6522 VIA emulation: ACR writes
scarybeasts
Post by scarybeasts » Sat Dec 29, 2018 7:43 am
I noticed that MAME and b2 both have code that re-arms the T1 interrupt if ACR is written and continuous mode selected. The other emulators don't have that quirk so I set about writing a test case to see which behavior is correct.
In the process, the test case also uncovered another really interesting test case where e.g. jsbeeb and b2 differ: what happens if IFR is read in the same VIA cycle that the interrupt is raised (timer reload)? As a bonus test, the test also attempts to discern whether writing ACR will reset PB7 in addition to re-arming T1.
Of the 5 emulators tested, there were 4 different answers. I expect the real BBC may give a 5th different answer still; we'll see. If someone could run VIA.AC1 from the attached SSD on a real beeb that would be enlightening.
If anyone was feeling particularly adventurous, running the test a second time but with the modification:
280 LDA #&80
would also be interesting. This should test whether writing ACR from one-shot to one-shot re-arms the timer. The emulators don't do anything for that case but there's the chance the real silicon isn't nuanced and just re-arms the timer for any ACR write.
I will attempt to interpret the results for the purposes of better emulation -- there's a lot going on in this particular test case.
Chris
tests.ssd
(100 KiB) Downloaded 16 times
Re: 6522 VIA emulation: ACR writes
Post by BigEd » Sat Dec 29, 2018 11:47 am
(Edit: perhaps see also the other thread, 6522 VIA emulation: T1LH writes vs. T1 interrupt)
Here you go, by the miracle of copy and paste over the serial line:
>L.
   10 REM RESULTS FROM DEC 2018
   20 PRINT "VIA TEST: DOES ACR WRITE RESTART TIMER?"
   30 DIM MC% 100
   40 DIM R% 16
   50 P% = MC%
   60 [
   70 OPT 3
   80 SEI
   90 LDA #&FF
  100 STA &FE62
  110 LDA #&00
  120 STA &FE60
  130 LDA #&7F
  140 STA &FE6E
  150 LDA #&80
  160 STA &FE6B
  170 LDA #&04
  180 STA &FE64
  190 LDA #&00
  200 STA &FE65
  210 NOP
  220 NOP
  230 NOP
  240 LDA &FE6D
  250 STA R%
  260 NOP
  270 NOP
  280 LDA #&C0
  290 STA &FE6B
  300 LDA &FE64
  310 STA R%+1
  320 LDA &FE6D
  330 STA R%+2
  340 LDA &FE60
  350 STA R%+3
  360 CLI
  370 RTS
  380 ]
  390 CALL MC%
  400 REM B-EM: 0, 0, 0, 128
  410 REM B2: 0, 0, 64, 128
  420 REM BEEBEM: 0, 0, 64, 128
  430 REM JSBEEB: 64, 0, 0, 128
  440 REM MAME: 0, 248, 0, 128
  450 PRINT ?(R%)
  460 PRINT ?(R%+1)
  470 PRINT ?(R%+2)
  480 PRINT ?(R%+3)
>RUN
1BBF
1BBF          OPT 3
1BBF 78       SEI
1BC0 A9 FF    LDA #&FF
1BC2 8D 62 FE STA &FE62
1BC5 A9 00    LDA #&00
1BC7 8D 60 FE STA &FE60
1BCA A9 7F    LDA #&7F
1BCC 8D 6E FE STA &FE6E
1BCF A9 80    LDA #&80
1BD1 8D 6B FE STA &FE6B
1BD4 A9 04    LDA #&04
1BD6 8D 64 FE STA &FE64
1BD9 A9 00    LDA #&00
1BDB 8D 65 FE STA &FE65
1BDE EA       NOP
1BDF EA       NOP
1BE0 EA       NOP
1BE1 AD 6D FE LDA &FE6D
1BE4 8D 24 1C STA R%
1BE7 EA       NOP
1BE8 EA       NOP
1BE9 A9 C0    LDA #&C0
1BEB 8D 6B FE STA &FE6B
1BEE AD 64 FE LDA &FE64
1BF1 8D 25 1C STA R%+1
1BF4 AD 6D FE LDA &FE6D
1BF7 8D 26 1C STA R%+2
1BFA AD 60 FE LDA &FE60
1BFD 8D 27 1C STA R%+3
1C00 58       CLI
1C01 60       RTS
        64
         0
         0
       128
And with the modification:
>L.280
  280 LDA #&C0
>280 LDA #&80
>RUN
1BBF
1BBF          OPT 3
1BBF 78       SEI
1BC0 A9 FF    LDA #&FF
1BC5 A9 00    LDA #&00
1BCA A9 7F    LDA #&7F
1BCF A9 80    LDA #&80
1BD4 A9 04    LDA #&04
1BD9 A9 00    LDA #&00
1BDE EA       NOP
1BDF EA       NOP
1BE0 EA       NOP
1BE7 EA       NOP
1BE8 EA       NOP
1BE9 A9 80    LDA #&80
1C00 58       CLI
1C01 60       RTS
        64
         0
         0
       128
Post by Coeus » Sat Dec 29, 2018 5:40 pm
So the discrepancy for B-Em is in the first value. What seems to be going on here is that the timer has not expired in time so when the IFR is read it still contains zero for the T1 timer bit.
This does seem very similar to the previous thread on VIA strangeness. In this case the STA is implemented as follows:
                case 0x8D:      /*STA abs */
                        addr = getw();
                        polltime(4);
                        takeint = (interrupt && !p.i);
                        writemem(addr, a);
                        break;
so it appears that some of the time for the final write to memory is already accounted for, i.e. the VIA is now 1 2Mhz tick ahead of the CPU then, during writemem, the extra 1 or 2 2Mhz cycles due to clock stretching are accounted for before the write actually happens, i.e. before the VIA receives the timer value.
The NOPs are unremarkable:
                case 0xEA:
                        /*NOP*/
                        polltime(2);
                        break;
Then there is the subsequent absolute load which was mentioned in the other thread:
                case 0xAD:      /*LDA abs */
                        addr = getw();
                        polltime(4);
                        a = readmem(addr);
                        setzn(a);
                        break;
So, once again, some of the time for the read from the I/O address is already accounted for in the polltime(4) and again, the extra cycles due to cycle stretching are accounted for before calling the VIA emulation to read the register. The VIA emulation is called separately to update timers from within polltime().
So, in theory the VIA should always be ahead but then the VIA emulation is testing for a timer value of "< -3" for the timer to expire not, "< 0". Partly that is because the timer values as held in the VIA structure are actually 2x the real value to enable 2Mhz cycles to be subtracted directly from them but that still seems to leave a fudge factor, presumably to compensate for the VAI being a little ahead of the CPU, except in this case it seems to be be over-compensating. Presumably it was fudged to make sure it gave the right result in a particular case that was used in a game.
scarybeasts
Post by scarybeasts » Sun Dec 30, 2018 7:15 am
Thanks again BigEd / Coeus!
And some instructive / interesting results.
In terms of what I was trying to test: this seems to show that writing ACR doesn't have any special behavior such as re-arming timers. This again is the simpler result and suggests a simplification fix can be applied to b2 / MAME.
The most interesting result, though, is that first number which shows that IFR is visible to the 6502 read the same cycle the interrupt is fired. This suggests that the read result exposed to the 6502 is the 6522 state at the 6522 mid-cycle or even end cycle. Definitely has key implications for the ordering of 6502 time advance vs. 6522 time advance in emulators.
This result also suggests some obvious follow-on tests such as, what if IFR is written to clear it in the same cycle as the IFR is raised due to timer expiry? Which wins? I'll code it up...
Chris
Post by BigEd » Sun Dec 30, 2018 9:42 am
It would be great to have a sort of regression test which checks out lots of obvious and non-obvious VIA behaviour. Presumably at present some of the copy-protection code is used as an acid test?
Post by Coeus » Sun Dec 30, 2018 10:07 am
This seems to be heading on the direction of discovering to what extent the 6522 uses synchronous logic. It is usual to suppose that anything moderately complex that has a clock input is mostly synchronous but there seems to be no obvious rreason why simple combinational logic should be made synchronous if that does not serve any purpose. I wonder if the IFR is actually a real register at all, in the sense of having storage that is updated all together at a particular point in time, or whether it is instead the collected output of various other parts of the circuit that work independently, prersented as an 8bit value for the convenience of the CPU.
Post by Coeus » Sun Dec 30, 2018 10:13 am
In which case it would be good to know which games and where a suitable version can be obtained. If it is copy protection code that is the test it would obviously be pointless to test a version of the game that has been hacked to remove that. In theory it should be possible to distill what the copy protection is doing into a stand-alone test.
It is partly not having a regression test to hand that stops me diving in to change this. Unlike functional changes, i.e. the other thread, if the way the timing works is not exact due to limited precision there is the possibility that fixing one case breaks another.
