B-Em
Re: B-Em
Post by Coeus » Mon Apr 23, 2018 8:28 pm
tricky wrote:...I have a config file with several layouts for each of several joysticks and then select the appropriate one...
Do you have an example config file, please?
Re: B-Em
Post by tricky » Mon Apr 23, 2018 10:29 pm
I'm not putting it forward as a candidate, it was just a proof of concept, but the one in the linked thread is a basic one for two controllers.
robably change this for myself as I don't really like allegro)
joymaps.txt
CODE: SELECT ALL
-joymap zx2 Controller (XBOX 360 For Windows)
LEFT  = Z
RIGHT = X
UP    = QUOTE
DOWN  = SLASH
0         = ENTER
1         = SHIFT
10        = QUIT
-joymap zx2
POV_LEFT  = Z
POV_RIGHT = X
POV_UP    = QUOTE
POV_DOWN  = SLASH
0         = ENTER
3         = SHIFT
12        = QUIT
A new config is started with -joymap, followed by its name and optionally the name of a controller (no name is used if name cannot be matched).
Numbers are button indices.
My hori stick has its joystick mapped to the POV hat for some reason!
pau1ie
Re: B-Em
Post by pau1ie » Tue Apr 24, 2018 7:55 am
Comparing this version of b-em with the previous one, I notice it uses much less CPU. The previous one uses 1 1/4 core, mostly X, Sound is choppy, presumably because it is running slightly slower than full speed. The new version uses about 75% of a core on my aging laptop. I suspect this is caused by the newer version of allegro being more efficient, either not updating the screen if it hasn't changed, or taking advantage of hardware acceleration. There is the occasional blip in sound, but I suspect this wouldn't happen on newer hardware, or on the type of sounds in most games.
Together with the vastly improved interface and incorporation of new hardware, I am really excited. Thanks to all who have contributed to this effort!
Re: B-Em
Post by BigEd » Tue Apr 24, 2018 8:16 am
That does sound promising! Is a Raspberry Pi up to the task of running this latest version with good performance? A Pi configured to boot directly into a full-screen emulator would be quite a thing, I think.
Re: B-Em
Post by Elminster » Tue Apr 24, 2018 8:44 am
I have Raspberry pi version of B-Em Allegro 5.2. It is a bit sluggish on a 3 B+ (lthough quicker than B2). But I also have the over heard of running it in docker and using vnc to view it. It maybe a bit quicker if run directly on the hardware.
KaleviKolttonen
Re: B-Em
Post by KaleviKolttonen » Tue Apr 24, 2018 8:58 am
My /opt/b-em/resourcedir/joymaps/boulder_dash_joymap looks like this:
# KEY_Z
left 6 1
# KEY_X
right 4 2
# KEY_QUOTE
up 4 8
# KEY_SLASH
down 6 8
# KEY_SPACE
button 6 2
So the format is not that user friendly, because you have to enter the raw BBC Micro keycodes as values.
I don't remember my C code, but probably I mapped all controller buttons with "button", thinking that old style Atari-joysticks had only one Fire-button. I only have Logitech Rumblepad 2 and Logitech Precision USB controllers, I haven't tested my code with more complicated controllers.
Re: B-Em
Post by Coeus » Sun Apr 29, 2018 4:50 pm
I suddenly had the idea that I might be able to attach a game controller as joystick and, sure enough, my wife's Xbox One controller has a micro-USB port. It does seem a little quirky as a controller but for testing it does have the advantage of multiple sticks and buttons including physical sticks that seem to drive more than one logical stick axis. Anyway, from that I got joysticks working, at least on Linux so far - it should work the same on Windows - and included enough flexibility to completely re-map the stick if you so desire. The latest commit for that is https://github.com/stardot/b-em/commit/ ... db3e25bbb6, the Wiki page is at https://github.com/stardot/b-em/wiki/Joysticks
myelin
Re: B-Em
Post by myelin » Sat May 26, 2018 8:05 pm
I've been under the impression that the only Acorn emulator that worked on macOS was Clock Signal, but I just built the sf/allegro5 branch of b-em, and it ran just fine, with only minor tweaks (here's the PR) to get it to build!
