BeebEM on GitHub
billcarr2005
BeebEM on GitHub
Post by billcarr2005 » Tue Feb 09, 2016 1:14 pm
I was made aware of this via the BBC-Micro mailing list.
Ben Collier has set up the "Semi-official repository for the BeebEm emulator", here
https://github.com/bmcollier/beebem
There's already several issues raised for enhancements, including raw disk image support ( such as FSD! 8) ) [-o<
bakoulis
Re: BeebEM on GitHub
Post by bakoulis » Sun Feb 14, 2016 5:27 pm
I have tried to installed at Linux Mint 17.3.
After the command
sudo ./configure.ac --enable-econet
that gives me an error
./configure.ac: 1: ./configure.ac: Syntax error: word unexpected (expecting ")")
poink
Post by poink » Sun Feb 14, 2016 6:21 pm
bakoulis wrote:I have tried to installed at Linux Mint 17.3.
After the command
As it's a repository, it doesn't have the 'configure' file, you have to run autoconf to create it. Try the following, in the top level source directory:
aclocal
autoconf
autoheader
automake --add-missing
Then you can run
./configure --enable-econet
make
I'd add that you shouldn't build software with root privileges; you only need sudo to install it systemwide, eg:
sudo make install
bakoulis
Post by bakoulis » Sun Feb 14, 2016 6:44 pm
Nice! Thank you mate. It works.
=D>
Post by sydney » Fri Apr 08, 2016 5:12 pm
I've followed the instructions above and beebem is now installed but it is very slow. The windows version runs faster under wine than the linux version. My laptop is a puny HP mini 110 but I thought it would at least match the windows version.
Post by hoglet » Thu Aug 25, 2016 7:03 pm
It seems Ben Collier's github account no longer exists.
Anyone know what's going on here?
I think these are forks of Ben's beebem repository before it was deleted:
https://github.com/sjnewbury/beebem-1/commits/master
https://github.com/mjwoodcock/beebem/commits/master
Post by Coeus » Fri Sep 09, 2016 11:30 pm
sydney wrote:I've followed the instructions above and beebem is now installed but it is very slow. The windows version runs faster under wine than the linux version. My laptop is a puny HP mini 110 but I thought it would at least match the windows version.
Interesting. I thought I'd do some comparisonsso here is BeemEm running on Windows 7 in VirtualBox:
This gave a warning about Direct X and one other which I can't remember and said it was falling back to GDI mode. Here is Windows taskmanager with BeebEm running. Interestingly, if I switch to "Processes" it shows BeebEm as consuming almost nothing and "System Idle Process" at 95% so there is something weird in how Windows is accounting CPU time here.
And this is what top shows on the Linux host running the VirtualBox instance BeebEm is running under:
Here is BeebEm from https://github.com/sjnewbury/beebem-1/commits/master running natively on Linux:
and here is top for running natively:
So it does look like BeebEm is more CPU intensive under Linux. I am not sure why, at this stage, but it seems like something worthy of investigation.
For comparison here is B-EM running natively on Linux:
Post by jgharston » Fri Nov 18, 2016 12:05 am
I spotted a bug in the Torch Tube implementation,fixed it, and Serial Torch Tube works!
The Torch and CUBE coprocessors implement a Tube interface with a 6522 VIA back to back with a Z80 PIO, providing one 1-byte data port each way with TxRDY/RxRDY handshaking. The Torch and CUBE implement their own communication protocol and API so you can't make standard BBC MOS API calls. Serial Tube implements the standard Tube MOS API communicating over just such a 1-byte handshaking port.
simonm
Post by simonm » Fri Nov 18, 2016 1:14 am
We should perhaps look at getting a fork of this into the stardot github team repo in case any other personal accounts go down.
Post by tricky » Fri Nov 18, 2016 6:22 am
When I finish getting my torch working, I'll have to give that a go.
