FPGAtom 64 colour
Re: FPGAtom 64 colour
Post by hoglet » Sat Dec 14, 2019 3:22 pm
roland wrote:
Sat Dec 14, 2019 3:13 pm
I agree, as I was struggling to find the right colours for my demo. Feel free to adjust and correct my code :)
OK, one more update pushed to the palette branch making these changes:
https://github.com/hoglet67/AtomFpga/commit/a79714ff
Also, I just remembered the GODIL has an 8-colour text mode (using the 6847 Semi-graphics 4 mode, which is normally inaccessible on the Atom).
If you load the COLOUR TEST 1 program from the archive and add:
5 ?#BDE0=1
you should see a few more colours on the screen.
oss003
Post by oss003 » Sat Dec 14, 2019 5:25 pm
Or Galaforce with a black background and Chuckie Egg in the right colours .....
Greetings
Kees
Post by hoglet » Sat Dec 14, 2019 6:18 pm
For Chuckie Egg you need:
B=#B010;?B=#30;B?1=#30;B?6=#00;B?8=#CC
*MENU
And you get this:
(The pink looks purple in real life!)
You could get the same effect on a real Atom with RGBtoHDMI, as that also allows the Palette to be redefined.
oss003
Post by oss003 » Sat Dec 14, 2019 9:15 pm
Nice ....... =D>
Greetings
Kees
Post by roland » Sun Dec 15, 2019 2:02 pm
This looks really great :D
I only get a vertical green line on the left of my screen. I can remove it by shifting the screen two pixels to the left in my monitor settings :mrgreen:
How do you set that up? Is that with the three buttons? I didn't build that board yet (I ran out of Pi Zero's :) )
Post by hoglet » Sun Dec 15, 2019 2:20 pm
That's an interesting question....
There is a choice of built-in palettes, but these are hard-coded in the Pi software, so it requires some C tweaking and a recompile to add a new one.
IanB also added a "in-band palette" control channel to the Pi capture code, so in theory you can reprogram the palette by flashing up the right pixel pattern on the display for one frame.
I'm at a loose end this afternoon, so let me look into what's possible from the Atom.
Post by hoglet » Sun Dec 15, 2019 2:21 pm
Oh, and shall I merge the AtomFpga palette branch back into dev?
Post by roland » Tue Dec 17, 2019 4:15 pm
I think there is a small change in the colour palette to improve interoperability and compatibility with the normal Atom: changing the addresses of the registers.
I had picked #B01x because some other video controls are at #B00x so it seems logical to put the registers near that block. But writing to the palette registers will influence the settings of the 8255 on a normal Atom. So after all, #B01x is a bad idea. Moving the registers to an address range near the Godil address block (which is also logical) will not interfere with the Atom's addresses. Writing to a palette register is simply ignored (or useless) on a normal Atom but the programs will still work, albeit with a different colour set.
Post by roland » Sat Jan 04, 2020 9:00 pm
@Hoglet: did you already have a look to change the palette registers addresses ?
I also have another great idea: the Atom2k15 and other Godil based Atoms do not support 64 colours but the mapping of the four logical colours to four out of eight is still possible. That would make games like Chucky Egg and so to look more realistic. Also future games and programs can benefit from a configurable palette. For that purpose the registers will also have to be moved to another address space.
I know it is possible but I have no idea how to modify the VHDL of the Godil in a way it is still compatible with the FPGA based Atoms. Can you have a look at this when you have a bit spare time? As usual, no hurry.... :wink:
Post by hoglet » Sun Jan 12, 2020 7:45 pm
Sorry Roland, I overlooked this request.
Anyway, it's done now.
I chose #BD00 -#BD0F, as this is at the start of the 256b "GODIL" address space.
I've also just merged all the palette work back to the master branch.
That is a nice idea :D
Just like AtomFpga_Atom2K18.vhd is specific to Atom 2K18 (and not used in any other builds), the same is true of TopRoland.vhd in AtomGodilVideo. i.e. this is only used on Atom2K15.
So this would be a sensible place to implement a similar palette. It could even use the same address range, and a compatible data format (just ignoring the output bits for R0 and B0). The implementation could probably just be borrowed from AtomFpga_Atom2K18.vhd.
In fact, I just had to have a go at this.
It really was mostly just cut-and-paste with a few signal names changed:
https://github.com/hoglet67/AtomGodilVi ... d0eeea?w=1
There's a new .bit file checked in to the root directory (TopRoland.bit)
https://github.com/hoglet67/AtomGodilVi ... Roland.bit
It seems to work, though I have not extensively tested it.
