Which is the canonical Elkulator repository?
myelin
Post by myelin » Thu Jun 07, 2018 4:41 pm
I'm doing some work with Elkulator (getting it to replay bus cycles recorded from a real machine) and there seem to be several repositories around, none of which claims to be the canonical one. I'm guessing David Boddie's Bitbucket repo is the one to go with... is that right?
Re: Which is the canonical Elkulator repository?
Post by Elminster » Thu Jun 07, 2018 4:48 pm
Hmmm I was using this one, looks similar.
https://github.com/rcook/elkulator
But looks more recent updates in the Bitbucket one.
SarahWalker
Post by SarahWalker » Thu Jun 07, 2018 5:02 pm
The 'canonical' one vanished when the Retro Software mercurial repo disappeared. If David's been working on the emulator then I'd suggest using his...
Post by davidb » Fri Jun 08, 2018 7:45 pm
I'd like to be able to feed my changes back into an official repository. I can import mine into a new one under the stardot organisation on GitHub if that sounds good.
myelin, I noticed that you sent me some pull requests. I'll try and get to them early next week. :)
Post by Elminster » Fri Jun 08, 2018 8:54 pm
I prefer github but only because I use it enough to understand it better than bitbucket. Either way looks like I need to move where I am building my elkulator docker image from.
myelin
Post by myelin » Fri Jun 08, 2018 9:01 pm
GitHub would be great. I'm starting to understand Mercurial and Bitbucket a bit better after submitting a few changes to Arculator, but I'm still much more familiar with Git :)
