Raspberry Pi 400
Andy1979
Raspberry Pi 400
Post by Andy1979 »
Well this looks fantastic:
https://www.raspberrypi.org/products/ra ... rType=home
Spiritual successor to the BBC Micro / A30x0?
4gb RAM and a heatsink to keep it running quickly.
I think Risc OS 5.28 has arrived just in time to run on this, assuming hardware is identical to the Pi 4B.
Currently resisting the urge to buy - new job and toddler mean I just don't have the time to tinker with something like this right now.
tarcus69
Re: Raspberry Pi 400
Post by tarcus69 »
Yeah I was just itching to buy one myself, but I've got so many Pis already. I'd prefer the 8 gig in there, and a better keyboard though. Should be easy enough to put a Pi in a normal keyboard though but at the end of the day, I don't need any more Pis and any more keyboards, particularly poor quality ones so despite wanting to buy one I think I'll leave it.
JasonStonier
Post by JasonStonier »
Saw that today - looks awesome. I actually built my own version a few months back by stripping down a Pi 4 to the bare bones of ports - it's running an Amiga emulator most of the time and works really well. This official version is very neat indeed.
tarcus69
Post by tarcus69 »
I've only just cottoned on that it's not a Pi 4 in a case, I'd half intended to buy one and put the Pi 4 8GByte in there instead but it's not a Pi 4, it's a new purpose-made Pi on a new board rather than a Pi4 with a ports extension board.
JasonStonier
tarcus69 wrote:
Mon Nov 02, 2020 1:29 pm
Should be easy enough to put a Pi in a normal keyboard though...
It is pretty easy - first thing is to clip the ethernet and USB ports off (and wire them back on with flying leads) - then the Pi will fit in pretty much anything. My favourite one I've done uses an old Cherry PS2 mechanical keyboard which has bags of space inside - enough to fit a PS2>USB converter, radial cooling fan, USB hub, and USB>D9 joystick adapter. It's my main retro machine...if only it would run a BBC Emulator at any kind of speed.
tarcus69
Post by tarcus69 »
I did actually buy one in the end, because I'm a sucker. The intention is to use it as an alternative to my desktop machines as a bridge to the modern world for the retrocomputers, a sort-of modern home computer.
JasonStonier
Weellll...it's Christmas. Treat yourself.
Be interested to know how you get on with it.
jonb
Post by jonb »
I think a Pi4 8GB in the new Argon M.2 case, with 500GB M.2 SSD module fitted. Full sized HDMIs and a proper (albeit external) keyboard. Whoosh.
iainjh
Post by iainjh »
on the BBC news website:
https://www.bbc.co.uk/news/technology-54782255
inc a reference to the BBC, and a pic of a genuine Retroclinic BBC Master!
stephen_usher
Post by stephen_usher »
Should have had red function keys to hark back to the original Archimedes. :-)
tarcus69
Post by tarcus69 »
jonb wrote:
Mon Nov 02, 2020 6:18 pm
The 400 seems to be deliberately marketed as a low-cost computer, presumably that's why they went for the 4 gig instead of 8, and may not produce an 8 gig version because if they do, similar to the BBC B and A or Spectrum 48k and 16k, people will develop for the higher spec machine making the lower spec machine meaningless.
Also I have several 4Bs including an 8 gig version, they're still often painfully slow as a desktop system.
Marvin
Post by Marvin »
tarcus69 wrote:
Tue Nov 03, 2020 8:55 am
What the heck are you running on it ? It must be some seriously bloated software.
We used to "manage" with computers with CPU's that ran in the hundred mhz and only had a few megabytes of ram.
The fastest Pi I have is the 3B+ and that runs everything fast enough for me.
Post by BigEd »
I used to have a 2MHz system with 32k of RAM. Oh hang on, I still do...
fordp
Post by fordp »
Marvin wrote:
Tue Nov 03, 2020 10:40 am
We used to dream of one day having a megabyte, but you try telling that to the youth of today and they will not believe you!
FordP (Simon Ellwood)
dp11
Post by dp11 »
A 4GB Pi has 128K of RAM for every byte of RAM on a 32K Beeb
tarcus69
Post by tarcus69 »
Size comparison with my normal keyboard. The keys are similar size but it's safe to say it's not that nice to type on but then it wasn't going to be, that type of keyboard is not really made for keyboard junkies.
jonb
Post by jonb »
8GB Pi 4 with USB3 SSD is lightning fast. Check out a YouTube vid.
JasonStonier
jonb wrote:
Tue Nov 03, 2020 6:38 pm
The specs are better than my actual gaming PC...
Post by BigEd »
dp11 wrote:
Tue Nov 03, 2020 12:01 pm
Should I think of it as a Beeb's worth of Masters, or a Master's worth of Beebs?
