Issue booting BBC Micro for first time
rkindig
Post by rkindig » Sun Sep 22, 2019 3:38 pm
Hi, I just got a BBC Master 128 and am starting it up for the first time.
It comes to an ADFS prompt and I worked through the steps for resetting the configuration. the *ROMS command works, but the next step says use the *ST command to see the configuration settings. However, when I enter ST nothing happens.
I checked the batteries and they are good.
Any thoughts?
thanks!
Randy
roganjosh
Re: Issue booting BBC Micro for first time
Post by roganjosh » Sun Sep 22, 2019 3:43 pm
*ST is an abbreviation and, as such, needs to end with a full stop i.e. *ST.
Of course you can always use the full command *STATUS
Return to “general”
