Today I received.....
Re: Today I received.....
Post by IanS » Fri Feb 08, 2019 2:11 pm
robcfg wrote:
Fri Feb 08, 2019 1:42 pm
I don’t know if the BBC Micro has RGB output (easy way) or not (not so easy way).
The easy way would just require a cable and/or small adapter, while the not so easy one some kind of composite to RGB converter, plus the cable.
BBC does have RGB output.
BBC RGB output is TTL ~0-5v
CPC RGB output is not TTL ~0~1v
So you should just be able to add the usual resistors required for a SCART cable.
(I have seen Amstrad Colour monitors plugged straight into a BBC, it does work, it gives a very bright picture, and is not recommended)
The middle pin on the BBC RGB connector is 5v, which is ignored by the CPC colour monitor. Don't try this with an Amstrad green screen, it uses the middle pin for luminance.
Post by Lardo Boffin » Fri Feb 08, 2019 2:21 pm
jonb wrote:
Fri Feb 08, 2019 11:00 am
I have two 6128s (one broken, one working) and while they are "good" in the sense of being well rounded machines, they're also quite slow compared to their contemporaries (quite a few of which I also have). "Slow" in the "subjective user experience" sense of the word.
I only got it yesterday so not fully up to speed with it but Elite is certainly sluggish on it - although there is no line flicker which is a bonus. :D
USA Model B
Post by 1024MAK » Fri Feb 08, 2019 2:52 pm
The Z80 CPU runs at 4MHz (which is a bit faster than a ZX Spectrum), but the amount of screen data that has to be shifted around does take up a fair wack of the CPUs time.
Games written for the CPC are obviously optimised for it. Ported games are often versions ported from the ZX Spectrum, and with some of these, minimal changes were made and screen and sound converter code added. So these can run a bit slow.
Post by RobC » Fri Feb 08, 2019 3:30 pm
And it's more like 3.3MHz once the wait states/cycle rounding is taken into account.
jonb
Post by jonb » Fri Feb 08, 2019 4:21 pm
vanpeebles wrote:
Fri Feb 08, 2019 11:26 am
Don't suppose you would fancy a trade for a ton of acorn magazines, cover discs, and anything else I can bundle in? :)
Hmmm let me think... [-(
Now the broken one, that is a different story. I am pretty sure it is repairable, but I have not got round to it yet. @1024MAK : Hey Mark, maybe I should open another epic repair thread..?
[Edited to add: Attempted repair discussed here back in June 2013: http://www.cpcwiki.eu/forum/amstrad-cpc ... n-startup/. Can't believe that was 5 1/2 years ago!]
vanpeebles
Post by vanpeebles » Fri Feb 08, 2019 6:14 pm
I’ll thrown in a load of old computing books too, one has a PET on the cover :lol: A right good box of all kinds, and I’ll pay postage for both sides?
Post by tricky » Sat Feb 09, 2019 2:22 pm
A very neat boo-bip EEPROM and a "purple board" to help me to diagnose all my dodgy beebs ;)
Post by flaxcottage » Sat Feb 09, 2019 5:03 pm
Interesting. What is this 'purple board' then. Pray do tell. [-o<
Post by cmorley » Sat Feb 09, 2019 5:09 pm
It's a USB adapter. In conjunction with the little interface board I did (which Richard will post a photo of on... Tuesday... 'nuff said! :oops: ) & hoglet's 6502 bus decoder software you can log the execution of a model B to a PC. Look at the instruction trace & diagnose the long beep :)
viewtopic.php?f=3&t=14398&hilit=ftdi
Post by flaxcottage » Sat Feb 09, 2019 6:08 pm
Thanks, Chris. :D
LordVaderUK
Post by LordVaderUK » Sun Feb 10, 2019 3:05 am
A somewhat battered Microvitec CUB monitor... sadly forgot to order a cable so I can’t try it with the Beeb yet, it switches on without going bang and emitting magic smoke though... despite the incredibly poor packaging 😬
And a DataCentre courtesy of Mark from RetroClinic, haven’t had time to fit it yet but I’ve read the rather lovely manual that comes with it!
Commie_User
Post by Commie_User » Sun Feb 10, 2019 7:27 pm
That screen looks ugly. Are you sure you can repair the glass?
LordVaderUK
Post by LordVaderUK » Sun Feb 10, 2019 8:46 pm
Just reflections in the photo - the glass is in undamaged condition, the metal case is a little battered...
Commie_User
Post by Commie_User » Tue Feb 12, 2019 9:15 pm
Are you sure??
Oh yeah! :D
marcusjambler
Post by marcusjambler » Wed Feb 13, 2019 5:09 pm
A TMS 320C25 Dev System for a BBC user port...
VectorEyes
Post by VectorEyes » Wed Feb 13, 2019 5:37 pm
I saw that on eBay!
What is it? What does it do? Enquiring minds want to know!
marcusjambler
Post by marcusjambler » Wed Feb 13, 2019 6:01 pm
This enquiring mind also wants to know :lol:
No software or documentation as of yet...
johnkenyon
Post by johnkenyon » Wed Feb 13, 2019 7:05 pm
The TMS320 is a series of digital signal processors. (aka DSP)
You've probably bought yourself a programmable audio filter. You'll have fun getting that working with no docs...
marcusjambler
Post by marcusjambler » Wed Feb 13, 2019 7:14 pm
Thats what I was guessing.... I've found some docs and a paper written by an under grad in the late 80s that includes example code for the BBC and IBM PC...
So long as no ROM is required I should be able to run the code and give it a go with one of my vocal mics, ZOOM16 DAW and reaper/cubase.... :lol:
Assuming its actually working.... :shock:
I'll probably start with a sig gen and scope....
Marcus
Post by flaxcottage » Wed Feb 13, 2019 8:07 pm
Thermal printer rolls
A clutch of thermal paper printer rolls for my Texas PC100C printer cradle. The printer works with my TI-58 and TI-59 calculators. This printer uses paper 63mm wide, which is now obsolete. New old stock paper does appear from time to time but is horrendously expensive.
These are 60mm wide. Still obsolete but still available. Not only that but the paper is much more sensitive and has 'black ink' rather than the 'blue ink' of the originals. The output is superb. :D
I might even type in the TI-59 Star Trek game from the August 1979 edition of Computing Today. :lol:
Post by daveejhitchins » Thu Feb 14, 2019 8:41 am
Received yesterday:
I'm preparing a very special Electron for John.
I wonder if I'll have any luck asking my ex partner, Dave Prosser, if he has the FPGA script . . . . [-o< :?
myelin
Post by myelin » Thu Feb 14, 2019 6:27 pm
Received yesterday:
Ooh... if you do manage to get it, I’d be Interested to help with the PCB design for a recreation project!
mr-macrisc
Post by mr-macrisc » Thu Feb 14, 2019 6:31 pm
Received yesterday:
Glad it arrived safe and sound and hopefully it proves to be useful :)
John