Post by BigEd » Sun Dec 30, 2018 11:37 am
It might be fruitful to review some of the threads around Kevin Edwards' protection systems (including his own posts in those threads) - I had an idea there were some code fragments shared which could form the basis of a test suite, but it's been a while.
viewtopic.php?p=4628#p4628
viewtopic.php?p=4855#p4855
viewtopic.php?p=204344#p204344
Post by Coeus » Sun Dec 30, 2018 12:51 pm
So the first issue for testing this with an actual tape image of Nightshade is that the Acorn Preservation site mentioned seems to have gone, replaced with a parked domain site. Is that archive now somewhere else?
tom_seddon
Post by tom_seddon » Sun Dec 30, 2018 12:59 pm
Rich T-W's prototype emulator has some Kevin Edwards protection test cases, including tape Nightshade I think: viewtopic.php?f=4&t=16138&p=222137#p222137
--Tom
tom_seddon
Post by tom_seddon » Sun Dec 30, 2018 1:22 pm
In b2's case, I assume this will be this recent change, which I added to sort out some horrid-looking scrolling in Planetoid, after being inspired by your T1/PB7 thread to look at it again. I don't remember the details, but (as I recall...) the lack of re-arming behaviour, that I noticed MAME had (and b2 didn't), was a perfect fit for the symptoms, so I added it in, trusting it was correct :)
Since Planetoid scrolls fine on B-em, which doesn't do this, I expect it is actually redundant. And the logic doesn't make a great deal of sense anyway. And judging by a quick glance at a Planetoid instruction log I've still got, it not only runs T1 in 1-shot mode, but also seems to re-write the value each time, so now I'm not sure what the original problem would have been any more.
I'll post again once I've had another proper look, if the results are at all interesting.
--Tom
Post by Coeus » Sun Dec 30, 2018 1:28 pm
Ok, so Rich's emulator it ahead on b-em in being able to run automated tests like this. Saving the nighshade code into a file and running under B-Em it with breakpoints set at both the success and failure addresses gives success either with or without the T1LH fix from the other thread.
Post by BigEd » Sun Dec 30, 2018 1:34 pm
(Just for completeness:
... the Acorn Preservation site mentioned seems to have gone, replaced with a parked domain site. Is that archive now somewhere else?
This thread says there's a (presently) private archive accessible to the stardot mods.)
Post by Coeus » Sun Dec 30, 2018 10:39 pm
Ok, re-factoring B-Em to support automatic tests in the way that RTW's emulator does would be a lot of work, I think, but I have made some changes to the debugger on a new branch: https://github.com/stardot/b-em/tree/sf/debug
Essentially this allows these kind of tests to be semi-scripted, i.e. the test can be run but you still have to eyeball the result. There are two new debugger commands:
  • paste allows characters to be "pasted" into the keyboard buffer. Control characters are introduced with '|' just like in *KEY definitions. To get a literal | character double it to ||
  • exec allows a file of debugging command to be executed, just like a *EXEC file.
So, for example, I can script the three Kevin Edwards test cases by creating a file called tests containing:
break 0E00
break 0DEF
paste *dir tests|M*run alien8|M
c
reset
bclear 1
break 0B09
break 0BCC
paste *run jetman|M
c
writem 0 1f
writem 1 0f
c
reset
paste *run nightshade|M
c
writem 0 40
writem 1 0f
c
Then starting B-em as:
b-em -debug
I can type:
exec tests
I could also start b-em with stdin redirected from the tests file. Then I just need to watch that it is the 0E00 breakpoints hit each time and not the other one. It beats doing all that by hand. It does assume the code for the test cases has been saved to a file accessible from the current filing system (I'm using VDFS).
This new branch is based on the current master and passed all three test cases.
Post by Coeus » Mon Dec 31, 2018 1:24 am
So steering back to the question of the ACR write I was able to get B-Em to return the same results as the real BBC micro, i.e. 64 0 0 128 by changing the timer limit from -3 to -2 but this breaks the Kevin Edwards test cases. I also found in B-Em the following code:
            case T2CH:
                /*Fix for Kevin Edwards protection - if interrupt triggers in cycle before write then let it run*/
                if ((v->t2c == TLIMIT && (v->ier & INT_TIMER2)) ||
                    (v->ifr & v->ier & INT_TIMER2))
                        interrupt |= 128;
So I am not completely clear here whether this is also something to make up for time skew between the 6522 and 6502, not having got the 6502 to latch the IRQ line at the right point or whether this emulating some non-obvious 6522 behaviour. Is it the case, for example, that the IFR timer bits update immediately a timer expires rather than waiting for the next clock, whereas the IFR bit 7 and external /IRQ line take an additional clock cycle to update? Does anyone know the answer to that or it is easier to run a test case?
It would be possible to test if there is an additional cycle delay when asserting the IRQ by setting different bits in the IER so the test case from earlier becomes:
   30 DIM MC% 100
   40 DIM R% 16
   50 P% = MC%
   60 [
   70 OPT 3
   80 SEI
   90 LDA #&FF
  100 STA &FE62
  110 LDA #&00
  120 STA &FE60
  130 LDA #&3F
  140 STA &FE6E
  150 LDA #&C0
  160 STA &FE6E
  170 LDA #&80
  180 STA &FE6B
  190 LDA #&04
  200 STA &FE64
  210 LDA #&00
  220 STA &FE65
  230 NOP
  240 NOP
  250 NOP
  260 LDA &FE6D
  270 STA R%
  280 NOP
  290 NOP
  300 LDA #&C0
  310 STA &FE6B
  320 LDA &FE64
  330 STA R%+1
  340 LDA &FE6D
  350 STA R%+2
  360 LDA &FE60
  370 STA R%+3
  380 CLI
  390 RTS
  400 ]
  410 CALL MC%
  420 REM B-EM: 0, 0, 0, 128
  430 REM B2: 0, 0, 64, 128
  440 REM BEEBEM: 0, 0, 64, 128
  450 REM JSBEEB: 64, 0, 0, 128
  460 REM MAME: 0, 248, 0, 128
  470 PRINT ?(R%)
  480 PRINT ?(R%+1)
  490 PRINT ?(R%+2)
  500 PRINT ?(R%+3)
scarybeasts
Post by scarybeasts » Mon Dec 31, 2018 3:30 am
I think the timing of the VIA raising timer IRQ is covered by Rich's excellent tests:
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Rows 23 & 24 are pretty instructive for this case, they avoid cycle stretching shenanigans and show that the IRQ is raised in the middle of the VIA cycle. (This matches another source I found in the c64 VICE emulator, comments in src/core/viacore.c. These comments also reference a resource called "6522-VIA.txt" that I've been unable to find, but it sounds useful if someone knows what it is.)
And now we know the IFR is visible the same cycle the interrupt is raised. It's not clear when exactly in the VIA cycle that is visible. Maybe someone who understands 6502 memory accesses can explain any constraints here, i.e. when in the 6502 cycle is the memory read point?
Chris
scarybeasts
Post by scarybeasts » Mon Dec 31, 2018 3:47 am
Oh, didn't know the change was so recent :-)
Another behavior that's unclear is whether the PB7 bit should be maintained (i.e. flipped) when PB7 output mode is off. MAME does, b2 does not. I'll cook up a simple test case to resolve.
Chris
Post by richardtoohey » Mon Dec 31, 2018 3:50 am
Can't answer the hard questions, but that text file - is it here?
ftp://www.zimmers.net/pub/cbm/documents ... index.html
6522-VIA.txt 2009-08-18 74398
6522-VIA.zip 2009-08-18 17459
6522 Versatile Interface Adapter data sheets converted to text by
Frank Kontros. This chip is used in many Commodore disk drives, in
the Commodore VIC-20 and in different PET models. The .zip file
contains the same information as the .txt file, only the graphics
are in IBM Code Page 437 character set instead of plain ASCII.
... and more specifically this link (from the 6522-VIA.txt line above)?
ftp://www.zimmers.net/pub/cbm/documents ... 22-VIA.txt
Text of that is below ... just in case the original disappears, but I'll delete it if making too much noise in this thread:
This   document  covers  all  programming  information  about  Rockwell  R6522
Versatile  Interface  Adapter  (VIA)  chip  used  in  many  Commodore devices.
Figures  and  tables  in  this  file  were  drawn  with  +,  -,  | characters.
For clear description, some of the figures are bit wider than 80 characters.
This file was created from scannings by Frank Kontros <jeno@kontr.uzhgorod.ua>
Many thanks for corrections to Wolfgang Lorenz <pc64@compuserve.com>
If  you  have  any  questions, comments or suggestions concerning this file or
6522 chip, please contact me (Frank).
                                      R6522
                               VERSATILE INTERFACE
                                     ADAPTER
DESCRIPTION
The  R6522  Versatile  Interface  Adapter (VIA) is a very flexible I/O control
device.  In  addition,  this  device  contains  a pair of very powerful 16-bit
interval  timers,  a  serial-to-parallel/parallel-to-serial shift register and
input  data  latching on the peripheral ports. Expanded handshaking capability
allows  control  of  bidirectional  data  transfers  between VIA's in multiple
processor systems.
Control   of  peripheral  devices  is  handled  primarily  through  two  8-bit
bidirectional  ports.  Each  line  can  be programmed as either an input or an
output.  Several  peripheral  I/O  lines  can  be controlled directly from the
interval  timers  for  generating  programmable  frequency square waves or for
counting  externally  generated  pulses.  To  facilitate  control  of the many
powerful  features  of  this  chip,  an  interrupt flag register, an interrupt
enable register and a pair of function control registers are provided.
