Disassembly of Superior Software's Stranded
tautology
Post by tautology » Thu May 09, 2019 9:18 pm
I've put up the (80%) commented disassembly of Superior's Stranded that I've been working on for the past week. It's not quite complete, but I could probably write an interpreter for it with what I know (including graphics).
It's not the best adventure, but the way it does messages, rooms and object logic is interesting.
It's also the first one that I've used Ghidra fully for, which does make it easier than my old tactic of exporting from 6502dis and search and replace.
Anyway disassembly as a .html file and a simple Python script to export the messages/rooms can be found at: https://github.com/tautology0/textadven ... r/Stranded
I will put this up as a blog post at some point.
Re: Disassembly of Superior Software's Stranded
Post by lurkio » Sat May 11, 2019 6:44 pm
:shock: =D> =D>
This is great! Very intriguing.
An explanation of how it draws graphics would be interesting.
Do tell! I probably won't understand it all, but I'll have a good go!
Any tips on setting up Ghidra..? Not that I really have the skills to go into a disassembling frenzy, but others might, perhaps.
Github doesn't seem to let hosted HTML pages be rendered in-browser, so I've (temporarily?) put the disassembly up on AWS for those interested in having a look:
Please do!
=D> =D>
tautology
Post by tautology » Sun May 12, 2019 9:54 pm
Unfortunately I've got a couple of weeks of busyness so won't have time to do much more on it, but to answer some questions:
Graphics are plotted with OSWRCH statements, using VDU 25. They stored in a compressed fashion as described below. The graphics window is set to be &80 - &480, &1c0 -&3c0; this makes it possible to stored X and Y in a byte each. Each instruction is:
byte mode: the mode of command ( 0 = DRAW, 2 = MOVE, 5 = FILL, 7 = TEXT). The first two bits are the background colour
byte X: X co-ord << 2
byte Y: Y co-ord << 2
There are extra bits for FILL and TEXT which I didn't quite work out, but will be revisiting.
The strangeness is that way that rooms, messages and commands are implemented. Normally rooms and messages are separate data structures. In this there's a base of messages with a flag to say that this message is a room. Each room has a set of simplistic byte code to tell it what to do with a certain command. For example:
01 01       NORTH: GO(1)
C1 07 04    If verb 07 and have parachute in inventory goto 04
81 07 07    If verb 07 and not have parachute in inventory goto 07
Where the destination may have its own code. It's very strange and took me a while to work out.
I've got blog post half written, but had to put it on hold whilst I did a few work and home life things.
tautology
Post by tautology » Thu Jun 06, 2019 10:39 pm
I've updated my decode script (in python) and added a JSON version of the decoded data; this shows the weird way it does rooms and messages.
For example:
			"location": 21,
			"message": "17 (You are in the main control room. There is a slot for a fuel capsule and a lever.)",
			"image": 8,
			"flags": 3,
			"actions": ["IF VERB=NORTH GOTO 18", "IF VERB=PULL LEVE AND INROOM(FUEL) GOTO 23", "IF VERB=PULL LEVE AND INROOM(FUEL) GOTO 22"]
			"location": 22,
			"message": "18 (Nothing happens. You notice that a fuel gauge shows zero.)",
			"image": 0,
			"flags": 0,
			"actions": ["GOTO 21"]
sirbod
Post by sirbod » Fri Jun 14, 2019 3:01 pm
I used Ghidra to strip off the manual based protection from the Arc version of Simon the Sorcerer a few months back. I'd previously spent many days trying unsuccessfully to remove it via assembler dumps / code tracing, but it only took a few hours with Ghidra - a very useful piece of software, I especially like the ability to name functions and the way it previews sub functions if you hover over the branch.
