Some fixes to 32016 emulation in B-Em
litwr
Post by litwr »
I have found that Carry flag is set wrong sometimes. So I have checked the sources. The problem is in the AddCommon function.
static uint32_t AddCommon(uint32_t a, uint32_t b, uint32_t cin)
   uint32_t sum = a + (b + cin);
   if (b == 0xffffffff && cin == 1)
      C_FLAG = 1;
      F_FLAG = 0;
   else
      switch (OpSize.Op[0])
         case sz8:
               C_FLAG = TEST(sum & 0x100);
               F_FLAG = TEST((a ^ sum) & (b ^ sum) & 0x80);
            break;
         case sz16:
               C_FLAG = TEST(sum & 0x10000);
               F_FLAG = TEST((a ^ sum) & (b ^ sum) & 0x8000);
            break;
         case sz32:
               C_FLAG = TEST(sum < a);
               F_FLAG = TEST((a ^ sum) & (b ^ sum) & 0x80000000);
            break;
   return sum;
C_FLAG gets wrong value for negative terms. For example, let R0=2 and we use ADDQB =-1,R0. The code above will make 0xffffffff+2+0=1. The carry flag must be set but it is not because 1 & 0x100 = 0. :( IMHO the next code for CF will work properly.
               C_FLAG = TEST(((a & 0xff) + (b & 0xff) + cin) & 0x100);
               C_FLAG = TEST(((a & 0xffff) + (b & 0xffff) + cin) & 0x10000);
               C_FLAG = TEST(sum < a || sum < b);         //this maybe used for all three cases
The branch for (b == 0xffffffff && cin == 1) maybe removed. The overflow flag has the same problem. The arguments and result are always 32 bit. So the code for this flag maybe
             F_FLAG = (a^b)&0x80000000 ? 0 : !!((a^sum)&0x80000000);
So all code maybe assembled to
   uint32_t sum = a + b + cin;
   return sum;
SubCommon should be also fixed.
Re: Some fixes to 32016 emulation in B-Em
Post by hoglet »
Thanks for posting this. It does look like I messed this up!
It's likely this problem affects PiTubeDirect as well, as it's the same emulator code base.
Can I ask if you have a high level test case that was failing before and is now passing? If so, can you share this?
It's a shame there isn't a comprehensive test suite for the 32016, like the DORMANN tests for the 6502.
Edit: I'm not sure I agree with your simplified version. Surely the size of the operands (8, 16 or 32 bits) must have some bearing on the flags?
litwr
Post by litwr »
hoglet wrote:Can I ask if you have a high level test case that was failing before and is now passing? If so, can you share this?
I will be happy to share but there are several lines of my codes only. I tried a sequence
L1
  MOVZBD ='0',TOS
  CXP XWriteByte
  ADDQB =-1,MEM
  BCS L1
MEM FCB 3
It should print '0' three times but it printed '0' only one time. I began to check the sources...
32016 is much more complex than 6502... It will be a very big task...
B-em's code converts any integer value to 32 bit unsigned integer and then extracts if necessary byte or word. However you are right - there was a tiny mistake for a very rare situation. The proper code is a bit bigger in size.
   if (cin == 0)
   else
      C_FLAG = TEST(sum <= a || sum <= b);
I have recompiled B-em with this patch. Panos and my small code works. :) I have still not made the code for SUB it is not required in my program but I am curious to make it too.
litwr
Post by litwr »
It is not so easy... The code does not use 32-bit sign extension for the every case. :( So my previous fix must be fixed too. For example, the code
case ADDQ:
            temp2 = (opcode >> 7) & 0xF;
            NIBBLE_EXTEND(temp2);
            temp = ReadGen(0);
            temp = AddCommon(temp, temp2, 0);
maybe replaced by
case ADDQ:
            temp = ReadGen(0);
            SIGN_EXTEND(OpSize.Op[0], temp);
The similar change should be made before every AddCommon invocation. I have also made the code for SubCommon
static uint32_t SubCommon(uint32_t a, uint32_t b, uint32_t cin)
   uint32_t diff = a - b - cin;
   if (cin == 0)
      C_FLAG = TEST(a < b);
   else
      C_FLAG = TEST(a <= b);
   F_FLAG = TEST((a ^ b) & (a ^ diff) & 0x80000000);
   return diff;
This code also assumes that a and b are 32 bit sign extended values.
litwr
Post by litwr »
I also have to add that the disc #2 in the Panos installation discs from J.G.Harston's mdfs.net is not right. The files have improper names. So they should be renamed before usage.