Nice work :D
Re: B-Em
Post by Elminster » Sat May 26, 2018 8:40 pm
Nice work :D
B2 works on Mac
But will have a play with B-Em when merged
Re: B-Em
Post by Coeus » Mon May 28, 2018 7:26 pm
That's good news. It has not been my intention to break Mac compatibility but I don't have one to test on, so good to hear such small changes suffice.
BTW, does static assert occur in Mac-specific headers because I didn't think B-Em used it itself.
I'll check that the changed version still builds on Linux and Windows.
Re: B-Em
Post by Coeus » Mon May 28, 2018 11:59 pm
And further to my last message I have made a copy of the previous master in branch allegro4 and merged the sf/allegro5 branch into master.
Re: B-Em
Post by Elminster » Tue May 29, 2018 9:27 am
I can confirm that B-EM with Allegro 5 builds straight out of the box on the master branch on Mac High Sierra. (Thanks Coeus & Myelin). Although I havent done any more testing than running 'hello world' in basic.
Only thing that is missing is build instructions, which is basically the same as Linux except I did a
brew install allegro
to get allegro 5.
Re: B-Em
Post by danielj » Tue Jul 17, 2018 8:39 pm
I've just done the same, works like a charm - particularly good as the latest OSX broke compatibility with beebem :)
Re: B-Em
Post by Elminster » Tue Jul 17, 2018 9:01 pm
I have a feature request of putting Sprow Master Ethernet into b-em, but I know if I ask someone will say, ‘fork, get coding, merge patch’.
Re: B-Em
Post by danielj » Wed Jul 18, 2018 8:08 am
For GitHub projects the best way to get the attention of the contributors is to raise an issue.
But yes, get coding :D
Re: B-Em
Post by Elminster » Wed Jul 18, 2018 8:42 am
Sure you dont need a post Freewifi project? I am only thinking of your mental wellbeing of course.
I think when I started my retro todo list everything was latest tech #-o
Re: B-Em
Post by CMcDougall » Wed Aug 22, 2018 11:09 am
tried playing v415b1 on my older laptop with winXP (as sick to death of win10 on it)
I install it, but then says not a program :shock:
Works perfectly on my newer laptop with win10, so wonder if not built for 32bit only 64.... :?
bakoulis
Re: B-Em
Post by bakoulis » Tue Sep 11, 2018 11:52 pm
I am looking for a way to use the beeb.mmb file with B-Em for Linux.
Is it possible in some way?
Re: B-Em
Post by hoglet » Wed Sep 12, 2018 6:53 am
The short answer is no, not at the moment (nor with Windows).
Re: B-Em
Post by Coeus » Wed Sep 12, 2018 8:02 am
B-Em doesn't currently understand MMB files. The module that deals with disc images could easily be adapted as it just means adding an offset to all file seeks for the particular SSD you're interested in. The greater amount of work would be working out how to specify which SDD. One possibility would be implement the command set from from the typical MMC/SD card filing systems.
In the mean time, on Linux, there is Steve Harris's beeb utility which allows you to extract SSDs from an MMB file.
bakoulis
Re: B-Em
Post by bakoulis » Wed Sep 12, 2018 9:32 am
I don't need to extract any specific SSD from MMB file. I have everything as SSD. My question was about MMB file, because this like as a hard disk with many games in and it have a very nice menu to choose quick what you want to play and if you bored, a CTRL+F12 brings again the magic menu to choose from!
Re: B-Em
Post by tricky » Thu Sep 13, 2018 1:00 pm
I believe that beebem supports beeb.mmb files with an extra DLL, which might be ported, although I have never looked at the code and may be completely wrong!
