6522 VIA emulation: PB7 toggling vs. PB7 mode
scarybeasts
Post by scarybeasts » Mon Dec 31, 2018 9:21 am
Simple test case VIA.PB2 (in attached SSD or pasted below via the magic of *SPOOL and bbcim). Probably not a very significant test case but I mentioned to Tom I'd put it together. MAME is the only emulator that gives 128 (as opposed to 0) and I suspect MAME has it right but we'll see.
Chris
   10 REM RESULTS FROM DEC 2018
   20 PRINT "VIA TEST: DOES PB7 TOGGLE IF ACR NOT IN PB7 MODE?"
   30 DIM MC% 256
   40 DIM R% 16
   50 P% = MC%
   60 [
   70 OPT 3
   80 SEI
   90 LDA #&FF
  100 STA &FE62
  110 LDA #&00
  120 STA &FE60
  130 LDA #&7F
  140 STA &FE6E
  150 LDA #&80
  160 STA &FE6B
  170 LDA #&03
  180 STA &FE64
  190 LDA #&00
  200 STA &FE65
  210 STA &FE6B
  220 NOP
  230 NOP
  240 LDA #&80
  250 STA &FE6B
  260 LDA &FE60
  270 STA R%
  280 CLI
  290 RTS
  300 ]
  310 CALL MC%
  320 REM B-EM: NO: 0
  330 REM B2: NO: 0
  340 REM BEEBEM: NO: 0
  350 REM JSBEEB: NO: 0
  360 REM MAME: YES: 128
  370 PRINT ?(R%)
tests.ssd
(100 KiB) Downloaded 11 times
Re: 6522 VIA emulation: PB7 toggling vs. PB7 mode
Post by BigEd » Mon Dec 31, 2018 9:27 am
Here you go, Beeb says this:
>RUN
1B26
1B26          OPT 3
1B26 78       SEI
1B27 A9 FF    LDA #&FF
1B29 8D 62 FE STA &FE62
1B2C A9 00    LDA #&00
1B2E 8D 60 FE STA &FE60
1B31 A9 7F    LDA #&7F
1B33 8D 6E FE STA &FE6E
1B36 A9 80    LDA #&80
1B38 8D 6B FE STA &FE6B
1B3B A9 03    LDA #&03
1B3D 8D 64 FE STA &FE64
1B40 A9 00    LDA #&00
1B42 8D 65 FE STA &FE65
1B45 8D 6B FE STA &FE6B
1B48 EA       NOP
1B49 EA       NOP
1B4A A9 80    LDA #&80
1B4C 8D 6B FE STA &FE6B
1B4F AD 60 FE LDA &FE60
1B52 8D 27 1C STA R%
1B55 58       CLI
1B56 60       RTS
       128
scarybeasts
Post by scarybeasts » Mon Dec 31, 2018 6:56 pm
Thanks! Victory to MAME.
Pernod
Post by Pernod » Mon Dec 31, 2018 7:49 pm
Apparently there are some known issues with the MAME implementation, there's an ongoing re-write in some branch somewhere.
