Computer Concepts Speech ROM and Text To Speech [Remastered PDFs]
dv8
Post by dv8 » Thu Mar 21, 2019 2:56 pm
Attached are remastered PDFs of the Computer Concepts Speech ROM Instruction Manual and the Text To Speech Manual Supplement.
The zip file contains the Speech and Text To Speech ROM images.
Also included is an SSD disc image containing the listings and examples from the manual plus a copy of the ROM images. Boot the disc with Shift+Break to run the demo program. Enter the command *TYPE !INDEX to get an index of the files on the disc and which section of the instructions they relate to.
Computer_Concepts_Speech.pdf
(267.2 KiB) Downloaded 74 times
Computer_Concepts_Speech.ssd
(63.25 KiB) Downloaded 50 times
Computer_Concepts_Text_To_Speech.pdf
(44.08 KiB) Downloaded 68 times
CC_Speech_and_Text_To_Speech_ROMs.zip
(15.99 KiB) Downloaded 64 times
Other related manuals:
Acorn Speech System User Guide
deladriere
Re: Computer Concepts Speech ROM Instruction Manual
Post by deladriere » Sun Nov 03, 2019 3:27 pm
Thanks for this
I would like to try this on BeebEm4
I can launch the *TYPE !INDEX that returns the list of command but when I try *SPON it returns a " Bad command"
What should I do?
Thanks in advance
Post by tricky » Sun Nov 03, 2019 4:55 pm
BTW, I'm still looking for the instructions for the accompanying Computer Concepts Text To Speech ROM. If anyone has a copy please get in touch so it can be preserved.
Sorry, I photographed the tts manual at ABUG, but life and hurting my back have got in the way. We've been away, but I will try to transcribe it soon.
Post by tricky » Sun Nov 03, 2019 6:46 pm
Drop box link to low res scans
	TEXT TO SPEECH
	Manual Supplement
The Text To Speech ROM is supplied as a complementary chip to the SPEECH ROM. The TTS ROM is of no use on its own. This document is a supplement to the SPEECH manual, covering the features added by the TTS ROM.
The Computer Concepts SPEECH ROM alone gives speech of high quality, but is relatively difficult to use. Using the SPEECH ROM alone the command required to make it say “BBC Microcomputer” is:
*UTTER <1>B E B E S E M * I K R O K UH M P Y +00 T UH
The Text To Speech ROM (TTS ROM) is a driver for the normal SPEECH ROM. It can be given the command:
*SAY B.B.C.Micro Computer
and it will work out the appropriate commands to make the SPEECH ROM say the words.
The rules by which text is translated to speech are extremely complicated, and do not always produce exactly the result expected. Unfortunately given a sentence like:
"John took the lead"
it is impossible to decide whether John won a race or stole a piece of metal! The word 'lead' can be pronounced either as 'leed' or 'led'. Even with anomalies such as this, the TTS system produces very acceptable results.
	Fitting the ROM
A separate sheet is included which details the fitting of ROM chips. The TTS ROM may have been purchased at the same time as the SPEECH ROM, or as a later add-on. Whichever is the case, simply plug in both ROMs as described in the ROM Filling Instructions. The order of the two chips is unimportant. For the BBC B+ the two chips can be supplied as one single 32K chip. This saves on valuable socket space. Computer Concepts are able to supply this single all-in-one chip as a replacement for the two separate chips at a cost of £5.75 incl.
For the speech system to operate at all, the BBC Micro speech processor must be fitted. If this is not already fitted to your machine then one must be purchased. If a speech processor (labelled TMS 5220) was supplied as part of the package, it must be fitted according to the instructions headed 'Speech Processor (TMS 5220) Fitting instructions'.
	Initialisation
Once the speech system is fitted, it has to be initialised before it will work. This is done with the single command:
*TEXON[RETURN]
The system will immediately reply with a message instructing the user that [BREAK]. must be pressed. There is no need to initialise the SPEECH ROM separately.
	TTS Commands
The most useful command provided by the TTS is *SAY. It should be followed by plain English words and quite simply causes those words to be spoken. For example, try the command:
*SAY Text to speech[RETURN]
All of the commands can be included in BASIC programs, or any other program that allows access to * commands. For instance in the Wordwise Plus word processor a footing can contain an embedded command as.
*SAY change paper!
*SAY is the major TTS command, but other commands are provided for flexibility. Instead of just speaking text from BASIC programs etc., it is possible to instruct TTS to speak all words typed at the keyboard, all words sent to the printer, all words on the screen, and so on. In fact, whatever the input or output device (within reason!) TTS can be made to speak accordingly.
