New Advanced User Guide (NAUG) [Remastered PDF]
- TobyLobster
- Contact:
Re: New Advanced User Guide (NAUG) [Remastered PDF]
The smallest of all possible errors: p129 section 8.6 refers to "IRQV2", but everywhere else this is called "IRQ2V"
Thanks. This will be corrected in the next release.TobyLobster wrote: ↑Tue Oct 13, 2020 11:35 amThe smallest of all possible errors: p129 section 8.6 refers to "IRQV2", but everywhere else this is called "IRQ2V"
Spotted another little boo boo.
Page 102
NVWRCH is labelled as non-vectored read character.
NVRDCH is labelled as non-vectored write character.
Fantastic work by the way. I'm really impressed. Shame I can't have it in a compact ring binder book.
Page 102
What's this on page 113 about?
&FFB3 in OS 1.20 is &00 BRK
It's also mention on the table on page 102.
6.5.3 OSWRSC
Call address &FFB3
Not indirected
Entry parameters:
Least significant byte of the address to be written in location &D6
Most significant byte of the address to be written in location &D7
A=value to be written
On Exit:
A, X and Y are preserved.
This call is not available from second processors.
- TobyLobster
- Contact:
Here's another in my small collection of "but does this really matter? I'm just being overly pedantic now" issues: there's a typo at the top of P363, 'funtions' instead of 'functions'.
Another round of corrections. The updated PDF is in the opening post.
Changes since revision 4 (April 2020):
- p102 (110) 6.1 OS calls : NVWRCH &FFCB should be 'Non-vectored write', NVRDCH &FFC8 should be 'Non-vectored read'
- p129 (137) 8.6 user VIA interrupts : IRQV2 should be IRQ2V
- p159 (167) 12.2 memory use OSBYTEs : added OSBYTE &EF (239) - read/write flag used by OSBYTE &72
- p173 (181) 13.1.6 OSBYTE &B6 : added hyperlink to Master OSBYTE &B6 - read/write use printer ignore char
- p206 (214) 13.3.13 VIDCON general summary table : mode 7 entry should be &4B
- p363 (371) 19.6 top paragraph : 'funtions' should be 'functions'
- p421 (429) 24.1.5 OSBYTE &FF : call address should be &FFF4
- p422 (430) 24.2.2 OSBYTE &F5 : section moved from page 423
- p423 (431) 24.2.4 OSBYTE &F6 : section renumbered from 24.2.3
- p423 (431) 24.2.5 OSBYTE &B6 : added new section for read/write use printer ignore char
- p424 (432) 24.2.6 UPTV : section renumbered from 24.2.4
- p425 (433) 24.2.7 OSBYTE &7B : section renumbered from 24.2.5
- p428 (436) 24.4.1 OSBYTE &81 read machine type : US OS version should be A1.0
- p436 (444) Appendix A : added hyperlink for Master OSBYTE &B6 - read/write use printer ignore char
- p437 (445) Appendix A : added hyperlink for OSBYTE &EF - read/write shadow state
- p438 (446) Appendix A : OSBYTE &F5 entry updated to page 422
It's for writing to screen memory when shadow RAM is present. Let's trace it.6502 wrote: ↑Sun Nov 22, 2020 8:11 pmWhat's this on page 113 about?
&FFB3 in OS 1.20 is &00 BRKCode: Select all
6.5.3 OSWRSC Call address &FFB3 Not indirected Entry parameters: Least significant byte of the address to be written in location &D6 Most significant byte of the address to be written in location &D7 A=value to be written On Exit: A, X and Y are preserved. This call is not available from second processors.
F402: 20 AB F3 JSR F3AB >s
F3AB: 48 PHA
F3AC: 48 PHA
F3AD: 48 PHA
F3AE: 08 PHP
F3AF: 48 PHA
F3B0: DA PHX
F3B1: BA TSX
F3B2: BD 08 01 LDA 0108,X
F3B5: 9D 05 01 STA 0105,X
F3B8: BD 07 01 LDA 0107,X
F3BB: 9D 04 01 STA 0104,X
F3BE: A9 F3 LDA #F3 ; This sets the address our caller will return to (1)
F3C0: 9D 07 01 STA 0107,X
F3C3: A9 D6 LDA #D6
F3C5: 9D 06 01 STA 0106,X
F3C8: AD 34 FE LDA FE34 ; Fetch the current value of ACCCON which controls some memory mapping.
F3CB: 9D 08 01 STA 0108,X
F3CE: A9 08 LDA #08 ; map out the 8K filing system RAM - see Master Ref Manual Pt1, Page F2-3, bit Y
F3D0: 1C 34 FE TRB FE34 >s
F3D3: FA PLX
F3D4: 68 PLA
F3D5: 28 PLP
F3D6: 60 RTS
F405: 4C 5F DB JMP DB5F
DB5F: 91 D6 STA (D6),Y ; So this is doing the actual write. Note that Y is included and the documentation said nothing about that.
DB61: 60 RTS >s
F3D7: 08 PHP ; Note we're now at the address put on the stack at (1) +1
F3D8: 48 PHA
F3D9: DA PHX
F3DA: BA TSX
F3DB: BD 04 01 LDA 0104,X ; get the saved value of ACCON back.
F3DE: 20 B0 ED JSR EDB0
EDB0: 29 08 AND #08 ; isolate bit Y (8K filing system RAM).
EDB2: D0 08 BNE EDBC ; if it was set previously...
EDBC: 0C 34 FE TSB FE34 ; set it.
EDBF: 60 RTS
F3E1: BD 03 01 LDA 0103,X
F3E4: 9D 04 01 STA 0104,X
F3E7: FA PLX
F3E8: 68 PLA
F3E9: 28 PLP
F3EA: 28 PLP
F3EB: 60 RTS
And another documentation bug on page 102 - while OSRDSC will read from the ROM of your choice (it was OSRDRM on the BBC B), OSWRSC does nothing with paged ROMs or sideways RAM - the code clearly shows it does nothing with &F4 and &FE30.
Then looking down the set of addresses, I wonder what is at &FFBC and &FFB6.
I just stumbled across this myself and came here to report it only to find this post a few days ago, quite a coincidence. BeebWiki had this wrong too, I've just fixed the page there: http://beebwiki.mdfs.net/OSWRSCCoeus wrote: ↑Mon Mar 08, 2021 1:32 amSo just a documentation bug here in failing to mention that Y is added as an offset to the address in &D6/&D7.Code: Select all