Ed6502 -> Ed6502-bbc
EdHelp -> EdHelp-dat
EdInit -> EdInit-dat
Edit   -> Edit-rif
InitDFS -> InitDFS-cmd
Link   -> Link-rif
Panos  -> Panos-lib
It maybe done by RENAME command, for example, RENAME Panos Panos-lib. Filenames are not case sensitive. I may report that Assembler, Linker and Editor work with B-em. However I had met strange behaviors of Assembler sometimes. It maybe caused by the fixed errors mentioned above.
Post by BigEd »
Thanks for the fixes litwr - they work for PiTubeDirect so I've applied them there.
fordp
Post by fordp »
BigEd wrote:Thanks for the fixes litwr - they work for PiTubeDirect so I've applied them there.
Is there a reason these patches have not been applied back to the B-Em repo?
FordP (Simon Ellwood)
Post by BigEd »
Well, for my part, I didn't even think of it! But possibly also, it would be good to have a solid test of the flags on the 32016, to test the real thing, the FPGA, this software model. Partly because flags are difficult, and partly because this has already been fixed once. Which might be the same statement!
fordp
Post by fordp »
As my master is dead I thought I would have a go at B-Em :(
Post by hoglet »
There are several forks of B-Em around.
I'll try to push these changes to mine later today.
fordp wrote:As my master is dead I thought I would have a go at B-Em :(
What happened to your Master?
fordp
Post by fordp »
It died as I was attaching my serial debug lead to my internal Pi Direct.
I shorted two pins out on the serial connector with my scope probe and that was that.
I suspect the short caused a temporary BBC PSU issue and something died. Now the master shows just a cursor with no text at boot even with all but the main ROM and all not needed stuff stripped out.
Post by hoglet »
fordp wrote:It died as I was attaching my serial debug lead to my internal Pi Direct.
Do you mean the serial connector on the level shifter? I don't understand how a short to ground on that could take out the Master.
Is the Pi still working?
There was a recent thread where mw0uzo got his two Master working again:
Dead BBC Masters - ROM screwup leading to main system damage
Do you have any kind of a logic analyzer?
If not, there are some very cheap 16Ch ones available:
http://hobbycomponents.com/cypress/675- ... ser-bundle
With a suitable 40-pin DIP test clip, you should be able to capture the PHI2, DATA[7:0], RnW, SYNC, nRST from the 65SC12 processor and figure out what's going on.
It should also be possible to write a reverse disassembler for such a trace that would show the instruction stream. I'd be happy to help with this.
fordp
Post by fordp »
Thanks Dave,
I have loads of test gear including logic analysers and two scopes one with logic analyser.
The two things I lack is good eye sight and time. I have ordered a replacement main board for my master so I will pop that in next week. I can keep my presumably broken one for spares then.
I have not tried the Pi but I would guess it is OK. I am just guessing that my master broke when I was attaching cables, I was also swapping keys around on my master keyboard.
Can anybody spare me a couple of master key switches?
litwr
Post by litwr »
Sorry I forgot to upload the fixes.
32016-carry-fix.zip
(13.4 KiB) Downloaded 57 times
Post by hoglet »
litwr wrote:Sorry I forgot to upload the fixes.
