JSBeeb ROM format
dagewa
JSBeeb ROM format
Post by dagewa »
Hi folks,
Does anyone know what format file JSBeeb expects for a ROM? I put some of the files from http://www.flaxcottage.com/BBC_ROMS/Default.asp under the roms/ directory on a forked copy of jsbeeb, but when I try to load any of them with the ?&rom= parameter I just got the message:
Error: Broken rom file
I started a (probably doomed) quest to use JSBeeb to explore a disc of InterWord files. I saw some old messages about emulators not being able to run InterWord because of the unusual format of the ROM. Is that still the case?
David
Pernod
Re: JSBeeb ROM format
Post by Pernod »
dagewa wrote:
Wed Jun 09, 2021 7:43 pm
They are not ROM files, they are disk images containing ROM files. You'd have to first extract the ROM image from the disk image.
Only MAME is currently capable of running InterWord.
dagewa
Post by dagewa »
Right thanks, I'll give up on the JSBeeb quest for now.
