RO4Patch & AcornSSL files needed
Daveo
Post by Daveo » Mon May 11, 2020 6:10 pm
Hi.
I was advised by CJE Micros to post my request here, as both CJE Micros & myself have been unable to locate the file anyway online.
I'm after the file named 'RO4Patch' and I think it's used to make some RiscOS 3 software work under RiscOS 4.
I need it to get !65Host working on my RiscPC 700 (ARM 710) with RiscOS 4.39.
It is mentioned on this site, but no link to where to obtain the file, only a link to obtain !PCR13 which makes !65Host work on StrongARM processors (which at the moment, I don't have but possibly a future upgrade).
I need !65Host to access an old teletext software I use to run whilst at college. We ran it on networked BBC Micros and networked A5000 using !65Host.
I also need the file 'AcornSSL' module, which is required to access SSL sites using ArcWeb/NetSurf.
Any help is much appreciated.
- Dave
RiscPC 700 - StrongARM 233MHz, 96MB RAM, 2MB VRAM, Gotek Floppy Emulator Drive & 20GB Hard Disc. 486 DX4-100 PC Card. RiscOS 4.39.
Raspberry Pi 3B - ARM Cortex-A53 1.2GHz (Quad Core), 1GB RAM & 32GB MicroSD. RiscOS 5.27.
acorndave
Re: RO4Patch & AcornSSL files needed
Post by acorndave » Mon May 11, 2020 11:53 pm
I wrote that artcicle for EUG bitd
RO4Patch attached
(take off the. txt extension to use)
The readme is a text file explaining its use
Riscos4PatchReadme.txt
(1.1 KiB) Downloaded 26 times
RO4Patch.txt
(304 Bytes) Downloaded 22 times
Daveo
Post by Daveo » Tue May 12, 2020 1:39 am
Ok, many thanks.
Still also need AcornSSL module tho.
- Dave
helpful
Post by helpful » Tue May 12, 2020 2:41 am
I did wonder if the latest AcornSSL from ROOL would work, but it fails on my RO3.7 setup. I've not got 4.39 setup at the mo to try it on that.
However, you don't need it for NetSurf as that has the SSL library compiled in.
Bryan.
RISC OS User Group Of London - http://www.rougol.jellybaby.net/
RISC OS London Show - http://www.riscoslondonshow.co.uk/
Daveo
Post by Daveo » Tue May 12, 2020 3:19 am
Ok. I've found the program that needs AcornSSL and it's called !FTPc.
Also, what filetype should RO4Patch be as it's a textfile at the moment.
- Dave
matt_nottm
Post by matt_nottm » Tue May 12, 2020 10:22 am
Hi, what is the name of the software that you are trying to get working, it isn't Octave is it?
Daveo
Post by Daveo » Tue May 12, 2020 11:09 am
No, it !65Host and a teletext viewer/editor that I used in college to run the college campusfax service on BBC micros & Acorn A5000s.
- Dave
matt_nottm
Post by matt_nottm » Tue May 12, 2020 12:01 pm
Thanks, if you have time to tell us a bit more or to post some screenshots, I'm sure there will be some interested people.
acorndave
Post by acorndave » Tue May 12, 2020 3:07 pm
filetype for RO4Patch should be Basic (ffb)
Return to “general”