FEATURES
o Two 8-bit bidirectional I/O ports
o Two 16-bit programmable timer/counters
o Serial data port
o TTL compatible
o CMOS compatible peripheral control lines
o Expanded "handshake" capability allows positive control
  data transfers between processor and peripheral devices
o Latched output and input registers
o 1 MHz and 2 Mhz operation
o Single +5V power supply
  ORDERING INFORMATION                                +---------------+
                                                 Vss =|  1         40 |= CA1
                                                 PA0 =|  2         39 |= CA2
   Part Number:                                  PA1 =|  3         38 |= RS0
   R6522 _ _ _                                   PA2 =|  4         37 |= RS1
         | | |                                   PA3 =|  5         36 |= RS2
         | | |                                   PA4 =|  6         35 |= RS3
         | | |                                   PA5 =|  7         34 |= RES
         | | |                                   PA6 =|  8         33 |= D0
         | | |                                   PA7 =|  9         32 |= D1
         | | +------ Temperature Range           PB0 =| 10         31 |= D2
         | |         Blank = 40øC to +70øC       PB1 =| 11         30 |= D3
         | |             E = 40øC to +85øC       PB2 =| 12         29 |= D4
         | |                                     PB3 =| 13         28 |= D5
         | |                                     PB4 =| 14         27 |= D6
         | +-------- Package                     PB5 =| 15         26 |= D7
         |               C = Ceramic             PB6 =| 16         25 |= 02
         |               P = Plastic             PB7 =| 17         24 |= CS1
         |                                       CB1 =| 18         23 |= CS2
         |                                       CB2 =| 19         22 |= R/W
         +---------- Frequency                   Vcc =| 20         21 |= IRQ
                     No Letter = 1 MHz                +---------------+
                             A = 2 MHz             R6522 Pin Configuration
INTERFACE SIGNALS
   M B   |    D0-D7 <    8    >|               |<   (8)   > PA0-PA7   |
   I U   |           \-------/ |               | \-------/            |
   C S   |                     |               |                      |   P I
   R     |       02 ---------->|               |<---------- CA1       |   E N
 R O I   |        _            |               |                      |   R T
 6 P N   |      R/W ---------->|     R6522     |<---------> CA2       |   I E
 5 R T  <       ___       2    |      VIA      |                       >  P R
 0 O E   |  CS1,CS2 -----/---->|               |<---------> CB1       |   H F
 0 C R   |                4    |               |                      |   E A
   E F   |  RS0-RS3 -----/---->|               |<---------> CB2       |   R C
   S A   |      ___            |               |                      |   A E
   S C   |      RES ---------->|               | /-------\            |   L
   O E   |      ___            |               |<   (8)   > PB0-PB7   |
   R     |      IRQ ---------->|               | \-------/            |
                     Figure 1. R6522 VIA interface Signals
       ___
RESET (RES)
                ___
A  low  reset  (RES)  input  clears  all  R6522  internal registers to logic 0
(except  T1  and  T2  latches  and  counters  and  the  Shift  Register). This
places  all  peripheral  interface  lines  in  the  input  state, disables the
timers, shift register, etc. and disables interrupting from the chip.
INPUT CLOCK (PHASE 2)
The  input  clock  is  the  system  02  clock  and triggers all data transfers
between processor bus and the R6522.
              _
READ/WRITE (R/W)
The direction of the data transfers between the R6522 and the system processor
is controlled by the R/W line in conjunction with the CS1 and CS2 inputs. When
R/W is low (write operation),  and the R6522 is selected,  data is transferred
from  the  processor  bus  into the selected R6522 register.  When R/W is high
(read  operation),  and  the  R6522 is selected,  data is transferred from the
selected R6522 register to the processor bus.
DATA BUS (D0-D7)
The  eight  bidirectional  data  bus lines transfer data between the R6522 and
the  system  processor  bus.  During read cycles, the contents of the selected
R6522  register  are  placed on the data bus lines. During write cycles, these
lines  are  high-impedance  inputs  and data is transferred from the processor
bus  into  the  selected  register.  When  the R6522 is not selected, the data
bus lines are high impedance.
                   ___
CHIP SELECTS (CS1, CS2)
The  two  chip select inputs are normally connected to processor address lines
either  directly or through decoding.  The selected R6522 register is accessed
when CS1 is high and CS2 is low.
REGISTER SELECTS (RS0-RS3)
The  coding  of  the four Register Select inputs select one of the 16 internal
registers of the R6522, as shown in Table 1.
                       Table 1. R6522 Register Addressing
|Reg.|   RS Coding   |Register |            Register/Description             |
| #  +---+---+---+---+ Desig.  +----------------------+----------------------+
|    |RS3|RS2|RS1|RS0|         | Write (R/W = L)      | Read (R/W = H)       |
|  0 | 0 | 0 | 0 | 0 | ORB/IRB | Output Register B    | Input Register B     |
|  1 | 0 | 0 | 0 | 1 | ORA/IRA | Output Register A    | Input Register A     |
|  2 | 0 | 0 | 1 | 0 |  DDRB   | Data Direction Register B                   |
|  3 | 0 | 0 | 1 | 1 |  DDRA   | Data Direction Register A                   |
|  4 | 0 | 1 | 0 | 0 |  T1C-L  | T1 Low-Order Latches | T1 Low-Order Counter |
|  5 | 0 | 1 | 0 | 1 |  T1C-H  | T1 High-Order Counter| T1 High-Order Counter|
|  6 | 0 | 1 | 1 | 0 |  T1L-L  | T1 Low-Order Latches                        |
|  7 | 0 | 1 | 1 | 1 |  T1L-H  | T1 High-Order Latches                       |
|  8 | 1 | 0 | 0 | 0 |  T2C-L  | T2 Low-Order Latches | T2 Low-Order Counter |
|  9 | 1 | 0 | 0 | 1 |  T2C-H  | T2 High-Order Counter                       |
| 10 | 1 | 0 | 1 | 0 |  SR     | Shift Register                              |
| 11 | 1 | 0 | 1 | 1 |  ACR    | Auxiliary Control Register                  |
| 12 | 1 | 1 | 0 | 0 |  PCR    | Peripheral Control Register                 |
| 13 | 1 | 1 | 0 | 1 |  IFR    | Interrupt Flag Register                     |
| 14 | 1 | 1 | 1 | 0 |  IER    | Interrupt Enable Register                   |
| 15 | 1 | 1 | 1 | 1 | ORA/IRA | Output Register A*   | Input Register A*    |
| NOTE: * Same as Register 1 except no handshake.                            |
                   ___
INTERRUPT REQUEST (IRQ)
The  Interrupt  Request output goes low whenever an internal interrupt flag is
set  and  the corresponding interrupt enable bit is a logic 1.  This output is
open-drain  to  allow the interrupt request signal to be wire-OR'ed with other
equivalent signals in the system.
PERIPHERAL PORT A (PA0-PA7)
Port  A  consists  of  eight lines which can be individually programmed to act
as  inputs  or  outputs  under  control  of  a  Data Direction Register A. The
polarity  of  output  pins  is controlled by an Output Register and input data
may  be  latched  into an internal register under control of the CA1 line. All
of  these  modes  of  operation are controlled by the system processor through
the  internal  control  registers.  These  lines  represents  one standard TTL
load  in  the  input  mode  and will drive one standard TTL load in the output
mode. Figure 2 illustrates the output circuit.
                                            +5V
                                             o
                                             *-----*---> PA0-PA7,
                                             |     |     CA2
             I/O CONTROL ----+     |     ||        |
                             | NOR |o----+|        |
             OUTPUT DATA ----+     |     ||        |
                                           __|__   |
              INPUT DATA <-------------------------+
                       Figure 2. Port A Output Circuit
PORT A CONTROL LINES (CA1,CA2)
The  two  Port  A  control  lines  act  as  interrupt  inputs  or as handshake
outputs.  Each  line  controls an internal interrupt flag with a corresponding
interrupt  enable  bit.  In  addition,  CA1  controls  the latching of data on
Port  A  input  lines. CA1 is a high-impedance input only while CA2 represents
one  standard  TTL  load  in  the  input mode. CA2 will drive one standard TTL
load in the output mode.
PORT B (PB0-PB7)
Peripheral   Port   B   consists  of  eight  bi-directional  lines  which  are
controlled  by  an  output  register and a data direction register in much the
same  manner  as  the  Port  A.  In  addition,  the polarity of the PB7 output
signal  can  be  controlled  by  one  of  the interval timers while the second
timer  can  be  programmed  to  count  pulses  on  the  PB6  pin. Port B lines
represent  one  standard  TTL  load  in  the  input  mode  and  will drive one
standard  TTL  load  in  the  output  mode.  In  addition, they are capable of
sourcing  1.0  mA  at  1.5  Vdc  in  the  output  mode to allow the outputs to
directly  drive  Darlington  transistor  circuits.  Figure  3  is  the circuit
schematic.
                                                +5V
                                                 o
          INPUT                  +-----+      +--+       >
         OUTPUT -------------*---+     |     ||         <
        CONTROL        |\    |   | NOR |o----+|          >
                   +--o| >---+---+     |     ||         <
                   |         |                   *------*---> PB0-PB7,
                   |         |                   |      |     CB1,CB2
         OUTPUT    |             | NOR |o----+|         |
           DATA ---*-------------+     |     ||         |
                                               __|__    |
     INPUT DATA <---------------------------------------+
                       Figure 3. Port B Output Circuit
PORT B CONTROL LINES (CB1,CB2)
The  Port  B  control  lines  act as interrupt inputs or as handshake outputs.
As   with   CA1   and  CA2,  each  line  controls  an  interrupt  flag  with a
corresponding  interrupt  enable  bit.  In  addition,  these  lines  act  as a
serial  port  under  control  of the Shift Register. These lines represent one
standard  TTL  load  in the input mode and will drive one standard TTL load in
the  output  mode.  CB2  can  also  drive  a  Darlington  transistor  circuit;
however, CB1 cannot.
FUNCTIONAL DESCRIPTION
The internal organization of the R6522 VIA is illustrated in Figure 4.
