actual spec and data).
anightin
Post by anightin » Sat May 23, 2020 12:44 pm
Phill.
Have low profile crystals in my Atoms now (since mid last year) and quite necessary to save space as Phill says :)
I guess I got lucky when picking some from eBay, I remember the 4MHZ one was 49HCS
Post by Kazzie » Sat May 23, 2020 2:04 pm
HC-49/S will be a description of the physical package size. (Non-low profile ones would be HC-49/U or HC-49. I think the huge ones as pictured in the first photo may be HC-51.)