The remainder of this supplement describes each of the commands provided by the TTS system. Commands may still be given directly to the SPEECH ROM if necessary, details of which are contained in the SPEECH ROM Instruction Manual.
*TEXON
As described earlier, this command is used to initialise the entire speech system. The [BREAK] key must be pressed immediately after the command is used. Note that the speech system claims a total of 1K of memory when the *TEXON command is issued. As a consequence, any programs, text, etc. currently in memory will be lost after speech system initialisation. The *TEXON command should therefore be issued before programs etc. are loaded.
*TEXOFF
This is the reverse of *TEXON, serving as a means of disabling the speech system and reclaiming its 1K of memory for other uses. Note that with either *TEXON or *TEXOFF no action is taken if the system is already in the appropriate state. Pressing [CTRL] [BREAK] may also be used to disable the speech system.
*SAY <text>
This is the command used to produce speech directly from command mode or from within a program. Any text string may be entered and the system will make the best sense that it can. For instance some common abbreviations such as “Mr.” are spoken in full, symbols are spoken in full and words containing no vowel are spelt out. Punctuation marks, quotes and brackets are treated differently in different contexts. Some control over interpretation can be exerted with *SMODE, *RMODE and *TMODE.
*PHONS <text>
This command works identically to *SAY but the phonetic translation produced is displayed on the screen. The screen output is exactly the command which would be required to say the given words through the normal SPEECH ROM *UTTER command. It is therefore useful for fast development of text for use with just the SPEECH ROM (without TTS). It can also be used for 'tweeking' output from TTS. If the TTS translation is slightly wrong for some reason, the translation can be examined, changed, and output directly through the SPEECH ROM.
*SAYIP
This is the first of the commands giving access to other sources of input. Following *SAYIP an attempt will be made to say whatever is entering via the current 'input stream'; this could be the keyboard or the RS423 port according to which has been selected with the standard *FX2 command (see the User Guide for The BBC micro automatically handles RS423 handshaking so that input slows to accommodate speech. The selection of a new source automatically cancels previous ones *SAY and *PHONS both cancel the selection of all other sources.
*SAYOP
This command causes the Text to Speech system to say whatever is entering the 'output stream'. This means, for instance, that machine responses such as “Syntax error” are spoken in addition to any input. It a program is listed after *SAYOP the listing will be spoken! - so will disc catalogue following *CAT. Remember different source modes are mutually exclusive, each cancels the rest.
*SAYPRT
In this mode all data going to the printer channel is diverted to the Text to Speech system. No output is actually sent to the printer. Speech can be switched on and off using [CRTL] [B] and [CTRL] [C].
*SAYOFF
This command can be used at any time to cancel any of the preceding special source modes without enabling another.
*SAYSCR
This command causes the whole contents of the current screen to be read out. The cursor is returned to the correct position afterwards. The reading can be stopped by using [ESCAPE].
*SAYFILE <filename>
The contents of any disc file can be spoken using this command. It is clearly more appropriate for use with text tiles, but an attempt will he made whatever the file contains. Strange results are obtained with BASIC tiles as some of the tokenised keywords and line numbers are interpreted as symbols.
*SAYMEM <start> <end>
This command requires two hexadecimal addresses as parameters. The system will attempt to say whatever data is resident in memory between the two addresses. Once again the output will not make much sense unless this data is text in ASCII format. Note that meaningless data will not crash the system; it will either be interpreted as spaces or symbols.
*SHUTUP
One of the problems encountered by users of the SPEECH ROM is the inability to abort speech which is backed up in the buffer without pressing [BREAK]. This command has precisely the required effect; all speech is immediately terminated and the system reset without affecting any other machine functions. Any speech, whether generated by the Text to Speech system, or by *UTTER, is equally affected. (Note that this command is automatically invoked when *SAYSCR is interrupted with an [ESCAPE]).
*SMODE <N/U/A>
This command, which requires one of the single letter parameters indicated, controls the system choice between pronouncing a whole word or spelling it out letter by letter. The default action, present at initialisation (including Break) or invoked by the N parameter, is to pronounce all words containing at least one vowel; those consisting solely of consonants are spelt out. The parameter U stands for “Uppercase”; in this mode lowercase words are treated normally but uppercase ones are all spelt out. This can be useful with text which contains many uppercase abbreviations not common enough to be recognised by the system as abbreviations. The parameter A, standing for “All”, causes the system to spell out all its input. In addition, however, it prevents the system from waiting for a space between words before deciding how to proceed. The net effect is that each character is spoken as soon as it is received. This mode is designed to be used with *SAYIP creating a machine with a 'live' keyboard. In keeping with this intended function the [SPACE] [RETURN] and [TAB] keys are also spoken.
