Page 1 of 1
Provisional STL DDFS 2.0 User Manual
Posted: Sat Aug 26, 2017 5:07 pm
by SimonSideburns
I have painstakingly scanned in the above named document.
I have also manually typed it back in (which was always going to be quicker than trying to use OCR) along with most of the errors.
I'll leave it up to the viewer to correct anything found (if they wish).
I'm happy to attach both the PDF and TXT files.
Re: Provisional STL DDFS 2.0 User Manual
Posted: Sat Aug 26, 2017 6:37 pm
by flaxcottage
Thanks. I think I have one of these with a spare model B motherboard. The manual will come in very useful when I try to get the DDFS working. =D>
Posted: Mon Aug 28, 2017 2:13 pm
by jgharston
SimonSideburns wrote:I have also manually typed it back in (...) along with most of the errors.
Argh. So.... want... to.... correct those errors. ;)
Posted: Tue Aug 29, 2017 11:28 am
by SimonSideburns
It would be so interesting to see what changed between this provisional manual and the actual one that was sent out. I touch type and had to make my fingers follow what was written as normally I would have corrected as I went along. I did spot several issues, even with the BASIC listings that had been provided.
Anyone have one?
Posted: Tue Aug 29, 2017 5:32 pm
by CMcDougall
maybe you could post pics of what you have, to trigger someone elses mind....
I have one (or2?) up loft at mo, but sure are just pink, like the ones on eBay at mo:
Posted: Mon Aug 27, 2018 9:26 pm
by SimonSideburns
Only just seen this reply. Mine are a few A4 pages of typed notes that look very much like a draft copy.
I will find them and take a picture soon.
Posted: Tue Aug 28, 2018 9:43 pm
by tricky
I have the DDFS2.0 ROM in my beeb from BITD, I had a green manual, but can't find it - I have not thrown it away.
Posted: Sun Sep 02, 2018 10:00 pm
by Coeus
I did discover the full set of manuals a while back, though I think these are the published rather than provisional versions. I have at least DDFS, ADFS and Sideways RAM IIRC. I did offer to scan them but I think it turned out scanned images are already available.
Posted: Sun Sep 30, 2018 12:24 pm
by marcusjambler
These are what I have :
Marcus