                         INTERRUPT                                         ___
                          CONTROL     +----------------------------------> IRQ
                       |   FLAGS    | |      |INPUT LATCH|    |       |
                       |   (IFR)    | |      |   (IRA)   |    |       |     P
                   +--\+------------+ |      +-----------+    |       |     O
                   | +/|   ENABLE   +-+  +--\|  OUTPUT   |/--\|BUFFERS|/--\ R
         +-------+ | | |   (IER)    |    | +/|   (ORA)   |\--/| (PA)  |\--/ T
DATA /--\|  DATA +-+ +-------------------+ | | DATA DIR  |    |       |     A
BUS  \--/|  BUS  +-+ +-------------------+ | |  (DDRA)   |    |       |
         |BUFFERS| | | +------------+    | | +-----------+    +-------+
         |       | | | | PERIPHERAL |    | |PORT A REGISTER
         +-------+ | | |   (PCR)    |    | |
                   | +\+------------+    | | +-----------+<--------------- CA1
                   | +/| AUXILIARY  |    | +\|  PORT A   |<--------------> CA2
                   | | |   (ACR)    |    | +/+-----------+
                   | | +------------+    | | |  PORT B   |<--------+
                   | |    FUNCTION       | | +-----------+<------+ |
                   | |    CONTROL        | |   HANDSHAKE         | |
                   | | +-------+-------+ | |    CONTROL          | |
___      +-------+ | | | LATCH | LATCH | | | +-----------+       | |
RES ---->|       | | | |(T1L-H)|(T1L-L)| | +\| SHIFT REG |<------+-*-----> CB1
  _      |       | | +\+-------+-------+ | +/|    (SR)   |<------*-------> CB2
R/W ---->|       | | +/|COUNTER|COUNTER| | | +-----------+
02  ---->|       | | | |(T1C-H)|(T1C-L)| | |
___      |  CHIP | | | +-------+-------+ | |PORT B REGISTER
CS2 ---->| ACCESS| | |      TIMER 1      | | +-----------+    +-------+
CS1 ---->|CONTROL| | |         +-------+ | | |INPUT LATCH|    |       |
         |       | | |         | LATCH | | | |   (IRB)   |    |       |     P
RS0 ---->|       | | |         |(T2L-L)| | | +-----------+    |       |     O
RS1 ---->|       | | | +-------+-------+ | +\|  OUTPUT   |/--\|BUFFERS|/--\ R
RS2 ---->|       | | +\|COUNTER|COUNTER| +--/|   (ORB)   |\--/| (PB)  |\--/ T
RS3 ---->|       | +--/|(T2C-H)|(T2C-L)|     +-----------+    |       |
         +-------+     +-------+-------+     | DATA DIR  |    |       |     B
                            TIMER 2          |  (DDRB)   |    |       |
                      Figure 4. R6522 VIA Block Diagram
PORT A AND PORT B OPERATION
The  R6522  VIA  has  two  8-bit  bidirectional  I/O ports (Port A and Port B)
and each port has two associated control lines.
Each  8-bit  peripheral  port  has  a Data Direction Register (DDRA, DDRB) for
specifying  whether  the  peripheral pins are to act as inputs or outputs. A 0
in  a  bit  of the Data Direction Register causes the corresponding peripheral
pin to act as an input. A 1 causes the pin to act as an output.
Each  peripheral  pin  is  also  controlled  by  a  bit in the Output Register
(ORA,  ORB)  and  the Input Register (IRA, IRB). When the pin is programmed as
an  output,  the  voltage on the pin is controlled by the corresponding bit of
the  Output  Register.  A  1  in  the  Output Register causes the output to go
high,  and  a  0  causes the output to go low. Data may be written into Output
Register  bits  corresponding  to pins which are programmed as inputs. In this
case, however, the output signal is unaffected.
Reading  a  peripheral  port  causes  the contents of the Input Register (IRA,
IRB)  to  be  transferred onto the Data Bus. With input latching disabled, IRA
will  always  reflect  the levels on the PA pins. With input latching enabled,
IRA  will  reflect  the  levels  on  the PA pins at time the latching occurred
(via CA1).
The  IRB  register  operates  similar  to  the IRA register. However, for pins
programmed  as  outputs  there is a difference. When reading IRA, the level on
the  pin  determines  whether a 0 or a 1 is sensed. When reading IRB, however,
the  bit  stored  in  the  output  register, ORB, is the bit sensed. Thus, for
outputs  which  have  large  loading effects and which pull an output "1" down
or  which  pull  an  output  "0"  up,  reading IRA may result in reading a "0"
when  a  "1"  was  actually  programmed,  and  reading  a  "1"  when a "0" was
programmed.  Reading  IRB,  on  the other hand, will read the "1" or "0" level
actually programmed, no matter what the loading on the pin.
Figures  5  through  8  illustrate  the  formats  of  the  port  registers. In
addition,  the  input  latching  modes  are  selected by the Auxiliary Control
Register (Figure 12).
              REG 0 -- ORB/IRB
     | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
       |   |   |   |   |   |   |   +----- PB0 |
       |   |   |   |   |   |   +--------- PB1 |
       |   |   |   |   |   +------------- PB2 |  OUTPUT REGISTER
       |   |   |   |   |                      |  "B" (ORB)
       |   |   |   |   +----------------- PB3 |
       |   |   |   |                          +-       OR
       |   |   |   +--------------------- PB4 |
       |   |   |                              |  INPUT REGISTER
       |   |   +------------------------- PB5 |  "B" (IRB)
       |   +----------------------------- PB6 |
       +--------------------------------- PB7 |
|       PIN             |                       |                           |
|  DATA DIRECTION       |        WRITE          |           READ            |
|    SELECTION          |                       |                           |
|DDRB = 1  OUTPUT       |MPU WRITES OUTPUT LEVEL|MPU READS OUTPUT REGISTER  |
|                       |ORB                    |BIT, ORB PIN LEVEL HAS NO  |
|                       |                       |AFFECT                     |
|DDRB = 0  INPUT        |MPU WRITES INTO ORB BUT|MPU READS INPUT LEVEL ON PB|
|INPUT LATCHING DISABLED|NO AFFECT ON PIN LEVEL |PIN                        |
|                       |UNTIL DDRB CHANGED     |                           |
|DDRB = 0  INPUT        |                       |MPU READS IRB BIT WHICH IS |
|INPUT LATCHING ENABLED |                       |THE LEVEL OF THE PB PIN AT |
|                       |                       |THE TIME OF THE LAST CB1   |
|                       |                       |ACTIVE TRANSITION          |
          Figure 5. Output Register B (ORB), Input Register B (IRB)
              REG 1 -- ORA/IRA
       |   |   |   |   |   |   |   +----- PA0 |
       |   |   |   |   |   |   +--------- PA1 |
       |   |   |   |   |   +------------- PA2 |  OUTPUT REGISTER
       |   |   |   |   |                      |  "A" (ORA)
       |   |   |   |   +----------------- PA3 |
       |   |   |   |                          +-       OR
       |   |   |   +--------------------- PA4 |
       |   |   |                              |  INPUT REGISTER
       |   |   +------------------------- PA5 |  "A" (IRA)
       |   +----------------------------- PA6 |
       +--------------------------------- PA7 |
|       PIN             |                       |                           |
|    SELECTION          |                       |                           |
|DDRA = 1  OUTPUT       |MPU WRITES OUTPUT LEVEL|MPU READS LEVEL ON PA PIN  |
|INPUT LATCHING DISABLED|ORA                    |                           |
|DDRA = 1  INPUT        |                       |MPU READS IRA BIT WHICH IS |
|INPUT LATCHING ENABLED |                       |THE LEVEL OF THE PA PIN AT |
|                       |                       |THE TIME OF THE LAST CA1   |
|                       |                       |ACTIVE TRANSITION          |
|DDRA = 0  INPUT        |MPU WRITES INTO ORA BUT|MPU READS LEVEL ON PA PIN  |
|INPUT LATCHING DISABLED|NO AFFECT ON PIN LEVEL |                           |
|                       |UNTIL DDRA CHANGED     |                           |
|DDRA = 0  INPUT        |                       |MPU READS IRA BIT WHICH IS |
|                       |                       |ACTIVE TRANSITION          |
          Figure 6. Output Register A (ORA), Input Register A (IRA)
   REG 2 -- DDRB                          REG 3 -- DDRA
 |7|6|5|4|3|2|1|0|                      |7|6|5|4|3|2|1|0|
  | | | | | | | +--- PB0 |               | | | | | | | +--- PA0 |
  | | | | | | +----- PB1 |               | | | | | | +----- PA1 |
  | | | | | +------- PB2 |  DATA         | | | | | +------- PA2 |  DATA
  | | | | +--------- PB3 |_ DIRECTION    | | | | +--------- PA3 |_ DIRECTION
  | | | +----------- PB4 |  REGISTER     | | | +----------- PA4 |  REGISTER
  | | +------------- PB5 |  "B" (DDRB)   | | +------------- PA5 |  "A" (DDRA)
  | +--------------- PB6 |               | +--------------- PA6 |
  +----------------- PB7 |               +----------------- PA7 |
  "0"  ASSOCIATED PB PIN IS AN INPUT     "0"  ASSOCIATED PA PIN IS AN INPUT
       (HIGH IMPEDANCE)                       (HIGH IMPEDANCE)
  "1"  ASSOCIATED PB PIN IS AN OUTPUT    "1"  ASSOCIATED PA PIN IS AN OUTPUT
       WHOSE LEVEL IS DETERMINED BY           WHOSE LEVEL IS DETERMINED BY
       ORB REGISTER BIT                       ORA REGISTER BIT
  Figure 7. Data Direction Register B    Figure 8. Data Direction Register A
            (DDRB)                                 (DDRA)
HANDSHAKE CONTROL OF DATA TRANSFERS
The  R6522  allows  positive  control  of  data  transfers  between the system
processor  and  peripheral devices through the operation of "handshake" lines.
