beeben save preferences
Rfairman
Post by Rfairman » Sat Aug 31, 2019 9:42 am
Beebem gives an error when trying to Save preferences
"failed to save Preferences.cfg"
Any ideas
regards
Richard
billcarr2005
Re: beeben save preferences
Post by billcarr2005 » Sat Aug 31, 2019 9:47 am
Could depend on your Windows settings?
You might need to run BeebEM as an administrator?
Rfairman
Post by Rfairman » Sat Aug 31, 2019 10:09 am
I had to change the read/ write option for the folder where preferences.cfg is saved
Is there way of making beebem default to look at where my ssd files are saved
regards
Richard
guesser
Post by guesser » Sat Aug 31, 2019 10:35 am
When you installed BeebEm did you create your user settings directory in a protected location (like under C:\Program Files etc)?
This should be somewhere where you can modify files without elevation, usually your own user profile (i.e. below C:\users\<foo>\)
You can change the user directory associated with your user profile from within BeebEm via Options->Preference Options->Select User Data Folder
guesser
Post by guesser » Sat Aug 31, 2019 10:43 am
There's a DiscIms setting in the preferences.cfg but it seems like it gets ignored and reset to DiscIms. This seems like a bug to me.
Edit: found it, there's a single character typo in the source. I've raised an issue for it on github
Post by chrisn » Sat Aug 31, 2019 12:26 pm
Thanks! This is now fixed and I have published new beta release: https://github.com/stardot/beebem-windo ... tag/4.15b3
Rfairman
Post by Rfairman » Mon Sep 02, 2019 10:11 am
Thnks now works great
regards
Richard
