When I've located my disk or tape image, why do I have to navigate all the way back to pick a new game from the same folder?
How do I stop that? Vice doesn't make me. It's really getting on my nerves.
Beeb-Em directory to stay where I left it?
- Contact:
- Lardo Boffin
- Contact:
Re: Beeb-Em directory to stay where I left it?
I know what you mean. On mine it defaults to the root Beeb Em folder in My Documents every time I go to select a disc. I don't use it much so it isn't really a problem for me.
Have you checked out what you can put in the config file? There may be an option you can set / enable. Or it could be the case that it just doesn't cache the last used location - not all Windows (or Mac, I'm an equal opportunity user) programs do. If this is the case it will always go back to the default location.
Adventure Language on GitHub
Atom, issue 5
Elk
Atom, issue 5
Elk
- Contact:
I can't actually see anything. I've dragged a few things into Notepad but see no paths.
Sometimes when I've downloaded a few things or am testing things out prior to feeding into a real Beeb, reloading can be a fiddly pain when there are folders and folders to flit between but only here and there.
- CMcDougall
- Contact:
Am on Win10, and it remembers where I last was...
Or right click on .SSD /.DSD and choose 'open with' and find BeebEm414. Then when you double click on a SSD or DSD (or .UEF/CSW),
it boots up
it boots up
There's a save preferences menu somewhere which should sort you out I think.
- Contact:
There is a save preference but you have to set a preference. And none I see cover directories.
But I like CMcDougall's advice on coming at it the other direction. That's nice and it works a treat, even with the emulator already on.
I never thought of that because to drag and drop doesn't work. I thought it was all the same.
Thanks.
Thanks.
- DutchAcorn
- Contact:
On version 3.82 (the one I use) under Options->Preference Options there is an option "Save Disc/Tape/State Folders".Commie_User wrote:There is a save preference but you have to set a preference. And none I see cover directories.
Thanks.
- Contact:
Oh, that's what it is. Must have not worked.
Well it's going now, thanks.
I've got 4.14.
I've got 4.14.