P.S. After having done this, I did wonder whether we should have implemented the palette in AtomGodilVideo all along. Then it would be available to all of the derivative works.
Post by roland » Sun Jan 12, 2020 8:00 pm
Thank you. I will update my FPGA next weekend .... I'm quite busy this week.
I will update my Atom2k15 and test it also.
I think that is because Kees came up with the idea when I started to design the Atom 2k18. He asked to add a few extra outputs so we could use 4-out-of-64 colours. Anyway ... I have something to look forward this week :lol:
fordp
Post by fordp » Mon Jan 13, 2020 1:46 pm
I have a recollection that two bits per colour was my idea. I must admit is was more intended for BBC B and Master running on this board!
FordP (Simon Ellwood)
Post by roland » Mon Jan 13, 2020 2:31 pm
I don't really know who came up first with the idea .... I only saw it here: viewtopic.php?f=44&t=15197&start=60#p229031
However, perhaps Kees based this post on your idea. When did you post it ... then an independent Judge (Beeb) can give a verdict who was the first one with this idea and get all the credits :lol:
Post by hoglet » Mon Jan 13, 2020 3:37 pm
A little bit of history...
The current version of Atom FPGA was started by Alan Daly in 2009. It used an Olimex Mod VGA board:
https://www.olimex.com/Products/Modules ... e-hardware
The Olimex board was designed as an open source implementation of the GameDuino FPGA-based graphics card. It uses a standard VGA connector, and allows 3-bits of Red, Green and Blue (so 9 bits in total).
Because of this, Alan's design used three bit colours.
https://github.com/hoglet67/AtomFpga/bl ... ic_top.vhd
The current AtomFpga_Core is a direct descendent of this, and has carried forward the idea of using 3-bit colour values internally:
https://github.com/hoglet67/AtomFpga/bl ... a_Core.vhd
Each FPGA Board wrapper then maps these 3-bit colour values to whatever the FPGA Board actually supports.
So I would say the idea of an Atom with multi-bit RGB at least dates back to Alan's work.
In fact, it likely goes back even further than this.
The earliest Atom FPGA implementation I'm aware of was created by Keith Howell, who is no longer active in the retro scene (as far as I'm aware). He called this "the PolyMorph" because the same hardware could imlement several machines.
His Atom design was never published, but it did exist, and it's well documented here:
http://members.casema.nl/hhaydn/howel/l ... roject.htm
This actually had a programmable palette (in the FPGA) and used three TDA8702 8-bit video DACs.
Keith did this in ~2003
Archive.org has some captures of his original website:
https://web.archive.org/web/*/http://ww ... roject.htm
So the earliest mention of a Atom with a programmable palette is Feb 3rd 2004.
Edit: Or is it....
Here's an article from 1994 written by Roland:
http://www.acornatom.nl/atom_nieuws/199 ... 942035.htm
As far as I can see, this this is giving an Atom (in PC) a palette with 2-bit RGB (64 colour) using PC's the EGA/VGA card.
Post by roland » Mon Jan 13, 2020 4:47 pm
Cool that you have found this article :lol: It's good that you teach us a lesson in history. The Judge can use this in his judgement :mrgreen:
Post by roland » Mon Jan 13, 2020 10:25 pm
I couldn't wait until next weekend and this evening I had a little spare time so I updated my three Atoms. It works fine; I could not find any errors or misbehaviour.
Can you and Kees work out a way to start Chuckie Egg, and maybe other games, in another colour setting? That can be achieved in the sources (so Kees has to modify them a little bit) or by adding a pre-loader that sets the correct colour before starting the game, which requires a change in the menu.
A very versatile way is to add a small colour.cfg file in each directory where you want to change the colours and the menu should look for this file. If it exists it loads those data directly into #BD00 and then starts the game. That way everybody can assign a favourite colour set to every game.
Post by hoglet » Mon Jan 13, 2020 10:40 pm
Glad it's all working for you - I didn't actually do much testing.
People may not have the same definition of "Correct"..
Instead of modifying each game, a simpler way might be to just write a "Palette Manager" program that supports:
- loading of palettes
- editing of palettes
- saving of palettes
- re-loading the menu without pressing break
BTW, the Chuckie Egg palette is:
P=#BD00;?P=#30;P?1=#30;P?6=#00;P?8=#CC
*MENU
Post by roland » Tue Jan 14, 2020 10:04 pm
Maybe "Correct" is not the correct word; preferred or favourite might be better.
I don't understand the last feature. Does that mean you have to reload the palette every time before you run a game? IMHO it is easier to write the colours to colour.cfg in the game's directory and load that before loading and starting the game. That way you don't need to modify the game itself and switching colours is automatically executed.
