Mode 7 at 3C00 on the B+
Post by Coeus »
SteveF recently made me aware that, on a Model B at least, it is possible to relocate the Mode 7 screen to 3C00. I am not sure if this is intentional or just a quirk but one of the bits of the memory address lines from the 6845, MA11, still makes it through to the RAM as the most significant bit when the next three less significant its are all fixed at '1'. There is more detail at: http://beebwiki.mdfs.net/Address_translation
I now have a patch for B-Em to implement this but I'd like to confirm whether this works on a B+ as, while I am working on it, it would be nice to have it completely right. Unless the answer is already documented could someone run a test program on a B+, please. See: viewtopic.php?f=54&t=20149#p282406 where an SSD with the program can be downloaded and confirm if the Mode 7 relocation is possible on the B+ or not.
rmbrowngr
Re: Mode 7 at 3C00 on the B+
Post by rmbrowngr »
Happy to try it, but it’ll have to wait until Tuesday or Wednesday next week when I’m back home. If no one else has tried it by then.
Richard B
Post by Coeus »
rmbrowngr wrote:
Fri Aug 07, 2020 5:20 pm
Thanks.
rmbrowngr
Post by rmbrowngr »
Ran the disk and I get themessage "Sorry BBC B only!".
Richard B
Post by Coeus »
rmbrowngr wrote:
Wed Aug 12, 2020 3:28 pm
Oh dear - that message is just checking what type of machine it is running on, not whether this mode 7 trick actually works. Could you try in again, please but instead of doing shift-break do:
> LOAD "M7-3C00"
> 3
> RUN
i.e. delete the machine-type test so the program attempts to put Mode 7 at 3C00 anyway. If it works you should get:
If it doesn't work you may get this:
or maybe something else.
rmbrowngr
Post by rmbrowngr »
Will try again with your instructions when back home again. On the beach, away from home.
Richard B
rmbrowngr
Post by rmbrowngr »
Coeus wrote:
Wed Aug 12, 2020 4:49 pm
> LOAD "M7-3C00"
> 3
> RUN
Here's the result, which is not what you where hoping for:
Machine config
Richard B
Post by jgharston »
On real hardware, when the teletext hardware is selected, address lines A10-A13 are all tied to '1', so unless the top 16K RAM is physical absent, the CRTC will always see 7C00-7FFF. The model A only sees 3C00-3FFF because there is physically nothing present at 4000-7FFF and address line A13 is ignored.
Post by Coeus »
rmbrowngr wrote:
Thu Aug 20, 2020 6:46 pm
Thanks for doing the test, Richard. I am not trying to use this trick on a BBC B+ myself it is more a case that Steve F was doing something with it and reported that B-Em was not emulating it correctly. So we got to the point we knew the trick did work on a BBC B and didn't work on a Master but we didn't know about the B+. So now, thanks to your help, I can make the B+ emulation in B-Em behave like a real B+ (which for this is the same as the Master).
Post by Coeus »
jgharston wrote:
Thu Aug 20, 2020 6:54 pm
I think we did some tests and concluded that the OS still writes to 7C00-7FFF on a Model A and takes advantage of partial address decoding as you imply to display the last 1K of the 16K present but this trick is not quite the same as that.
What is behind this trick is that while A10-A13 are set to one, A14 is not, it comes from the screen address wrap-around circuit and can tus be manipulated. See: http://beebwiki.mdfs.net/Address_translation#TTX_VDU
Post by Coeus »
Coeus wrote:
Thu Aug 20, 2020 7:44 pm
So checking the circuit diagram, IC36 transforms the C0,C1 values from IC32 to produce the B inputs to the adder IC39 with the A inputs coming from MA8-MA11 of the 6845. While the sum outputs S1-S3 only go to IC9 which is specific to the HiRes (bitmap) column address, S4 goes to IC28. IC28 is using the phase of the clock to select what is determining which RAM bank to use - on one phase it is the CPU A14 and on the other it is S4 from IC39 (the adder).
