Advanced Master Reference Manual [Remastered PDF]
avoid work duplication! collaborate on the archival of acorn literature!
dv8
Post by dv8 »
Here is a completely remastered PDF of the Advanced Reference Manual for the BBC Master by Watford Electronics.
  • The look and layout of the original book has been preserved.
  • A large number of error corrections have been applied to the text.
  • All diagrams have been redrawn in vectors.
  • There is extensive hyperlinking - click on any reference to a page, chapter or section to jump directly to the relevant page.
Advanced_Master_Reference_Manual.pdf
(1.05 MiB) Downloaded 89 times
Other remastered user guides in this series:
Master Reference Manual Parts 1 and 2
Advanced User Guide
New Advanced User Guide
BBC Micro User Guide (Model B and B+ editions)
Kecske Bak
Re: Advanced Master Reference Manual [Remastered PDF]
Post by Kecske Bak »
Many thanks for this - I have your entire collection on my PocketBook and I'm currently reading through Ian Birnbaums's 6502 book and cross referencing the User Guides and Advance User Guides as I go through. It simply amazes me the amount of work you are putting into this project. I assure you that I am putting your hard work to good use!
leenew
Post by leenew »
Thank you.
Amazing work once again! =D>
Lee.
Lardo Boffin
Post by Lardo Boffin »
Nice! Many thanks. 8)
Adventure Language on GitHub
Atom, issue 5
Elk
TobyLobster
Post by TobyLobster »
Excellent work as always, it's great to have this. (Errata: P215 "0.5μ5 on a BBC model B" should be "0.5μs" I guess.)
dv8
Post by dv8 »
Kecske Bak wrote:
Thu Feb 11, 2021 1:06 pm
Thanks. It's always good to know that people find these books useful.
TobyLobster wrote:
Thu Feb 11, 2021 11:28 pm
Yes it should be μs. I should have caught that one during proof reading. #-o
Sometimes I wonder what on earth the OCR is thinking when it does stuff like this.
Post by BeebMaster »
Looks great, thank you so much. It's always annoyed me with this manual that Watford made such an effort to keep the cover style consistent with the two Acorn Master Reference manuals but they never bothered to match the font!
SteveF
Post by SteveF »
Another amazing effort, thanks! I didn't even know this existed until now.
dv8 wrote:
Sun Feb 14, 2021 12:06 pm
Am I missing something, or is there another error - the next line suggests the cycle time is 0.33us on a Master. Surely the cycle time is 0.5us on a Master, just like on a BBC B? 0.33us would apply to an external Acorn 6502 copro (whether connected to a B or Master).
Post by BigEd »
I think I spotted a factual error too - but what to do? These are not OCR problems...
(The manual says that there are two custom chips in the Tube, one at each end, and that's not so, for Acorn second processors.)
cmorley
Post by cmorley »
BigEd wrote:
Tue Feb 16, 2021 7:09 am
It is on the Master because the Tube is buffered (& switched internal/external)... For the external Tube IC21 sits in the way between the CPU bus and the external Tube on the Master & INTUBE/EXTUBE are generated by IC15.
Post by BigEd »
Well, I suppose one could read it that way, and the EBC is described earlier on, but these two paragraphs a bit later read to me as misapprehension:
Each processor runs independently of the other and is provided with its own clock and memory chips. The two systems communicate with one another over a 2MHz asynchronous bus, known as the Tube, which is controlled at each end by a custom interface.
The Tube provides the means for the language and I/O processors to communicate with each other. The Tube comprises a pair of proprietary chips coupled to the respective processors and communicating with one another over a 2MHz asynchronous bus.
It's true to say that "The Tube chip" is always singular and related to a single second processor, and it's true that the Master can have two second processors connected, one internal and one external, but to me those paragraphs still don't read right.
However, if that's an objection, it's an objection to the original document, not to the excellent and helpful remastering of the document!
TobyLobster
One more... P.87: "4) USERV has been included in the MOS sub-section because it is used to pass the unknown OSWORDs &E0 to &FF the user." this should be "...*to* the user." I would imagine.
Edzard
Post by Edzard »
Thanks! Very impressive indeed.
Edzard
lovebug
Post by lovebug »
nicely done thanks
randomly changing stuff in your code until it works is "hacky" and "bad coding practice"
do it fast enough and its called "machine learning"
Post by DutchAcorn »
This is (again) an amazing piece of work, beautifully done. Thank you for the hard work and sharing it.
dv8
Post by dv8 »
SteveF wrote:
Mon Feb 15, 2021 10:52 pm
When I first read that line I took it to mean an external 2P on either the Master or Model B. Looking at it again, it does seem to imply the Master without a 2P so I'll re-organise this part to make it clearer.
Factual errors are welcome too. I would like the remastered books to be accurate and have already fixed loads of mistakes in this one.
My initial interpretation of "a pair of proprietary chips" was a Tube ULA on the parasite and the PBC on the host. I see what you mean though, the two quoted paragraphs could be read as a Tube ULA on each side.
I'm still undecided whether to change this or leave it as is. Anyone care to offer an alternative, less ambiguous, wording?
BigEd wrote:
Tue Feb 16, 2021 10:20 am
No worries, I didn't take it that way!
The whole book really is quite shoddy and feels like it was put together in a rush. It's not much more than a collection of sloppily copy+pasted text from other sources with little attention given to quality control.
TobyLobster wrote:
Wed Feb 17, 2021 8:18 pm
Agreed. I'll change this in the next release.
Finally, a big thanks to all the other commenters for your kind words.
Return to “scanning of books, magazines, ads and letters”
