Advanced User Guide (Remastered)
These forums are for community collaboration on archiving, magazine scanning etc. to avoid work duplication and agree conventions / define standards
dv8
Post by dv8 » Mon Jun 03, 2019 2:34 pm
Here is a completely remastered PDF of The Advanced User Guide For The BBC Micro.
A huge amount of effort has been put in to fix the errors in the original book.
This PDF should be the most accurate version of the AUG available.
  • The look and layout of the original guide has been preserved.
  • A large number of error corrections have been applied to the text.
  • All diagrams have been redrawn in vectors.
  • There is extensive hyperlinking - click on any reference to a page, chapter or section number or on any OSBYTE/OSWORD reference to jump directly to the relevant page.
There is also a disc image containing all the listings. Enter the command *TYPE !INDEX to see a list of programs on the disc and which section of the guide they correspond to.
Advanced_User_Guide.pdf
Third revision (July 2019)
(1.33 MiB) Downloaded 37 times
Advanced_User_Guide.ssd
(19.75 KiB) Downloaded 42 times
Other remastered user guides in this series:
New Advanced User Guide
BBC Micro User Guide (Model B and B+ editions)
leenew
Re: Advanced User Guide (Remastered)
Post by leenew » Mon Jun 03, 2019 3:09 pm
:shock: Amazing 8)
Lee.
MartinB
Post by MartinB » Mon Jun 03, 2019 6:02 pm
What I said in the Remastered NAUG thread... =D>
0xC0DE
Post by 0xC0DE » Mon Jun 03, 2019 6:22 pm
Fantastic, thank you so much! :D
0xC0DE
Visit my YouTube channel featuring my demos for Acorn Electron and BBC Micro
Post by Elminster » Mon Jun 03, 2019 7:49 pm
Yikes. Downloaded...... Last one. What tome of law is next?
dv8
Post by dv8 » Mon Jun 03, 2019 10:35 pm
Well, the Master Welcome Guide and Reference Manuals are on the 'to-do' list but I need a break before starting another big project like that :)
tom_seddon
Post by tom_seddon » Tue Jun 04, 2019 11:56 pm
Nice work! Great to see the key numbers fixed, and for OSFILE to finally have the right address :) - I suspect this PDF will have a permanent home in my Acrobat recent files list...
I have found one new issue - on page 257, 10.2 section c should real "Locations &FD and &FE".
--Tom
P.S. A remastered version of the Master Reference Manual (volume 1 in particular) would be amazing!
Rich Talbot-Watkins
Post by Rich Talbot-Watkins » Wed Jun 05, 2019 5:44 am
Yeah, I have enduring memories of 9 and I being the wrong way round in the AUG. (Were there other problems?)
Thanks a lot for doing this, it'll be my new indispensable Beeb reference!
dv8
Post by dv8 » Wed Jun 05, 2019 8:58 am
Thanks for this. I've corrected the PDF but I'll leave it a week or so before re-uploading to see if any other errors are discovered.
I don't think there were any other mistakes in that table on p142.
There were quite a few problems with the larger keycode table in the NAUG (section 14.1), mostly internal key numbers and INKEY numbers not corresponding or decimal/hex numbers not matching. Can't remember if these errors were also present in the equivalent AUG table (appendix C).
rmbrowngr
Post by rmbrowngr » Wed Jun 05, 2019 1:10 pm
Great stuff. Any thoughts on the Electron User Guide? :-k The only copies I have are of a poor scan in pdf and a tatty copy bought from eBay.
Acorn_ElectronUG.zip
(4.73 MiB) Downloaded 4 times
Richard B
Acorn Electrons issue 4 and issue 6 with Master RAM Board, Acorn Plus 1, AP6, AP5, Pegasus 400, BeebSCSI, Gotek, Raspberry Pi 2nd Processor, GoSDC MBE with Elk2GoSDC and Cart2GoSDC.
BBC B+ 64K (128K upgraded) with Duel OS
vanekp
Post by vanekp » Wed Jun 05, 2019 1:32 pm
Electron User guide https://www.retro-kit.co.uk/user/custom ... tronUG.pdf
you can download Electron advanced uses guide here http://stardot.org.uk/mirrors/www.bbcdo ... Issue2.pdf
Peter.
dv8
Post by dv8 » Tue Jun 11, 2019 10:29 am
Updated the PDF to fix a few issues. Download links in the opening post
Changes since revision 1 (June 2019)
  • p54 (56) BRK instruction, B flag : added text (set in P pushed on stack)
  • p152 (154) OSBYTE &81 Read machine type : (INKEY &FF00) changed to (INKEY -256)
  • p153 (155) OSBYTE &81 Read key : added link to 'Read machine type' entry on p152
  • p257 (259) 10.2 BRK vector (c) : 'Locations &ED and &FE' should be &FD and &FE
  • p272 (274) 11.3 Page two : &297-&27B should be &297-&29B
  • p349 (351) 16.11 ROM Filing System, 3rd para from bottom : (&43 '#') should be (&23 '#')
  • p366 (368) 18.8.1 The cursor start register (R10) : '1/16th and 1/32nd of field rate' should be '16 and 32 times field rate', added text 'When bit 6=0 and bit 5=1, the cursor is disabled.'
dv8
Post by dv8 » Mon Jul 01, 2019 8:20 am
Another update with more corrections. The new PDF is in the opening post
Changes since revision 2 (June 2019):
  • p127 (129) OSBYTE &0B / *FX 11 : default setting n=32 should be n=50
  • p215 (217) OSBYTE &D4 / *FX 212 : default value 144 (&90) addded text 'amplitude -13'
  • p216 (218) OSBYTE &D5 / *FX 213 : default value 101 (&65) should be 100 (&64)
  • p217 (219) OSBYTE &D6 / *FX 214 : default value 7 should be 6
  • p226 (228) OSBYTE &E4 / *FX 228 : default value for fn+SHIFT+CTRL, &A0 should be 0 - key has no effect
  • p246 (248) OSBYTE &FF / *FX 255 : added link to Appendix J, added description for bit 7, added timing table for 1770/1772 FDC
  • p366 (368) 18.6.3 Cursor blanking delay : 'Cursor enable signal' should be 'Cursor blanking signal'
  • p483 (485) Appx.I - link options : added * to default setting for each option
  • p484 (486) Appx.I - link options, S14 : descriptions wrong way round, should be OPEN=disable JIM, CLOSED=enable JIM; in the note 'link 16 must be CLOSED' should be 'link 15 must be CLOSED and R72 fitted'
  • p485 (487) Appx.I - link options, S15 note : 'link 15 must be CLOSED when link 17 is OPEN' should be 'link 15 must be CLOSED and R72 fitted when link 14 is OPEN'
  • p485 (487) Appx.I - link options, S16 note : 'link 16 must be CLOSED if link 14 is OPEN' should be 'link 16 must be CLOSED and R73 fitted when link 17 is OPEN'
  • p485 (487) Appx.I - link options, S17 note : 'link 15 must be CLOSED' should be 'link 16 must be CLOSED and R73 fitted'
  • p489 (491) Appx.J - keyboard links : added switch orientation diagram for type 2 keyboards
dv8
Post by dv8 » Mon Jul 01, 2019 8:23 am
Coming soon... :)
soviet
Post by soviet » Mon Jul 01, 2019 8:25 pm
Awesome work, it's gonna be very useful to my have a lot lo learn.
=D>
