How many sold? German tank problem:serial nums wtd
Re: How many Beebs sold? - German tank problem
That top image looks like the same serial number sticker I've got in my original Beeb from '83. Mine's an Astec AFAIK...
One other bit of information - my electron which has the product code 02-ALA01 has a label inside which says "Made in Hong Kong". The 02-ALA01 electrons don't have this.
- SarahWalker
I believe 02 is Wong Electronics. 01 is probably Astec.
@jms2: my Beeb is 3935 down the line from yours! The serial number sticker has fallen off and been reattached, no doubt the same has happened with your sticker.
I'd be interested to see the date stamp on the motherboard if you ever lift the WE ROM board.
I've got:
03ANB01 3054325. Date stamp: 11 MAY 1984, B.548 DI
I have previously observed:
03ANB01 3066404. Date stamp: 2 JUL 1984, B.574 nS
Interestingly the dates are 52 days apart, but the B. numbers differ by 26. If a "B." occurs every two days then B.1 would have happened on 13 May 1981... B.100 was due on 27 November that year, still very early. (courtesy of timeanddate.com)
However if the B number is incremented once per day then B.100 would fall on 18 February 1983, about a month after the date on the Issue 7 diagram, although we are now clearly grasping at straws!
Greg
I've got:
Greg
Mine's a BBC Model A.
Identical orange stickers on the motherboard and the underside say ICL SERIAL No 005416.
Printed on the motherboard:
Copyright 1981 203,000 Issue 3
Acorn Computers Ltd
Scribbled on top of that is GS 23.9.83, in permanent marker.
I can't see much else, 05042 on the keyboard, 6156 on the WE DDFS ROM (in biro)
Acorn Computers Ltd
- SarahWalker
Okay, interest on this seems to have died down, so I'll post some 'final' numbers. Unless anyone else has anything else to contribute?
Estimates I'm reasonable certain of :
Electron - 315,068
Electron Plus 1 - 19,899
Electron Plus 3 - 10,012
Master 128 - 283,609
Master Compact - 39,238
Archimedes 310 - 21,056
Archimedes A410/1 - 10,466
Estimates I'm not so certain of (not enough samples, or not varied enough) :
BBC A/B - 551,427
of which :
- ANx01 - 459,119
- ANB02 - 1,071 (only one sample)
- ANB03 - 80,456
- ANB04 - 10,781 (only one sample)
At the least I suspect there are a lot more ANB02's (Econet but no disc, should have been pretty common for school machines?).
A3000 - 146,068 (only one sample of 25-AKB01, rest are 01-AKB01. No special access or Learning Curve machines seen)
A3020 - 104,152 (models not seen)
RiscPC 600 - 26,589 (lots of models not seen)
RiscPC 700 - 3,084 (lots of models not seen)
StrongARM RiscPC - 2,933 (lots of models not seen)
Estimates that are complete guesses (only one or two sample, or one sample of several models) or where parts of serial numbers are uncertain :
German BBC B - 1,885 (only 1 sample)
US BBC B - 20,396 (only 2 samples)
BBC B+ 64K - 17,711 or 37,711
BBC B+ 128K - 6,817 (only 2 samples)
Master ET - 4,403 (only 2 samples)
Archimedes 305 - 4,105 (only 1 sample)
Archimedes 420/1 - 189 (only 1 sample)
Archimedes 440 - 713 (only 1 sample)
Archimedes 440/1 - 4,308 (only 2 samples, from different production lines)
Archimedes A540 - 1,584 (only 2 samples)
A3010 - 59,813 or 19,813 (lots of models not seen, only 1 each)
A4 - 2,269 (only 1 sample)
A5000 - 12,005 (only 1 sample of 3 different models)
A7000 - 14,030 (lots of models not seen, only 1 each)
A7000+ - 4,144 (lots of models not seen, only 1 each)
R260 - 3,453 (only 2 samples)
Electron - 315,068
BBC A/B - 551,427
of which :
- ANx01 - 459,119
- ANB03 - 80,456
A lot of the Masters in my school were Master ETs - i.e. didn't have much fitted and were just basic Econet Terminals. No idea how they'd fit in with your number crunching. I haven't seen one since I left ...