*RMODE <I/S/F>
This command determines what the system will do on encountering a Carnage Return. I stands for "Ignore" and is self explanatory. This mode is useful for speaking text in which the words wrap round to the next line. S stands for "Space", in this mode Carriage Returns are interpreted as spaces, useful for instance with right-justified text in which adjacent words at line ends may only be separated by [RETURN]. F the default, stands for 'Full stop'. In most cases it is most appropriate for the system to assume the end of a sentence at a Carnage Return. Unfortunately in many situations, for example during a screen read, the Carriage Returns are implicit and not present in the text itself; no control is then possible over system behaviour and unwanted effects may occur.
*TMODE <N/W>
At initialisation or following the parameter N (for "Normal") the system assumes the end of a sentence on encountering three consecutive spaces. The parameter W, standing for "Wait", prevents this; the system waits for explicit punctuation. This is useful with unjustified text where there may be many spaces at the end of a line, or with widely spaced text. The disadvantage of Wait mode, and the reason for default to the other option, is that if no explicit punctuation is present at the very end of the text the last sentence is not processed and remains in the Text to Speech input buffer. The user may then be surprised by its release when further text is encountered.
Sorry it took so long, RichText version attached.
ComputerConceptsTextToSpeech.zip
RichText version
(5.81 KiB) Downloaded 32 times
dv8
Post by dv8 » Sun Nov 03, 2019 7:27 pm
What should I do?
The disc in the above archive only contains listings from the manual, it doesn't contain the actual Speech software.
EDIT: The disc image has now been updated to include the Speech and TTS roms.
The ROMs can be downloaded from the zip file in the opening post. To use them, BeebEm needs to be configured to see the ROMs (by editing the Roms.cfg file).
Be aware that the only version of BeebEm that will work with CC Speech is tricky's modified version 4.03 for Windows. It can be downloaded from this post.
If you would prefer an easier way to get speech in BeebEm I would recommend trying SPEECH! by Superior Software instead.
dv8
Post by dv8 » Sun Nov 03, 2019 7:52 pm
No worries, I was distracted with other projects and had forgotten all about this :oops:
Thanks for uploading the pics and text.
I'll get a remastered PDF done soon as poss.
dv8
Re: Computer Concepts Speech ROM and Text To Speech Instruction Manuals
Post by dv8 » Mon Nov 04, 2019 12:26 pm
The Text To Speech PDF has now been added to the opening post.
I've also included a zip file with the two ROMs and added the ROMs to the disc image.
deladriere
Post by deladriere » Mon Nov 04, 2019 5:42 pm
Thanks guys for your prompt replies
I am trying to get the data for the various phoneme so I could feed the Arduino Talkie library (a TMS5220 emulator) with them
The Rom format seems quite difficult to understand (to find the various phonemes)
I may have to buy the real thing and sniff the data feed at the TMS5220 pins
Unless anyone has a better idea. :D
e668ecp
Re: Computer Concepts Speech ROM and Text To Speech [Remastered PDFs]
Post by e668ecp » Thu Nov 19, 2020 5:15 pm
Sorry to resurrect this thread but I've just found a spare boxed copy of Computer Concepts Speech program together with a TNS5220.
After inserting both roms I've typed *SPON and then pressed Break but when I do this the BBC hangs until I do a Ctrl+Break
Any ideas what's wrong?
Post by tricky » Thu Nov 19, 2020 5:50 pm
No, but I have had the same problem once when the resistor capacitor network was producing a clock way out of spec. The pot was just dirty and a bit of twiddling for it working again. I use a meter to set it up to speed, but as long as the machine works, you can probably do it by ear.
I would go with the usual trouble shooting first.
Which versions of the ROMs do you have?
Do you have the demo disc and is it the same? Same for the manual?
e668ecp
Post by e668ecp » Thu Nov 19, 2020 5:58 pm
I've inserted the ROMs into my original BBC and the work fine.. so im not sure why they don't work in my "test" BBC. They are both Issue 7's.
What is the alterations that are needed to the motherboard to get the Speech to work? My orginal BBC had this system fitted by a dealer in 1985/6 and they are long gone!
TMS5220 made in England
Speech V1
e668ecp
Post by e668ecp » Thu Nov 19, 2020 7:36 pm
Sorted... dodgy ROM socket
Post by tricky » Thu Nov 19, 2020 11:36 pm
No mods required on any boards for computer concepts ROMs or my Astro Blaster, but I don't know about the OS speech, but I guess that doesn't matter if you don't have the phrom.