Port  A  lines  (CA1, CA2) handshake data on both a read and a write operation
while the Port B lines (CB1, CB2) handshake on a write operation only.
READ HANDSHAKE
Positive  control  of  data  transfers from peripheral devices into the system
processor  can  be  accomplished  very  effectively using Read Handshaking. In
this  case,  the  peripheral  device  must  generate the equivalent of a "Data
Ready"  signal  to  the processor signifying that valid data is present on the
peripheral  port.  This  signal  normally interrupts the processor, which then
reads  the  data,  causing generation of a "Data Taken" signal. The peripheral
device  responds  by  making  new data available. This process continues until
the data transfer is complete.
In  the  R6522,  automatic  "Read Handshaking" is possible on the Peripheral A
Port  only.  The  CA1  interrupt input pin accepts the "Data Ready" signal and
CA2  generates  the  "Data  Taken" signal. The "Data Ready" signal will set an
internal  flag  which  may  interrupt  the  processor  or  which may be polled
under  program  control.  The  "Data  Taken" signal can either be a pulse or a
level  which  is  set  low by the system processor and is cleared by the "Data
Ready"  signal.  These  options  are  shown  in Figure 9 which illustrates the
normal Read Handshake sequence.
                02 --+ +-+ +-+ +-+ +-#-+ +-+ +-+ +-+ +-+ +-#-+ +-+ +-+ +-
    "DATA READY"   ---------+   +----#-------+-------------#------+
     CA1)                   +---+----#-------+   |   |            +------
    ___                     |                    |   |            |
    IRQ OUTPUT     ---------+                    +---------#------+
    READ IRA                                 +---+   |            |
    OPERATION      ------------------#-------+   +---------#-------------
    "DATA TAKEN"   ------------------------------+   |            +------
    HANDSHAKE MODE                               +---------#------+
    (CA2)                                        |   |
    "DATA TAKEN"   ------------------#-----------+   +-----#-------------
    PULSE MODE                                   +---+
    (CA2)
                Figure 9. Read Handshake Timing (Port A, Only)
WRITE HANDSHAKE
The  sequence  of  operations  which  allows  handshaking data from the system
processor  to  a  peripheral device is very similar to that described for Read
Handshaking.  However,  for Write  Handshaking,  the R6522 generates the "Data
Ready"  signal  and  the  peripheral device must respond with the "Data Taken"
signal.  This  can  be accomplished on both the PA port and the PB port on the
R6522.  CA2  or  CB2 act as a "Data Ready" output in either the handshake mode
or  pulse  mode  and  CA1  or  CB1  accept  the  "Data  Taken" signal from the
peripheral  device,  setting  the interrupt flag and cleaning the "Data Ready"
output. This sequence is shown in Figure 10.
    WRITE ORA,ORB  ----+   +---------#---------------------#---+   +-----
    OPERATION                                                  |
    "DATA READY"   ----------+                +----------------------+
    HANDSHAKE MODE           +-------#--------+                |     +---
    (CA2,CB2)                |                |                |
    "DATA READY"   ----------+   +---#---------------------#---------+
    PULSE MODE               +---+            |                |     +---
    (CA2,CB2)                                 |                |     |
    "DATA TAKEN"   ---------------------------+   +--------#---+---------
    (CA1,CB1)                                 +---+--------#---+     |
    ___                                       |                      |
    IRQ OUTPUT     ------------------#--------+                      +---
                      Figure 10. Write Handshake Timing
Selection  of  operating  modes  for  CA1, CA2, CB1 and CB2 is accomplished by
the Peripheral Control Register (Figure 11).
                  REG 12 -- PERIPHERAL CONTROL REGISTER
         CB2 CONTROL -----+       |       |       +- CA1 INTERRUPT CONTROL
|7|6|5| OPERATION              |  |       |   | 0 = NEGATIVE ACTIVE EDGE |
+-+-+-+------------------------+  |       |   | 1 = POSITIVE ACTIVE EDGE |
|0|0|0| INPUT NEG. ACTIVE EDGE |  |       |   +--------------------------+
+-+-+-+------------------------+  |       +---- CA2 INTERRUPT CONTROL
|0|0|1| INDEPENDENT INTERRUPT  |  |       +-+-+-+------------------------+
| | | | INPUT NEGATIVE EDGE    |  |       |3|2|1| OPERATION              |
|0|1|0| INPUT POS. ACTIVE EDGE |  |       |0|0|0| INPUT NEG. ACTIVE EDGE |
|0|1|1| INDEPENDENT INTERRUPT  |  |       |0|0|1| INDEPENDENT INTERRUPT  |
| | | | INPUT POSITIVE EDGE    |  |       | | | | INPUT NEGATIVE EDGE    |
|1|0|0| HANDSHAKE OUTPUT       |  |       |0|1|0| INPUT POS. ACTIVE EDGE |
|1|0|1| PULSE OUTPUT           |  |       |0|1|1| INDEPENDENT INTERRUPT  |
+-+-+-+------------------------+  |       | | | | INPUT POSITIVE EDGE    |
|1|1|0| LOW OUTPUT             |  |       +-+-+-+------------------------+
+-+-+-+------------------------+  |       |1|0|0| HANDSHAKE OUTPUT       |
|1|1|1| HIGH OUTPUT            |  |       +-+-+-+------------------------+
+-+-+-+------------------------+  |       |1|0|1| PULSE OUTPUT           |
    CB1 INTERRUPT CONTROL --------+       +-+-+-+------------------------+
+--------------------------+              |1|1|0| LOW OUTPUT             |
| 0 = NEGATIVE ACTIVE EDGE |              +-+-+-+------------------------+
| 1 = POSITIVE ACTIVE EDGE |              |1|1|1| HIGH OUTPUT            |
                 Figure 11. Peripheral Control Register (PCR)
COUNTERS/TIMERS
There  are  two  independent  16-bit-counter/timers  (called Timer 1 and Timer
2)  in  the R6522. Each timer is controlled by writing bits into the Auxiliary
Control Register (ACR) to select this mode of operation (Figure 12).
                    REG 11 -- AUXILIARY CONTROL REGISTER
                       +--+--+  |  +----+----+  |   +------ PA
      T1 TIMER CONTROL ---+     |       |       +---------- PB
|7|6|OPERATION       | PB7   |  |       |              LATCHING ENABLE/DISABLE
|0|0|TIMED INTERRUPT |       |  |       |              | 0 = DISABLE LATCHING|
| | |EACH TIME T1 IS |       |  |       |              | 1 = ENABLE LATCHING |
| | |LOADED          |DISABLE|  |       |              +---------------------+
|0|1|CONTINUOUS      |       |  |       |
| | |INTERRUPTS      |       |  |       +---- SHIFT REGISTER CONTROL
|1|0|TIMED INTERRUPT |ONE-   |  |  |4|3|2| OPERATION                         |
| | |EACH TIME T1 IS |SHOT   |  |  +-+-+-+-----------------------------------+
| | |LOADED          |OUTPUT |  |  |0|0|0| DISABLED                          |
|1|1|CONTINUOUS      |SQUARE |  |  |0|0|1| SHIFT IN UNDER COMTROL OF T2      |
| | |INTERRUPTS      |WAVE   |  |  +-+-+-+-----------------------------------+
| | |                |OUTPUT |  |  |0|1|0| SHIFT IN UNDER CONTROL OF 02      |
                                |  |0|1|1| SHIFT IN UNDER CONTROL OF EXT.CLK |
   T2 TIMER CONTROL ------------+  +-+-+-+-----------------------------------+
+-+-----------------+              |1|0|0| SHIFT OUT FREE-RUNNING AT T2 RATE |
|5| OPERATION       |              +-+-+-+-----------------------------------+
+-+-----------------+              |1|0|1| SHIFT OUT UNDER CONTROL OF T2     |
|0| TIMED INTERRUPT |              +-+-+-+-----------------------------------+
+-+-----------------+              |1|1|0| SHIFT OUT UNDER CONTROL OF 02     |
|1| COUNT DOWN WITH |              +-+-+-+-----------------------------------+
| | PULSES ON PB6   |              |1|1|1| SHIFT OUT UNDER CONTROL OF EXT.CLK|
                 Figure 12. Auxiliary Control Register (ACR)
Timer 1 Operation
Interval  Timer  T1  consists  of  two  8-bit latches (Figure 13) and a 16-bit
counter  (Figure  14).  The  latches store data which is to be loaded into the
counter.  After  loading,  the  counter  decrements  at  02  clock  rate. Upon
reaching  zero,  an  interrupt  flag  is  set,  and  IRQ  goes  low  if the T1
interrupt  is  enabled.  Timer  1  then  disables  any  further  interrupts or
automatically  transfers  the  contents  of  the  latches into the counter and
continues  to  decrement.  In  addition, the timer may be programmed to invert
the  output  signal  on  a peripheral pin (PB7) each time it "times-out". Each
of these modes is discussed separately below.
Note  that  the  processor  does not write directly into the low-order counter
(T1C-L).  Instead,  this  half of the counter is loaded automatically from the
low  order  latch  (T1L-L)  when  the  processor  writes  into  the high order
counter  (T1C-H).  In  fact, it may not be necessary to write to the low order
counter  in  some  applications  since  the  timing  operation is triggered by
writing to the high order latch.
