Page 1 of 1
Defects on ADFS floppies
Posted: Fri May 22, 2020 1:19 pm
by bjn
If...
- a "verify" operation finds defects
- they're all in the last few pixels of the progress bar
- the "free" dialogue says there's some free space
- all files happily copy from the floppy to the hard drive
are the defects likely in free space? Is everything likely fine?
Could the defects even be part of some fancy copy protection? ("Attempt to read sector x; if it succeeds, then this isn't a legit copy" -- I've heard of stuff like this being done on Amiga games or similar.)
Re: Defects on ADFS floppies
Posted: Fri May 22, 2020 1:24 pm
by danielj
If you do a *MAP on the floppy it should say where the free space is (but it's likely to be towards the end!) - if you didn't get an error when copying you should be fine.
Certainly there are a number of varieties of copy protection that'd cause a disk to fail to verify - and quite often these are on high numbered tracks. If this is commercial software I'd suspect copy protection. Give an example?
Posted: Fri May 22, 2020 2:35 pm
by bjn
Excellent, thanks. I'll give that a try next time I come across such a disk.
The one which prompted me to ask was the game Magic Pockets.
Posted: Fri May 22, 2020 3:13 pm
by danielj
Games, it'll probably be copy protection assuming the game itself appears to work ok...
Posted: Fri May 22, 2020 5:17 pm
by geraldholdsworth
EGO: Repton 4 on the Archimedes (and later on, the new version of Archimedes Repton 3) had this protection method. Easy to bypass too (there's a patch on the Repton Resource Page website for both games).