Sam.
Sam.
- SarahWalker
Left the ET out by mistake, now fixed. Only got 2 serial numbers though, both of which are suprisingly low.
Damn, meant to add these a few weeks ago
BBC B
03ANB01 3060030
BBC Master
01AMB15 0101673
BBC Master
01AMB15 0042713
BBC B
03ANB01 3060030
BBC Master
01AMB15 0101673
BBC Master
01AMB15 0042713
Alex
Back up to 1 Beeb again. \o/
Oops, i've been meaning to contribute mine too...
ICL-027041 (issue 3)
07-ANB01-3770516 (no mainboard!)
07-ANB03-5004816 (issue 7)
08-ANB04-6025023 (issue 7)
- 1024MAK
Here's my updated list with some more serial numbers
(that includes the ones that I missed out from the first list
Mark K.
Mark K.
- Attachments
- Acorn Serial numbers 2.zip
- (2.85 KiB) Downloaded 142 times
Had to do some rearranging of things anyway, so...
6502 Second Processors 03-ANC01
1003516
1008837
1009954
Master 128 01-AMB15
0014336
0017440
0021079
0084091
0092398
0106274
0146614
0260546 (Cherry keyboard)
Master Compact Keyboard: 27-ADB10-0111164
Master Compact PSU: 12-ADD04-3005736
1003516
1008837
1009954
Master 128 01-AMB15
0014336
0017440
0021079
0084091
0092398
0106274
0146614
I'm beginning to think that this question is one which could be potentially be on-going. We could make this a sticky topic in the Community Projects forum and I could add a link to it in the welcome email that I send out to any new people who register asking them to post the serial numbers of any kit they have.
Sam.
Sam.
Good call that man!
Alex
Re: How many sold? German tank problem:serial nums wtd
Ebay furnished me with this one, its in one of the photos
Master Compact Keyboard: 27-ADB10-0128936
- SarahWalker
Since this thread is now sticky, I've decided to put all current totals in the first post, which will be updated as and when necessary.
Ebay seller has another one, same deal different number.
Master Compact Keyboard: 27-ADB10-0119704
edit: also from the bottom of my A440/1
A410/1 - 27-AKB40-1004231
edit2: from another ebay photo
1009904
1009904
Hi
This is short & sweet:
Electron 06-ALA01-0073925
Electron 07-ALA01-0113437
Regards
Deacon
Regards
Deacon
I'll have a go at contributing to this endeavor too.
I recently picked up a B+ 128k system, after 20 minutes of playing about the PSU did the crackling smokey thing, so I've picked up a couple of X2s to sort this out. When I'm done, expect a few questions to appear elsewhere in the forums, thanks ;o) Pulled out our original Beeb and the spares machine for the same treatment, so while conviently at hand out of the packaging here are some numbers.
The B+ : 01-ANB53-5505469
The beebs :
(iss. 3) 010169 (sticker is an orange one with the legend "ICL Serial No", also has other short-comings, but this is the spares box)
(iss. 4) 02-B01-203338
Hope this will be of use to you.