I think there is a type in ADDC:
         case ADDC:
            temp2 = ReadGen(0);
            SIGN_EXTEND(OpSize.Op[0], temp2);
            temp = ReadGen(1);
            SIGN_EXTEND(OpSize.Op[1], temp2);
            temp3 = C_FLAG;
            temp = AddCommon(temp, temp2, temp3);
         break;
The second SIGN_EXTEND should be:
            SIGN_EXTEND(OpSize.Op[1], temp);
fordp
Post by fordp »
         case ADDC:
            temp2 = ReadGen(0);
            temp = ReadGen(1);
            temp3 = C_FLAG;
         break;
Indeed the old code is wrong for sure!
litwr
Post by litwr »
Sorry. :oops: Of course, it is a typo. I had also accidentally removed comments. :oops:
32016-carry-fix-2.zip
(13.57 KiB) Downloaded 53 times
dp11
Post by dp11 »
I think line 23
int nsoutput = 0;
Can be removed.
I also think in n32016_reset_addr , FSR should be cleared
bsdnazz
Post by bsdnazz »
I've just tried to boot the PanOS 1.1 and 1.4 disk images http://mdfs.net/Mirror/Archive/Acorn/PanOS/ using a RetroClinic DataCentre for floppy emulation and a Rasberry Pi running with the SD card from Kjell Sundby.
Unfortunately both PanOS versions hang loading PanOS. Has any one got PanOS booting on the Pi?
dp11
Post by dp11 »
Firstly which version of PiTubeDirect are you using ?
bsdnazz
Post by bsdnazz »
While my real 32016 hardly gets any further with the Data Centre. I get an "*** Exception (UND) at PC = XXXXXX" on both versions of PanOS. 000300 for V1.1 and 019A65 for V1.4
This may be due to my 32016 having Pandora 0.6 ROMS.
bsdnazz
Post by bsdnazz »
dp11 wrote:Firstly which version of PiTubeDirect are you using ?
I'm not entirely sure! I bought a Tube adaptor from Kjell Sundby in Nov 2016 and ordered an SD card from him at the same time so it's what he was shipping then.
I see that with the Anaconda release of PiTubeDirect I only need a FAT32 formatted SD card so it looks like my first task is to get Anaconda booted and try that.
fordp
Post by fordp »
bsdnazz wrote:While my real 32016 hardly gets any further with the Data Centre. I get an "*** Exception (UND) at PC = XXXXXX" on both versions of PanOS. 000300 for V1.1 and 019A65 for V1.4
Do you mean 0.61 or are they really 0.6?
bsdnazz
Post by bsdnazz »
I will have to double check when I get home. They just have white pricing labels over the eproms with 'Hi' and 'Lo' written on them.
Edit - it's got 0.61 Pandora Roms.
Post by BigEd »
bsdnazz wrote:Has any one got PanOS booting on the Pi?
Just to answer this one: yes! Not just the full PanOS on an ADFS partition, but also mini-PanOS as seen on litwr's SSD images. (Edit: for example this.)
bsdnazz
Post by bsdnazz »
Can I beg for some dsd image files? An ADFS for tge datacentre ide would be ace too.
Post by BigEd »
Can't help with DSD - I'm too ignorant - but just possibly this 400M download will be an ADFS image for PanOS and DosPlus. (That link won't be live forever - I'm sure there's a more official one - but it might do for now.)
Edit: Dave posted a link to a 7zip compressed image for a 2G or larger SDCard here.
bsdnazz
Post by bsdnazz »
BigEd wrote:Can't help with DSD - I'm too ignorant - but just possibly this 400M download will be an ADFS image for PanOS and DosPlus. (That link won't be live forever - I'm sure there's a more official one - but it might do for now.)
Thanks - I'm downloading them now. However, it looks like they are MMC image files and I'll have to see if/how they can be transferred to the RetroClinic DataCentre I have.
bsdnazz
Post by bsdnazz »
I've downloaded and booted the Anaconda build of PiTubeDirect but it hangs as the same point as the previous version.
I'm begining to wonder if the DSD images I got from MDFS.NET are corrupt. Has anyone successfully run any of these?
Is there another source of PanOS DSD images?
Post by hoglet »
If you can work with .ssd images, these are known to work:
viewtopic.php?p=133413#p133413
