Defects on ADFS floppies
bjn
Post by bjn »
If...
- a "verify" operation finds defects
- they're all in the last few pixels of the progress bar
- the "free" dialogue says there's some free space
- all files happily copy from the floppy to the hard drive
are the defects likely in free space? Is everything likely fine?
Could the defects even be part of some fancy copy protection? ("Attempt to read sector x; if it succeeds, then this isn't a legit copy" -- I've heard of stuff like this being done on Amiga games or similar.)
Re: Defects on ADFS floppies
Post by danielj »
If you do a *MAP on the floppy it should say where the free space is (but it's likely to be towards the end!) - if you didn't get an error when copying you should be fine.
Certainly there are a number of varieties of copy protection that'd cause a disk to fail to verify - and quite often these are on high numbered tracks. If this is commercial software I'd suspect copy protection. Give an example?
bjn
Post by bjn »
danielj wrote:
Fri May 22, 2020 1:24 pm
Excellent, thanks. I'll give that a try next time I come across such a disk.
The one which prompted me to ask was the game Magic Pockets.
Post by danielj »
Games, it'll probably be copy protection assuming the game itself appears to work ok...
geraldholdsworth
Post by geraldholdsworth »
bjn wrote:
Fri May 22, 2020 1:19 pm
EGO: Repton 4 on the Archimedes (and later on, the new version of Archimedes Repton 3) had this protection method. Easy to bypass too (there's a patch on the Repton Resource Page website for both games).
Gerald Holdsworth
www.reptonresourcepage.co.uk
Return to “general”
