Absolute best adventures?
0xC0DE
Post by 0xC0DE » Wed Mar 27, 2019 9:01 pm
I remember playing some text adventure games on the Electron when I was a kid. I don't remember the names however.
What do you consider to be the absolute top 5 text adventure games on the Electron?
And on the beeb?
I'm ready to dive back in.
0xC0DE
Visit my YouTube channel featuring my demos for Acorn Electron and BBC Micro
Lardo Boffin
Re: Absolute best adventures?
Post by Lardo Boffin » Wed Mar 27, 2019 9:06 pm
Twin Kingdom Valley has to be number one for me. Probably because I managed to finish it with a perfect score BITD. 8)
Atom, issue 5
USA Model B
0xC0DE
Post by 0xC0DE » Wed Mar 27, 2019 9:16 pm
Going straight to my list of "text adventures to play" :mrgreen:
0xC0DE
trixster
Post by trixster » Thu Mar 28, 2019 11:14 am
I think the Level 9 ones take some beating.
Lancelot is brilliant but requires a Master or beefed-up Beeb to really appreciate. Not sure if there was an Elec version.
Post by lurkio » Thu Mar 28, 2019 12:02 pm
For my inevitable answer, see my avatar pic and the last link in my signature.
0xC0DE
Post by 0xC0DE » Thu Mar 28, 2019 3:39 pm
Thanks for the suggestions!
Those Level 9 adventures look very interesting. As far as I can tell, not many of them are actually available on the Electron (which is my favorite Acorn machine :mrgreen:). But it also looks like many of them (Lancelot, for instance) are text only? Broad assumption here but it shouldn't be too hard to port to the Electron? I read on this forum that jgharston converted many text adventures to the Atom even. I might be willing to try to port some to the Electron myself.
0xC0DE
Post by hoglet » Thu Mar 28, 2019 3:51 pm
The issue is going to be memory, as the Electron doesn't have Mode 7. Most of the adventures use pretty much available RAM (right up to &7BFF).
The options for gaining more memory are:
- use a Jafa Mode 7 adapter (very rare)
- use a Master RAM Board (MRB)
- use a AP5 plus a 6502 Second Processor
With any of these, they should actually just work, because they are legally written and only use a small number of standard MOS calls.
Incidentally, it was me that ported all the Level 9 adventures to the Atom, and this was only possible with an Atom with a 32KB RAM expansion card. You can read more about this here:
viewtopic.php?t=6483
They are all present in the Atom Software Archive:
0xC0DE
Post by 0xC0DE » Thu Mar 28, 2019 3:59 pm
That was indeed the thread I read today. Don't know how my brain turned hoglet into jgharston, whoops! :oops:
0xC0DE
fuzzel
Post by fuzzel » Thu Mar 28, 2019 6:08 pm
My favourites (from memory) are:
Level 9: Lords of Time (easy / medium difficulty) and Colossal Adventure (medium difficulty)
Acornsoft: Kingdom of Hamil (medium) and Countdown to Doom (hard)
Robico: Escape from Enthar Seven (medium)
Magus: Village of Lost Souls (hard), What's Eeyores (hard), Locks of Luck (v. hard but brilliant, biased because I solved it)
Epic: Wheel of Fortune (easy to medium)
Bug-Byte: Twin Kingdom Valley (medium)
I'm not sure which if any will play on the Electron
rmbrowngr
Post by rmbrowngr » Thu Mar 28, 2019 6:11 pm
After recent experience with the MRB I would think a better way to get memory, using assembly for coding and not basic, would be with AP5 and second processor.
Richard B
Acorn Electrons issue 4 and issue 6 with Master RAM Board, Acorn Plus 1, AP6, AP5, Pegasus 400, BeebSCSI, Gotek, Raspberry Pi 2nd Processor, GoSDC MBE with Elk2GoSDC and Cart2GoSDC.
BBC B+ 64K (128K upgraded) with Duel OS
rmbrowngr
Post by rmbrowngr » Thu Mar 28, 2019 6:18 pm
BTW, I vote for Twin Kingdom Valley and The Lost Crystal http://www.acornelectron.co.uk/eug/sols ... l_000.html
I remember a nice little adventure from Electron User, but I can’t remember what’s it called.
I always wanted the Hobbit on the Electron, but I think it was never released on this platform. One of the things on my long list of things I would like to work on.
Richard B
Post by hoglet » Thu Mar 28, 2019 6:43 pm
Indeed...
In case anyone is brave enough to try, I've just done a bit more digging.
The Level 9 adventures use just the following OS calls:
- OSWRCH
- OSRDCH
- OSWORD0
- OSBYTE
- OSFILE
Of these, only OSWORD0 and OSFILE use memory parameter blocks that might be problematic with a MRB, depending on where the block is located.
The OSWORD0 block is located at &0037 in all cases, so won't be a problem.
The OSFILE block is less consistent:
- Colossal Adventure uses &0037
- Adventure Quest uses &0037
- Dungeon Adventure uses &0037
- Snowball uses &0037
- Return to Eden uses &7AC0
- Worm in Paradise uses &1B12
- Lords of Time uses &0037
- Red Moon uses &766C
- The Price of Magik uses &1B12
So the ones in bold above will be problematic with the MRB. Specifically, SAVE and RESTORE would fail in those two cases, as the shadow screen memory would get used. But the rest should just work.
I have a MRB, so I might give this a try.
Dethmunk
Post by Dethmunk » Sat May 18, 2019 10:18 pm
For me I'd say on the Electron....
Twin Kingdom Valley
The Lost Crystal
Wheel of Fortune
Rick Hanson (trilogy) :wink:
You might like my Darkness of Raven Wood (although its not the absolute best adventure on Electron for sure) :D
0xC0DE
Post by 0xC0DE » Sat May 25, 2019 6:55 pm
Thanks for all the suggestions. I will try all of them.
0xC0DE
8bitAG
Post by 8bitAG » Sun May 26, 2019 9:02 am
In terms of homegrown Quilled games, I believe the Larry Horsfield games such as Magnetic Moon were quite well thought of. I'm more familiar with the later (larger) PAWed Spectrum conversions.
