Today I received.....
derek
Re: Today I received.....
Post by derek » Sat Aug 15, 2020 1:04 pm
I just aquired a BBC issue 3, with Opus Disc Drive board and external speaker connection:
There is a mod. to the board under the Opus board
Looks like pin 40 has been crushed...
I have look at the power supply to check or change the capacitors before power up.
Regards,
Derek
derek
Post by derek » Sat Aug 15, 2020 1:07 pm
In addition to the above BBC issue 3, there these items included:
Twin 3" Disc Drives to plug into BEEB.
Joystick
Speakers
Tape Drive.
Quite nice system, once I check the power supply .
Regards,
Derek
tone76
Post by tone76 » Sun Aug 16, 2020 2:49 am
It was more like 2 days ago, but I received a Wong's Model B Issue 7. I tried livestreaming the unboxing but it was a bit of a fail, hence the grainy shot and weird pose.
This one's a resto project. Several keys are missing, a couple others are broken, and it gives the infamous Long Beep ... but it was a very good price (in the context of the Australian market) and it's nothing I probably can't fix.
Acorn Electron
BBC Model B (either too many or not enough)
BBC Model B+ 128K
BBC Master 128 x 2
Post by BeebMaster » Sun Aug 16, 2020 12:31 pm
I quite like the home-made air vents in the case, that's a good idea.
tone76
Post by tone76 » Mon Aug 17, 2020 12:49 am
Interestingly, the vents appear to be right on top of the PSU. I've seen this mod before, which makes me wonder if there was a template somewhere (maybe in a magazine or user group newsletter?)
Whilst part of me would like to restore this machine to original condition, I'm leaning towards leaving the vent mod as-is. It's part of this machine's story, and the rest of the case is in quite good condition overall. (notwithstanding the black keyboard surround, which has a crease in it between the cassette motor and caps lock LEDs ... I wonder if something heavy was placed on this machine at some point? It'd explain the broken keys and the crease)
Acorn Electron
BBC Model B+ 128K
BBC Master 128 x 2
Post by BeebMaster » Mon Aug 17, 2020 11:31 am
Could have been caused by a falling monitor...
Is the ZIF socket lever a bit skew-whiff as well?
Post by Coeus » Mon Aug 17, 2020 2:16 pm
Whilst part of me would like to restore this machine to original condition...
How would you do that if you wanted to? Fill the holes with something? If so, what? Or replace the top with one from elsewhere? Where?
Post by 8271 » Tue Aug 18, 2020 7:02 pm
Econet RiscPC Podule from Ian *AND* Econet modules from BeebMaster.
The Econet Network is going to have significant upgrades to the server speed in the coming evenings!
2 x BBC-B, 4 x Master128, Master Viglen, Master Domesday, A310, A4, A5000, RiscPC700 Level 4 Server, RPC_SA233 & RPC_SA200, RiscOS_Pi, Econet & Ethernet
stephen_usher
Post by stephen_usher » Wed Aug 19, 2020 7:27 pm
I "accidentally" won an eBay auction...
Oops. Well, it'll be useful in porting the latest OpenSSH to SunOS 4.1.4. A bit faster than the SPARCstation 5.
jonb
Post by jonb » Thu Aug 20, 2020 7:43 am
Nice pizza box Stephen!
They do come up occasionally for reasonable prices. I scored an IPX with keyboard and Sun monitor for postage as the owner was moving house and wanted rid. It's ex Bath Uni Maths department. Just needed a battery hack for the NVROM and it's a good 'un. I was given an UltraSparc 5 by someone too, but I spoiled that by shelling out for a Ultra 10 case and more memory (£100, ouch).
Post by Elminster » Thu Aug 20, 2020 9:30 am
I use my sun oracle T5000 spare server as part of my shelving system, I never start it as the noise is so loud you have to go to the other end of the house. Perhaps I should have bought a sparc Station instead ...
Now I have the sound meter from the 3D printer tests I should probably start it up and test it, if I can remember the ILO commands
Post by Rod C » Thu Aug 20, 2020 12:07 pm
Good luck with the Beeb. If it would help, I can send you the @, 6 and X keycaps from a scrap keyboard I have here. What else is broken on the keyboard?
Rod
marcusjambler
Post by marcusjambler » Thu Aug 20, 2020 10:42 pm
Cant resist books...
drfloyd
Post by drfloyd » Sat Aug 22, 2020 1:18 pm
Received my Archimedes 3010, with DOM 512Mb, ZIP and french plug :)
stephen_usher
Post by stephen_usher » Sat Aug 22, 2020 7:40 pm
Don't bother hacking the NVRAM, just buy an M48T02 from RS Components or Farnell.
johnkenyon
Post by johnkenyon » Sat Aug 22, 2020 8:19 pm
Two problems with that idea:
1) Finding a M48T02 - out of production.
2) The M48T02 went through at least two revisions, and despite the specs not changing, "newer" versions wouldn't work when dropped in to IPXs.