The beebs :
Serials from my collection:
BBC A cleartone 102432
BBC A 001013
BBC A RACE ANA01-319474
BBC B AB Electronic Systems 113318
BBC B ICL 027418
BBC B AB Electronic 182834
BBC B 01-ANB03 5047337
BBC B ICL 008193
BBC B 02-B01-222619
BBC B 02-UNB09-1009723 (US)
BBC B 02-UNB09-1007888 (US)
BBC B 02-GNB14-1000943 (German)
BBC B SCL 7502 (Indian)
BBC B+ 01-ANB53-5518856
BBC B+ 01-ANB55-7504361
BBC B+ 01-ANB55-7504545
Electron 07-ALA01-0076881
Electron 06-ALA01-0028986
Electron 06-ALA01-0035669
Electron 07-GLA01-1012560 (German)
Master 01-ADB12-0102936 (ET)
Master 01-AMB15-0183926
Master 01-AMB15-0143103
Master 01-AMB15-0026371 (512)
Master 01-AMB15-0226490
Master 01-AMB15-0249307
Master Compact 27-ADB10-0106477/25-ADD04-1026719
Master Compact 07-ADB10-1004201/25-ADD04-1032699
Master Compact 27-ADD10-0122032/25-ADD04-1014946
Communicator 25-AFB11-1000029 (Italian)
A500 46
A500 222
A500 104
A310 27-AKB15-1015793
A310 27-AKB15-1002806
A440 27-AKB20-1000357
A680 01-A680B-0000147
A410/1 27-AKB40-1000464
A410/1 27-AKB40-1000943
A420/1 27-AKB46-10011228
A420/1 27-AKB44-1000095
A440/1 27-AKB40-1007658
R260 01-UNX26-1000012
R260 01-UNX26-1002301
A3000 01-AKB01-1093164
A3000 01-AKB01-1086052
A540 01-AKB50-0001035
A540 01-AKB50-0001057
A5000 25-ALB12-1004198
A5000 25-ALB32-1010157
A4000 25-AGC40-1010328
A4000 01-AGC20-1022788
A4000S 93-AGC50-1016486
A4 92-AKB64-1010429
A4 01-AKB64-1012105
A4 01-AKB64-1011135
A3010 01-AGB11-1016983
A3010 01-ALC15-0005713
A3010 93-AGB40-1010365
A3020 93-AGB23-1021544
A3020 93-AGB22-1047893
RiscPC600 72-ACB25-1015512
RiscPC600 72 ACB25-1016451
RiscPC700 72-ACB76-1010012
RiscPC700 72-ACB76-1011765
RiscPC700 72-ACB75B-1010116
RiscPC 700 72-ACB76-1011715
StrongARM RiscPC 80-SRP26-1170062
StrongARM RiscPC 80-SRP26-1170557
A7000 80-AMC23-1014337
A7000+ 80-AMC10-1010281
Music 500 03-ANV-02-0104578
6502 2nd Procesor ANC01-1003860
Z80 2nd processor 04-ANC04-105415
Hope they help a bit and don't spoil your calculations
Chris
BBC A 001013
BBC B ICL 027418
BBC B ICL 008193
BBC B 02-B01-222619
A500 46
A500 222
A500 104
A4 92-AKB64-1010429
A4 01-AKB64-1012105
A4 01-AKB64-1011135
Chris
A couple more for the list in my spare room
A3020 93-AGB22-1028340
BBC B 161103 (AB Electronic Systems Ltd) -Issue 7
Two more for the pot
A partial
21 ANB01
and a full
01 ANB03 5045789
A partial
21 ANB01
and a full
01 ANB03 5045789
Electron 07-ALA01-0 029497 (assembled in the UK)
Electron 02-ALA01-0 002001 (assembled in Hong Kong)
- richardtoohey
No BBC stuff (I'm looking!) but ..
A3010 25-AGB11-1016179
RPC-600 72-ACB25-1026272
I will post the serial number for my kit as soon as it arrives. I bought a Master 128 and 2nd processor.
Just got my Master 128
The Serial number is: 01-AMB15-0045652
Bill
Bill
Just though I'd better add mine...
BBC B issue 7
01-ANB03-5053074
BBC B issue 7
01-ANB03-5053074
Now that I have the A5K somewhere other than an attic:
25-ALB12-1007475
Ok - new on here so will try not to show myself up too badly
Just bought the following
MASTER - 01-AMB15-0026692
6502 Second processor - 03 ANC01 -1007293
MODEL B - 01-ANBO3-5053160 (Says issue 7 on MB but questionable contents)
MASTER looks ok from outside - yet to take a peek inside. MODEL B can't seem to compare with examples I've seen while researching - but thats another thread for tomorrow.
Hope these help
Hope these help
Hello! I'm a new member as of today!
I'm looking to refurb my Dad's old BBC to get it going again. It's an (early?) Issue 3 BBC B, with an ICL serial no:
ICL 007957
PSU (unfortunately dead) is dated 82-08.
It still has a BASIC A ROM (with the 1981 Copyright). I think it had an OS ROM upgrade at some point.
Marc
ICL 007957
Marc