  REG 6 -- T1 LOW-ORDER LATCH             REG 7 -- T1 HIGH-ORDER LATCH
   | | | | | | | +--- 1   |                | | | | | | | +--- 256   |
   | | | | | | +----- 2   |                | | | | | | +----- 512   |
   | | | | | +------- 4   |                | | | | | +------- 1024  |
   | | | | +--------- 8   |_ COUNT         | | | | +--------- 2048  |_ COUNT
   | | | +----------- 16  |  VALUE         | | | +----------- 4096  |  VALUE
   | | +------------- 32  |                | | +------------- 8192  |
   | +--------------- 64  |                | +--------------- 16384 |
   +----------------- 128 |                +----------------- 32768 |
 WRITE - 8 BITS LOADED INTO T1           WRITE - 8 BITS LOADED INTO T1 HIGH-
         LOW-ORDER LATCHES. THIS                 ORDER LATCHES. UNLIKE REG 4
         OPERATION IS NO DIFFERENT               OPERATION NO LATCH TO
         THAN A WRITE INTO REG 4                 COUNTER TRANSFERS TAKE PLACE
 READ  - 8 BITS FROM T1 LOW ORDER-       READ  - 8 BITS FROM T1 HIGH-ORDER
         LATCHES TRANSFERRED TO MPU.             LATCHES TRANSFERRED TO MPU
         UNLIKE REG 4 OPERATION,
         THIS DOES NOT CAUSE RESET
         OF T1 INTERRUPT FLAG
                   Figure 13. Timer 1 (T1) Latch Registers
 REG 4 -- T1 LOW-ORDER COUNTER           REG 5 -- T1 HIGH-ORDER COUNTER
         LOW-ORDER LATCHES. LATCH                HIGH-ORDER LATCHES. ALSO
         CONTENTS ARE TRANSFERRED                AT THIS TIME BOTH HIGH- AND
         INTO LOW-ORDER COUNTER AT               LOW-ORDER LATCHES TRANSFERRED
         THE TIME THE HIGH-ORDER                 INTO T1 COUNTER. T1 INTERRUPT
         COUNTER IS LOADED (REG 5)               FLAG ALSO IS RESET
 READ  - 8 BITS FROM T1 LOW-ORDER        READ  - 8 BITS FROM T1 HIGH-ORDER
         COUNTER TRANSFERRED TO MPU.             COUNTER TRANSFERRED TO MPU
         IN ADDITION T1 INTERRUPT FLAG
         IS RESET (BIT 6 IN INTERRUPT
         FLAG REGISTER)
                  Figure 14. Timer 1 (T1) Counter Registers
Timer 1 One-Shot Mode
The  Timer  1  one-shot  mode generates a single interrupt for each timer load
operation.  As  with  any  interval timer, the delay between the "write T1C-H"
operation  and  generation  of the processor interrupt is a direct function of
the  data  loaded  into the timing counter. In addition to generating a single
interrupt,  Timer  1  can  be programmed to produce a single negative pulse on
the  PB7  peripheral  pin.  With  the  output enabled (ACR7=1) a "write T1C-H"
operation  will  cause  PB7 to go low. PB7 will return high when Timer 1 times
out. The result is a single programmable width pulse.
                                           ___
T1   interrupt  flag  will  be  set,  the  IRQ  pin  will  go  low  (interrupt
enabled),  and  the  signal on PB7 will go high. At this time the counter will
continue   to   decrement  at  system  clock  rate.  This  allows  the  system
processor  to  read  the  contents  of the counter to determine the time since
interrupt.  However,  the  T1 interrupt flag cannot be set again unless it has
been cleared as described in this specification.
Timing for the R6522 interval timer one-shot mode is shown in Figure 15.
                02 --+ +-+ +-+ +-+ +-+ +-+ +-#-+ +-+ +-+ +-+ +-+ +-+ +-
       WRITE T1C-H ----+   +-----------------#-------------------------
        ___                |                           |
        IRQ OUTPUT --------------------------#---------+
        PB7 OUTPUT --------+                           +---------------
                           | N |N-1|N-2|N-3|     | 0 |N| |N-1|N-2|N-3|
                           |<---- N + 1.5 CYCLES ----->|
                   Figure 15. Timer 1 One-Shot Mode Timing
In   the  one-shot  mode,  writing  into  the  T1L-H  has  no  effect  on  the
operation  of  Timer  1.  However, it will be necessary to assure that the low
order  latch  contains  the  proper data before initiating the count-down with
a  "write  T1C-H"  operation.  When  the  processor writes into the high order
counter  (T1C-H),  the  T1 interrupt flag will be cleared, the contents of the
low  order  latch  will  be  transferred  into  the low order counter, and the
timer  will  begin  to  decrement  at  system clock rate. If the PB7 output is
enabled,  this  signal  will  go  low on the 02 following the write operation.
When  the  counter  reaches  zero,  the T1 interrupt flag will be set, the IRQ
pin  will  go  low (interrupt enabled), and the signal on PB7 will go high. At
this  time  the  counter will continue to decrement at system clock rate. This
allows   the  system  processor  to  read  the  contents  of  the  counter  to
determine  the  time  since  interrupt.  However, the T1 interrupt flag cannot
be set again unless it has been cleared as described in this specification.
Timer 1 Free-Run Mode
The  most  important  advantage  associated  with  the  latches  in  T1 is the
ability  to  produce  a  continuous series of evenly spaced interrupts and the
ability  to  produce  a  square wave on PB7 whose frequency is not affected by
variations  in  the  processor  interrupt  response time. This is accomplished
in the "free-running" mode.
In  the  free-running  mode,  the  interrupt flag is set and the signal on PB7
is   inverted  each  time  the  counter  reaches  zero.  However,  instead  of
continuing  to  decrement  from zero after a time-out, the timer automatically
transfers   the  contents  of  the  latch  into  the  counter  (16  bits)  and
continues  to  decrement  from  there.  The  interrupt  flag can be cleared by
writing  T1C-H,  by  reading  T1C-L  or  by  writing directly into the flag as
described  later.  However,  it  is  not  necessary  to  rewrite  the timer to
enable setting the interrupt flag on the next time-out.
All   interval  timers  in  the  R6522  are  "re-triggerable".  Rewriting  the
counter   will   always  re-initialize  the  time-out  period.  In  fact,  the
time-out  can  be  prevented  completely if the processor continues to rewrite
the  timer  before  it  reaches  zero.  Timer 1 will operate in this manner if
the  processor  writes  into  the  high  order  counter  (T1C-H).  However, by
loading  the  latches  only,  the  processor  can access the timer during each
down-counting  operation  without  affecting the time-out in process. Instead,
the  data  loaded  into  the  latches  will  determine  the length of the next
time-out   period.   This   capability   is   particularly   valuable  in  the
free-running  mode  with  the  output enabled. In this mode, the signal on PB7
is  inverted  and  the interrupt flag is set with each time-out. By responding
to   the  interrupts  with  new  data  for  the  latches,  the  processor  can
determine  the  period  of  the  next half cycle during each half cycle of the
output  signal  on  PB7.  In  this  manner,  very  complex  waveforms  can  be
generated.
A  precaution  to  take  in  the  use  of PB7 as the timer output concerns the
Data  Direction  Register  contents  for  PB7.  Both  DDRB bit 7 and ACR bit 7
must  be  1  for  PB7  to  function  as  the timer output. If one is 1 and the
other  is  0,  then  PB7  functions  as a normal output pin, controlled by ORB
bit 7.
               02 --+ +-+ +-+ +-#-+ +-+ +-+ +-+ +-+ +-#-+ +-+ +-+ +-+ +-
      WRITE T1C-H     +---+               |                     |
      OPERATION   ----+   +-----#---------------------#-----------------
       ___                |               |                     |
       IRQ OUTPUT --------------#---------+           #---------+
       PB7 OUTPUT --------+               +-----------#---------+
                          |< N+1.5 CYCLES>|<---- N+2 CYCLES --->|
                   Figure 16. Timer 1 Free-Run Mode Timing
Timer 2 Operation
Timer  2  operates  as  an interval timer (in the "one-shot" mode only), or as
a  counter  for  counting  negative pulses on the PB6 peripheral pin. A single
control  bit  in  the  Auxiliary  Control  Register  selects between these two
modes.  This  timer  is comprised of a "write-only" low-order latch (T2L-L), a
"read-only"  low-order  counter  (T2C-L)  and  a read/write high order counter
(T2C-H).  The  counter  registers  act as a 16-bit counter which decrements at
02 rate. Figure 17 illustrates the T2 Latch/Counter Registers.
  REG 8 - T2 LOW-ORDER LATCH/COUNTER      REG 9 - T2 HIGH-ORDER COUNTER
 WRITE - 8 BITS LOADED INTO T2           WRITE - 8 BITS LOADED INTO T2
         LOW-ORDER LATCH                         HIGH-ORDER COUNTER. ALSO,
                                                 LOW-ORDER LATCH TRANSFERRED
 READ  - 8 BITS FROM T2 LOW-ORDER                TO LOW-ORDER COUNTER. IN
         COUNTER TRANSFERRED TO MPU.             ADDITION T2 INTERRUPT FLAG
         T2 INTERRUPT FLAG IS RESET              IS RESET
                                         READ  - 8 BITS FROM T2 HIGH-ORDER
               Figure 17. Timer 2 (T2) Latch/Counter Registers
Timer 2 One-Shot Mode
As  an interval timer,  T2 operates in the "one-shot" mode similar to Timer 1.
In  this  mode,  T2  provides  a  single  interrupt  for  each  "write  T2C-H"
operation.   After  timing  out,  the  counter  will  continue  to  decrement.