Marvin
Post by Marvin »
BigEd wrote:
Tue Nov 03, 2020 10:58 am
Same here, you've only got to look at what 0xC0DE has achieved with his latest game Elementum with only 32K of RAM in total. I'd wager that a single icon on tarcus69 bloated Pi4 install requires more memory than that.
I find it insane that we have computers way more powerful than we could ever have dreamed of when started out and yet we still find ways to make them run slow.
The computers we have nowadays should be so fast that they give us the answer almost before we ask them if the software was written well.
Post by tricky »
Marvin wrote:
Tue Nov 03, 2020 8:28 pm
I think MS win that one with Office 365, which seems to be written in JS+node.JS and each "app" contains a version of chromium!
On the Pi400, does anyone know how the keyboard matrix is handled?
As in, N-key rollover or whatever doesn't clash on the grid - ultimately, how many and which keys can you hold down without loosing any info.
tarcus69
Post by tarcus69 »
Ditch the attitude please, it's a straight Raspbian install, same as on the Pi 400.
tarcus69
Post by tarcus69 »
tricky wrote:
Wed Nov 04, 2020 10:47 am
It appears to be basically the "official" Pi keyboard but wired into a USB port internally. There are three USB ports on the back instead of four, one of the USB 2 ports is missing. I'm typing on it at the moment, it's a bit "dead flesh" really. If I hold down one key I can press another, e.g. QWWWWW is me holding down Q then tapping W but qwerrrrrrrrrrrrrrr is me going through qwerty holding down keys, it stops noticing at R, so it looks like 4 keys.
JasonStonier
I didn't read it as attitude - just a commentary on the way increasing power and memory has led to lazy coding techniques.
I think of how I struggled to get a linux installation down to under 128 MB for a very early solid state drive in an embedded system...when compared to my Amiga which has a fully functional desktop environment on a 1.44MB floppy disk and cracked along on 2MB of chip RAM.
Now I love the Pi ecosystem in general, Linux in particular, and the innovation that it's encouraging, but you can't deny that a single hi-res icon on Raspbian would eat up an awful lot of the screen memory on a beeb :D
JasonStonier
Here's my version - the CherryPi.
Pi4 4gig, integrated USB hub, PS2>USB converter for the Cherry mechanical keyboard, radial cooling fan, Amiga joystick > USB converter.
Boots into Amiga Workbench, but a couple of keystrokes puts me in Raspbian - and it's my daily computer.
tarcus69
Post by tarcus69 »
JasonStonier wrote:
Wed Nov 04, 2020 11:34 am
Unfortunately when you get told you're doing something wrong, then later name-checked as having a bloated install, it does come across as attitude. I don't want to drag it out any further but he can cut that out.
As for bloatware, browsers are a big problem, they're now operating systems in their own right, and run effectively several virtual machines inside them, they can soak up a Pi's power pretty quickly particularly with multiple tabs open. I use "virt-viewer" on some older Pis to give me a thin client that works pretty well and allows a virtual machine's desktop to follow me around the house. On the Pi 400 it works very fast as it does on the other Pi 4s. Chromium tends to bog down a bit more than I'd like on these machines but much improved over the Pi3.
tarcus69
Post by tarcus69 »
JasonStonier wrote:
Wed Nov 04, 2020 11:43 am
Nice, and I'll bet it feels a lot better than this thing (the 400) does!
I move between several different keyboards, a C64, Electron, Beeb, A3000, Pi 400, a laptop, and several DAS tenkeyless keyboards, they all have little variations so I'm always hitting wrong keys which is annoying. The C64 and Acorns have some particularly annoying differences, e.g. delete is at the top right on the C64 and most of the others but on the bottom right on the BBC and Electron. Also on some, the colon and semicolon swap places which is an endless source of "fun"..
JasonStonier
As a habitual terminal user, I find I can't get out of the habit of hitting the Up Arrow to repeat the last command. Every time I do it on the beeb I'm like "what? I have to type the whole frikken command in AGAIN?"...
In other news, my folks were staying with us last week and my mum spent every minute of her spare time (re)playing Repton 3 on my beeb. Once b-em is up to speed on the Pi I'll be sorting her out a Pi 400 for Repton on the big telly.
mr-macrisc
Post by mr-macrisc »
I like this
I also like how some people are now looking at pcie 1x connector on new computer module and have sata adapters running and some good signs they may get gfx cards running. It at least opens up some desktop storage options
tarcus69
Post by tarcus69 »
JasonStonier wrote:
Wed Nov 04, 2020 12:09 pm
Yes the copy thing is weird, but also the star commands on my Archies and BBCs, as a long-time Linux user, cat and dir bend my mind every time..
I've long been surprised at the relative lack of simple updated options for BBC emulation on Linux, I need to go through them again, is b-em the best currently or are there other good ones? I don't have any Windows machines to run emulators on.
Return to “general”