The NVRAM on my IPX was my first attempt at dremeling off the cap. I damaged the 32.768kHz crystal and ended up with a 24 pin IC with two extra pins at each end. For the battery I initially used a tagged CR2032 that I had lying around (fell off and died during ~10yrs in storage, and have recently replaced it with a CR1220 battery in a holder hotglued to the top. (CR1220 chosen because it fitted in the smaller space and I had a spare one)
The UltraSparc5 uses a M48T59, which you may have more luck with a new replacement. On mine I dremeled off the battery and then soldered/hotglued a CR2032 battery holder onto the device. (CR2032 chosen because there's more space in a U5, and its a common PC CMOS battery)
If you want to go down the dremel route, I suggest buying a set of burrs. ("DURATOOL D00150 Diamond Tipped Burr Set, 30 Piece" was the kit I bought)
/john
jonb
Post by jonb » Sun Aug 23, 2020 9:00 am
It's more satisfying repairing it yourself. Cheaper too.
:D
tone76
Post by tone76 » Sun Aug 23, 2020 11:00 am
Possibly. The ZIF socket lever seems fine, though.
It'd be time consuming, but doable. I'd probably borrow the methods used by a couple of prominent YouTubers: The 8-Bit Guy made a video about filling a large hole in the top of a Bell and Howell (rebadged Apple II+), and RetroManCave made a video where he got a couple of Beebs resprayed. That said, I'm getting used to the vents; it's part of this machine's story.
That's a really kind offer, but I've managed to track down a parts Beeb (it's pretty ratty, might be beyond help). It's got some good parts on it, including a complete keyboard.
Thanks for the offer though ... it's this kind of thing that makes me appreciate Stardot (as well as the Acorn community as a whole). :D
Acorn Electron
BBC Model B+ 128K
BBC Master 128 x 2
drfloyd
Post by drfloyd » Sun Aug 23, 2020 11:09 am
I have seen about all the 8-16-32bit machines between 1980 and 1992
i can confirm that this A3010 is the best look, best OS, best basic, and fastest.
Multiwizard
Post by Multiwizard » Sun Aug 23, 2020 11:39 am
i can confirm that this A3010 is the best look.
Really?... :-k :-s :-? :shock:
It funny to see how different we all are, for me the A3010 the only one I never wanna have because of his awful look... :(
Apart of this version:
https://www.retro-kit.co.uk/user/custom ... /A3010.jpg
Greetings, Wim... :-)
stephen_usher
Post by stephen_usher » Sun Aug 23, 2020 1:47 pm
/john
I've not had any of these problems with sun3x/sun4c/sun4m machines. The M48T02s from RS just work in the sun4c as do the M48T08s in the sun4m machines.
True that the U5/U10 etc. NVRAMs are impossible to get though.
Post by 1024MAK » Sun Aug 23, 2020 7:02 pm
Lardo Boffin wrote:
Tue Aug 04, 2020 11:32 am
A fairly early (I assume based on the PSU) issue 2 model B.
Upgraded model A maybe?
Post by Lardo Boffin » Sun Aug 23, 2020 8:06 pm
At some point I may be brave and take the motherboard out at which point I will have a look at the soldering to see if any of it is a bit less neat and tidy than the rest. Are there any tell tale signs of an upgrade?
Adventure Language on GitHub
Atom, issue 5
Elk
Post by 1024MAK » Sun Aug 23, 2020 10:03 pm
At some point I may be brave and take the motherboard out at which point I will have a look at the soldering to see if any of it is a bit less nest and tidy than the rest. Are there any tell tale signs of an upgrade?
Half the DRAM chips in sockets. Any maybe a different batch/date code.
The extra connectors not being the same type/style/make.
The extra chips having a significantly different date date code.
The cut-outs in the rear case for the extra connectors not being as neat as a production B model.
Site Admin
Post by Arcadian » Mon Aug 31, 2020 4:30 pm
Actually arrived a few days ago, but...
20 sealed packs of 3.5" DSDD Floppies, purchased from oide (thanks Joe)
48 sealed packs of... middle-eastern HUMMUS. Yum.
(I'll admit I'm more excited about the Hummus than the Floppies)
topcat96
Post by topcat96 » Mon Aug 31, 2020 7:51 pm
Hummus on 3.5" floppy disc ... culinary genius but a bit too crunchy for my tastebuds :lol:
Post by Lardo Boffin » Thu Sep 03, 2020 1:53 pm
I’m a sucker for reasonably priced books.
Atom, issue 5
Elk
Post by richardtoohey » Fri Sep 04, 2020 3:45 am
I love reading (or at least skimming!) the old computing books - it was all so exciting and FRESH in those days. Now all "intuitive" GUIs and "AI" etc.
Or am I just hitting peak nostalgia [-X
Re: Today I recieved.....
Post by flaxcottage » Sun Sep 06, 2020 12:23 pm
So do I, my bookshelf is quite bulging. :lol:
Post by Rod C » Sun Sep 06, 2020 4:44 pm
'Two Acorn Econet modules unused since the late nineties:
Each of which tested out OK in my A3000. :D
Also a Quantum Trailblazer 840MB hard drive which my StrongArm RiscPC will hopefully accept as a brain transplant, having rejected the previous two transplant. [-o<
Return to “general”