However,  setting  of  the  interrupt  flag is disabled after initial time-out
so  that  it  will  not be set by the counter decrementing again through zero.
The  processor  must  rewrite  T2C-H  to enable setting of the interrupt flag.
The  interrupt  flag  is  cleared by reading T2C-L or by writing T2C-H. Timing
for this operation is shown in Figure 18.
       WRITE T2C-H ----+   +-----------------#-------------------------
        ___                |                           |
                           |<------ N+1.5 CYCLES ----->|
                          Figure 18. Timer 2 One-Shot Mode Timing
Timer 2 Pulse Counting Mode
In   the   pulse   counting   mode,   T2  counts  a  predetermined  number  of
negative-going  pulses  on  PB6.  This  is  accomplished  by  first  loading a
number  into  Timer  2.  Writing  into  T2C-H  clears  the  interrupt flag and
allows  the  counter  to  decrement  each  time a pulse is applied to PB6. The
interrupt  flag  is  set  when T2 counts down past zero. The counter will then
continue  to  decrement  with  each  pulse on PB6. However, it is necessary to
rewrite  T2C-H  to  allow  the interrupt flag to set on a subsequent time-out.
Timing  for  this  mode  is  shown  in Figure 19. The pulse must be low on the
leading edge of 02.
    WRITE T2C-H     +---+
    OPERATION   ----+   +------------------------------------------------
      PB6 INPUT                   +-+     +-+           +-+     +-+
     ___        ------------------------------------------------+
     IRQ OUTPUT                   |       |             |       +--------
                               N  |  N-1  |  N-2     1  |   0   |  -1
                    Figure 19. Timer 2 Pulse Counting Mode
SHIFT REGISTER OPERATION
The  Shift  Register  (SR)  performs serial data transfers into and out of the
CB2  pin  under  control  of an internal modulo-8 counter. Shift pulses can be
applied  to  the  CB1  pin  from  an  external source or, with the proper mode
selection,  shift  pulses  generated internally will appear on the CB1 pin for
controlling external devices.
The  control  bits  which  select  the  various shift register operating modes
are  located  in  the  Auxiliary  Control  Register. Figure 20 illustrates the
configuration  of  the  SR  data  bits and Figure 21 shows the SR control bits
of the ACR.
 REG 10 -- SHIFT REGISTER              REG 11 -- AUXILIARY CONTROL REGISTER
  | | | | | +-------- |  SHIFT                            |
  | | | | +---------- |_ REGISTER                         |  SHIFT REGISTER
  | | | +------------ |  BITS                             +- MODE CONTROL
  | +---------------- |              |4|3|2|OPERATION                        |
                     -+              |0|0|0|DISABLED                         |
                                     |0|0|1|SHIFT IN UNDER CONTROL OF T2     |
 NOTES                               |0|1|0|SHIFT IN UNDER CONTROL OF 02     |
 1  WHEN SHIFTING OUT BIT 7 IS THE   |0|1|1|SHIFT IN UNDER CONT. OF EXT.CLK  |
    FIRST BIT OUT AND SIMULTANEOUSLY |1|0|0|SHIFT OUT FREE RUNNING AT T2 RATE|
    IS ROTATED BACK INTO BIT 0       |1|0|1|SHIFT OUT UNDER CONTROL OF T2    |
 2  WHEN SHIFTING IN BITS INITIALLY  |1|1|0|SHIFT OUT UNDER CONTROL OF 02    |
    ENTER BIT 0 AND ARE SHIFTED      |1|1|1|SHIFT OUT UNDER CONT. OF EXT.CLK |
    TOWARDS BIT 7                    +-+-+-+---------------------------------+
     Figure 20. Shift registers           Figure 21. Shift Register Modes
SR Mode 0 -- Disabled
Mode  0  disables  the  Shift  Register.  In  this mode the microprocessor can
write  or  read  the  SR  and  the  SR  will  shift  on each CB1 positive edge
shifting  in  the  value  on  CB2.  In  this  mode  the  SR  Interrupt Flag is
disabled (held to a logic 0).
SR Mode 1 -- Shift in Under Control of T2
In  mode  1,  the  shifting  rate  is controlled by the low order 8 bits of T2
(Figure  22).  Shift  pulses  are generated on the CB1 pin to control shifting
in  external  devices.  The time between transitions of this output clock is a
function  of  the  system  clock  period  and the contents of the low order T2
latch (N).
         02  +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+
WRITE OR READ  +---+         |           |           |           |                           |
SHIFT REG   ---+   +------------------------------------------------------#----------------------
                  N+2 CYCLES |<--------->|<--------->| N+2 CYCLES                            |
CB1 OUTPUT  -----------------+     1     +-----------+     2     +--------#--+     8     +-------
SHIFT CLOCK                  +-----------+           +-----------+           +-----------+   |
  CB2 INPUT -----------------------\/---1---\/-------------\/---2---\/----#--------\/---8---\/---
  DATA      -----------------------/\-------/\-------------/\-------/\----#--------/\-------/\---
        ___    +-----------------------------------------------------------------------------+
        IRQ ---+        +---
              Figure 22. SR Mode 1 -- Shift In Under T2 Control
The  shifting  operation  is  triggered  by the read or write of the SR if the
SR  flag  is  set in the IFR. Otherwise the first shift will occur at the next
time-out  of  T2  after  a read or write of the SR. Data is shifted first into
the  low  order  bit  of SR and is then shifted into the next higher order bit
of  the  shift  register  on  the negative-going edge of each clock pulse. The
input  data  should  change  before  the  positive-going edge of the CB1 clock
pulse.  This  data  is  shifted  into shift register during the 02 clock cycle
following  the  positive-going  edge of the CB1 clock pulse. After 8 CB1 clock
pulses, the shift register interrupt flag will set and IRQ will go low.
Post by richardtoohey » Mon Dec 31, 2018 3:51 am
(Second part of that text file, too long for one post).
SR Mode 2 -- Shift in Under 02 Control
In  mode  2,  the  shift  rate  is  a  direct  function  of  the  system clock
frequency  (Figure  23).  CB1  becomes  an output which generates shift pulses
for   controlling  external  devices.  Timer  2  operates  as  an  independent
interval  timer  and  has no effect on SR. The shifting operation is triggered
by  reading  or  writing the Shift Register. Data is shifted, first into bit 0
and  is  then  shifted into the next higher order bit of the shift register on
the  trailing  edge  of  each  02 clock pulse. After 8 clock pulses, the shift
register  interrupt  flag  will  be  set,  and  the output clock pulses on CB1
will stop.
         02 -+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-
    READ SR ---+   +-----------------------------------------------------------------------------
CB1 OUTPUT  -----------------+   +---+   +---+   +---+   +---+   +---+   +---+   +---+   +-------
SHIFT CLOCK                  +---+   +---+   +---+   +---+   +---+   +---+   +---+   +---+   |
  CB2 INPUT -----------------\/---1--\/---2--\/---3--\/---4--\/---5--\/---6--\/---7--\/---8--\/--
  DATA      -----------------/\------/\------/\------/\------/\------/\------/\------/\------/\--
        ___ ---------------------------------------------------------------------------------+
        IRQ        +---
              Figure 23. SR Mode 2 -- Shift In Under 02 Control
SR Mode 3 -- Shift in Under CB1 Control
In  mode  3,  external  pin  CB1  becomes an input (Figure 24). This allows an
external  device  to  load  the  shift  register  at  its  own pace. The shift
register  counter  will  interrupt  the  processor  each time 8 bits have been
shifted  in.  However,  the  shift register counter does not stop the shifting
operation;  it  acts  simply  as a pulse counter. Reading or writing the Shift
Register  resets  the  Interrupt  Flag and initializes the SR counter to count
another 8 pulses.
CB1 OUTPUT  ---+    1    +---------+    2    +--------#----+    8    +-------
SHIFT CLOCK    +---------+         +---------+             +---------+
  CB2 INPUT -------\/----1---\/--------\/----2---\/---#--------\/----8---\/--
  DATA      -------/\--------/\--------/\--------/\---#--------/\--------/\--
        ___                                                              |
        IRQ -------------------------------------------------------------+
                Figure 24. SR Mode 3 -- Shift In Under CB1 Control
Note   that   the  data  is  shifted  during  the  first  system  clock  cycle
following  the  positive-going  edge  of the CB1 shift pulse. For this reason,
data  must  be  held  stable  during  the first full cycle following CB1 going
high.
SR Mode 4 -- Shift Out Under T2 Control (Free-Run)
Mode  4  is  very  similar  to mode 5 in which the shifting rate is set by T2.
However,  in  mode  4  the  SR  Counter  does  not stop the shifting operation
(Figure  25).  Since  the Shift Register bit 7 (SR7) is recirculated back into
bit  0,  the  8  bits  loaded into the Shift Register will be clocked onto CB2
repetitively. In this mode the Shift Register Counter is disabled.
