SMS with a Beeb?
blackwitch
SMS with a Beeb?
Post by blackwitch »
Hi all.
I was just wondering. An early morning thought.... lol
Is it possible to send and receive SMS text messages through a BBC?
I would have thought it would be but I guess connecting it to a network would be the main problem.
Any thoughts?
lovebug
Re: SMS with a Beeb?
Post by lovebug »
you should be able to use one of these https://www.texim-europe.com/product/SIM800C connected to the serial port through a level shifter
SIM800C-SIMCom.pdf
(1.43 MiB) Downloaded 7 times
Image Image Image
Post by roland »
I played with the module described here: https://raymondtunning.wordpress.com/20 ... -and-data/
It was connected to the Godil serial port of my Atom 2k15 and I managed to get it working. After that I never used it again :lol:
johnkenyon
Post by johnkenyon »
blackwitch wrote:
Fri Sep 24, 2021 6:30 am
Hi all.
Any thoughts?
Use an old Nokia or SonyEricsson phone - many of these had serial interfaces with a MAX232 style converter in the serial lead to convert to true RS232.
As far as sending SMS is concerned, look at the source code for Gnokii.
Note that by "old" I'm talking about pre-2005ish, phones which never came with a USB cable.
SonyEricsson T610, T630, K700 all have serial interfaces - a look at https://www.developershome.com/sms/gnokiiIntro.asp lists other models which might have a serial interface.
lovebug
Post by lovebug »
using an old phone maybe an issue as I think that 3G is gonna be shut off by 2023
even the link i posted to the sim800c module only supports up to 4G which will eventually be phased out but it should be around for a while to come
Image Image Image
johnkenyon
lovebug wrote:
Mon Sep 27, 2021 8:30 pm
The old phones I mentioned are 2G only. 2G will outlive 3G due to better range, and its ability to provide slow but reliable data service (e.g. hand held card terminals) and to allow for fallback for voice. (So you can still make that 999 call with no 3/4/5G signal)
Some 2G bandwidth is being pulled for newer stuff, but not all of it.
lovebug
Post by lovebug »
ah ! thats great news :D
Image Image Image
Return to “general”