        02  +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+
WRITE SR   ---+   +---------------------------------------------------#---------------------------------------------
                 N+2 CYCLES |<--------->|<--------->| N+2 CYCLES|           |           |
CB1 OUTPUT -----------------+     1     +-----------+     2     +-----#-----+     8     +-----------+     9     +---
SHIFT CLOCK                 +-----------+           +-----------+           +-----------+           +-----------+
CB2 OUTPUT -------------------\/-----------1----------\/-------2------#-------\/-----------8----------\/-----1------
DATA       -------------------/\----------------------/\--------------#-------/\----------------------/\------------
        Figure 25. SR Mode 4 -- Shift Out Under T2 Control (Free-Run)
SR Mode 5 -- Shift Out Under T2 Control
In  mode  5,  the  shift rate is controlled by T2 (as in mode 4). The shifting
operation  is  triggered  by the read or write of the SR if the SR flag is set
in  the  IFR  (Figure  26).  Otherwise  the first shift will occur at the next
time-out  of  T2  after  a read or write of the SR. However, with each read or
write  of  the  shift  register the SR Counter is reset and 8 bits are shifted
onto  CB2.  At  the  same time, 8 shift pulses are generated on CB1 to control
shifting  in  external  devices.  After  the  8  shift pulses, the shifting is
disabled,  the  SR  Interrupt  Flag  is  set  and CB2 remains at the last data
level.
         02 + +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-#-+ +-+ +-+ +-+ +-+ +
   WRITE SR --+   +----------------------------------------------------------
                 N+2 CYCLES |<----->|<----->| N+2 CYCLES      |       |
 CB1 OUTPUT ----------------+   1   +-------+   2   +---#-----+   8   +------
 SHIFT CLOCK                +-------+       +-------+         +-------+
 CB2 OUTPUT --------------------\/------1------\/---2---#--------\/-----8----
 DATA       --------------------/\-------------/\-------#--------/\----------
        ___                                                           |
        IRQ ----------------------------------------------------------+
              Figure 26. SR Mode 5 -- Shift Out Under T2 Control
SR Mode 6 -- Shift Out Under 02 Control
In mode 6, the shift rate is controlled by the 02 system clock (Figure 27).
         02 + +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+ +-+   +-+ +-+ +-+ +-+ +-+ +
 CB1 OUTPUT ------------+ 1 +---+ 2 +---+ 3 +---+ 4 +--#--+ 7 +---+ 8 +------
 CB2 OUTPUT -------------\/---1--\/---2--\/---3--\/--4-#---\/---7--\/---8----
 DATA       -------------/\------/\------/\------/\----#---/\------/\--------
        ___                                                           |
              Figure 27. SR Mode 6 -- Shift Out Under 02 Control
SR Mode 7 -- Shift Out Under CB1 Control
In  mode  7,  shifting  is  controlled  by pulses applied to the CB1 pin by an
external  device  (Figure  28). The SR counter sets the SR Interrupt Flag each
time  it  counts  8 pulses but it does not disable the shifting function. Each
time   the  microprocessor,  writes  or  reads  the  shift  register,  the  SR
Interrupt  Flag  is  reset and the SR counter is initialized to begin counting
the  next  8  shift  pulses  on pin CB1.  After 8 shift pulses,  the Interrupt
Flag  is  set.  The  microprocessor  can then load the shift register with the
next byte of data.
 CB1 INPUT  --------------+   1   +---------------+   2   +---#----+  |  8  +
 SHIFT CLOCK              +-------+               +-------+        +--------+
 CB2 OUTPUT --------------\/-----------1----------\/-----2----#----\/---8----
 DATA       --------------/\----------------------/\----------#----/\--------
        ___                                                           |
             Figure 28. SR Mode 7 -- Shift Out Under CB1 Control
INTERRUPT OPERATION
Controlling    interrupts   within   the  R6522   involves   three   principal
operations.  These  are  flagging  the  interrupts,  enabling  interrupts  and
signaling  to  the  processor that an active interrupt exists within the chip.
Interrupt  flags  are  set  in the Interrupt Flag Register (IFR) by conditions
detected  within  the  R6522  or  on inputs to the R6522. These flags normally
remain  set  until  the  interrupt  has been serviced. To determine the source
of  an  interrupt,  the microprocessor must examine these flags in order, from
highest to lowest priority.
Associated  with  each  interrupt  flag  is  an  interrupt  enable  bit in the
Interrupt   Enable  Register  (IER).  This  can  be  set  or  cleared  by  the
processor   to  enable  interrupting  the  processor  from  the  corresponding
interrupt  flag.  If  an interrupt flag is set to a logic 1 by an interrupting
condition,  and  the  corresponding  interrupt  enable  bit is set to a 1, the
Interrupt  Request  (IRQ)  output  will  go  low.  IRQ  is an "open-collector"
output  which  can  be  "wire-OR'ed"  with  other  devices  in  the  system to
interrupt the processor.
In  the  R6522,  all  the interrupt flags are contained in one register, i.e.,
the  IFR  (Figure  29).  In addition, bit 7 of this register will be read as a
logic   1  when  an  interrupt  exists  within  the  chip.  This  allows  very
convenient  polling  of  several  devices within a system to locate the source
of an interrupt.
      REG 13 -- INTERRUPT FLAG REGISTER
|7|6|5|4|3|2|1|0|             SET BY                    CLEARED BY
 | | | | | | | +--CA2| CA2 ACTIVE EDGE       | READ OR WRITE REG 1 (ORA)*   |
 | | | | | | +--CA1--| CA1 ACTIVE EDGE       | READ OR WRITE REG 1 (ORA)    |
 | | | | | +SHIFT REG| COMPLETE 8 SHIFTS     | READ OR WRITE SHIFT REG      |
 | | | | +-CB2-------| CB2 ACTIVE EDGE       | READ OR WRITE ORB*           |
 | | | +-CB1---------| CB1 ACTIVE EDGE       | READ OR WRITE ORB            |
 | | +-TIMER 2-------| TIME-OUT OF T2        | READ T2 LOW OR WRITE T2 HIGH |
 | +-TIMER 1---------| TIME-OUT OF T1        | READ T1 LOW OR WRITE T1 HIGH |
 +-IRQ---------------| ANY ENABLED INTERRUPT | CLEAR ALL INTERRUPTS         |
  * IF THE CA2/CB2 CONTROL IN THE PCR IS SELECTED AS "INDEPENDENT"
    INTERRUPT INPUT, THEN READING OR WRITING THE OUTPUT REGISTER
    ORA/ORB WILL NOT CLEAR THE FLAG BIT. INSTEAD, THE BIT MUST BE
    CLEARED BY WRITING INTO THE IFR, AS DESCRIBED PREVIOUSLY.
                   Figure 29. Interrupt Flag Register (IFR)
The  Interrupt  Flag  Register  (IFR)  may  be read directly by the processor.
In  addition,  individual  flag  bits may be cleared by writing a "1" into the
appropriate  bit  of  the  IFR.  When  the  proper  chip  select  and register
signals  are  applied  to  the  chip, the contents of this register are placed
on  the  data  bus.  Bit  7  indicates  the status of the IRQ output. This bit
corresponds  to the logic function:  IRQ = IFR6xIER6 + IFR5xIER5 + IFR4xIER4 +
+ IFR3xIER3 + IFR2xIER2 + IFR1xIER1 + IFR0xIER0
                                    Note:
                         x = logic AND, + = logic OR
The  IFR  bit  7  is  not  a flag. Therefore, this bit is not directly cleared
by  writing  a  logic  1  into  it. It can only be cleared by clearing all the
flags   in  the  register  or  by  disabling  all  the  active  interrupts  as
discussed in next section.
For  each  interrupt  flag  in  IFR,  there  is  a  corresponding  bit  in the
Interrupt  Enable  Register  (IER) (Figure 30). Individual bits in the IER can
be  set  or  cleared  to  facilitate controlling individual interrupts without
affecting  others.  This  is  accomplished  by  writing to the IER after bit 7
set  or  cleared  to,  in turn, set or clear selected enable bits. If bit 7 of
the  data  placed  on  the system data bus during this write operation is a 0,
each  1  in  bits  6  through  0  clears the corresponding bit in the IER. For
each zero in bits 6 through 0, the corresponding bit is unaffected.
                 REG 14 -- INTERRUPT ENABLE REGISTER
                          |7|6|5|4|3|2|1|0|
                           | | | | | | | +--- CA2       |
                           | | | | | | +----- CA1       |  0 = INTERRUPT
                           | | | | | +------- SHIFT REG |      DISABLED
                           | | | | +--------- CB2       |_
                           | | | +----------- CB1       |
                           | | +------------- TIMER 2   |  1 = INTERRUPT
                           | +--------------- TIMER 1   |      ENABLED
                           +----------------- SET/CLEAR |
         NOTES:
         1  IF BIT 7 IS A "0", THEN EACH "1" IN BITS 0-6 DISABLES THE
            CORRESPONDING INTERRUPT.
         2  IF BIT 7 IS A "1",  THEN EACH "1" IN BITS 0-6 ENABLES THE
         3  IF A READ OF THIS REGISTER IS DONE, BIT 7 WILL BE "1" AND
            ALL OTHER BITS WILL REFLECT THEIR ENABLE/DISABLE STATE.
                  Figure 30. Interrupt Enable Register (IER)
Selected  bits  in  the  IER  can  be  set by writing to the IER with bit 7 in
the  data  word  set  to  a  logic 1. In this case, each 1 in bits 6 through 0
will  set  the  corresponding  bit.  For each zero, the corresponding bit will
be   unaffected.   This   individual  control  of  the  setting  and  clearing
operations  allows  very  convenient  control  of the interrupts during system
operation.
In   addition  to  setting  and  clearing  IER  bits,  the  contents  of  this
register can be read at any time. Bit 7 will be read as a logic 1, however.
Post by Coeus » Mon Dec 31, 2018 12:50 pm
Ok, so just to make sure I understand what I am looking at in that spreadsheet, is row 1 the value in the low byte of the timer under test? Then on the other rows I assume instructions have been chosen to take up various different numbers of clock cycles so the instruction that does finally access the VIA happens with various different counter values.
Are these tests included on your tests.ssd?
